Brake Reach
Quoted: 200 Post(s)
Liked 65 Times
Brake Reach
I am thinking of changing cantilever brakes to V brakes on a very old mountain bike. Do the V brakes have the same reach as cantilever brakes? Sometime ago I tried to add different cantilever brakes to this bike. The reach was different and they did not work out.
Quoted: 1944 Post(s)
Liked 2,164 Times
Most v-brakes are just a swap on old 26ers.
You will need to change the brake levers to a longer cable pull.
John
John
Quoted: 4205 Post(s)
Liked 3,863 Times
The easy answer is usually yes, reach is about the same. The real answer is found by trial fitting as some brake geometries can limit or extend reach at the limits, this is dependent on rim specs and boss spacing too. Andy
AndrewRStewart
AndrewRStewart
Bikes: Raleigh Competition GS, Freschi Supreme, Miyata 1000, Trek 520, Marin Pine Mountain, Specialized RockCombo, Soma Smoothie, Surly Cross-Check
Quoted: 99 Post(s)
Liked 267 Times
Echoing the above comments that it SHOULD work and of course you'll have to also swap your levers to linear pull.
Just this weekend, I swapped the canti brakes on my 1990 Trek 950 and it went smoothly. I used Tektro M730 brakes (good range of reach adjustability) and paired them with Tektro RS360A levers. The only tweak I had to make was swapping the thick/thin pad spacers on the rear brake. It's my first ever experience with V-Brakes, but the instructions were easy to follow and piece of cake to set up.
Quoted: 200 Post(s)
Liked 65 Times
I have XTR 8 speed levers that incorporate the shifters. They are still functioning perfectly. I was thinking of going the travel agent route.
Likes For daniell:
Liked 2,164 Times
Are your cantis XTR M900’s?
Those are very nice brakes.
John
John
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
It's a little concerning that the reach was wrong on the other set of cantis. Wonder which is non-standard, your existing cantis or the other set?
Quoted: 200 Post(s)
Liked 65 Times
https://www.performancebike.com/shim...qtqhe?v=305118
Likes For daniell:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
I was surprised too. Fortunately I was able return them. These are the brakes that I am currently using.
Anyway, that design has a lot of adjustment to them and, with Kool Stop salmon brake pads, they stop really well when set up properly. So, is it that you can't get those to reach or are they just not stopping well for you?
Liked 3,863 Times
The most common reasons for a canti brake to not stop as well as they could is- old and/or poor pads, too much cable friction, poor straddle cable to canti arm angle and poor pad alignment. A good set of pads (I also like KS) and possibly a different straddle length and/or brake cable and some adjustments can do wonders in many cases.
Here's a link to Sheldon Brown's site page explaining about cantis and how to set them up. The Geometry of Cantilever Brakes (sheldonbrown.com) Andy
AndrewRStewart
AndrewRStewart
Liked 2,164 Times
If you can’t resolve your cantilever brakes and you don’t care for the travel agent, you might be able to find separate mounts for the shifter pods.
I think, but not sure these days, that a slightly later shifter mount from an STX, or LX, XT, etc. will work on your pod mounts.
If you are close to a co-op and can find a couple of non-working individual trigger shifters cheap you can separate yours from the brake levers and run a linear/v brake setup properly.
I think Delta(?) made some aftermarket flexible plastic mounts but those might be tough to find these days.
John
John
Quoted: 200 Post(s)
Liked 65 Times
John
John
I may be beating a dead horse with this problem. I was never able to center the cantilever brakes. One block is all the way in, the other all the way out. I have already discussed this in a previous thread. First I thought that there may be a frame alignment problem. I checked the wheel for dish. Perfect. I am now thinking that the hangers might be out of alignment. If that is the case, perhaps V brakes would solve my problem.
Quoted: 1143 Post(s)
Liked 1,740 Times
Take a picture of what you have set and post it, that will help the forum trouble shoot.
One block in one block out? Sound like a simple screw adjustment, or spring mounted in wrong position, or maybe you just need to manipulate the spring.
I would start be cleaning the brake bosses, check for clean pivoting, sometimes the brake bosses can mushroom at the top hindering the pivot action. If I recall those calipers have a plastic spring cover that break as well, that could put out of wack. We don't know what your straddle cable type or condition is.
To me it sounds like spring tension.
Quoted: 200 Post(s)
Liked 65 Times
Liked 2,164 Times
If you can find just the shifter mounts, not attached to the brake levers, you can swap the brake levers for compatible linear/V and mount the shifters and brake levers independent of each other.
I think the same shifter pod interface was used on later mtb shifters. If you can find some, preferably cheap non-working, just mount your XTR shifter pods to the mounts.
I have done this.
John
Liked 1,740 Times
Hard to see what's going on with the knobby tire.
The first thing I see is the pads are not set symmetric. One pad is lower than the other and the brake block are not at even measure between block holders and calipers.
That is a set screw at the bottom of the one on the drive side, that does side to side. Tighten that and it will open to the drive, loosen will open to the nondrive.
There may be an issue with the straddle housing it looks like it may be in the pinch, that housing has to be the right length or it will never center. I'm not a fan of that type of straddle.
Quoted: 200 Post(s)
Liked 65 Times
Liked 1,740 Times
It's all spring tension, you probably need to get a little midevil on the spring(s).
I did manipulate the spring to even the tension and pull on the last set of cantis I set on my Miyata.
These are an older version of cantis I bought from a friend.
Quoted: 1324 Post(s)
Liked 927 Times
That design of straddle cable is supposed to be a safety feature in that if a cable breaks (especially the front one) the straddle cable will not drop down onto the tire and cause the wheel to lock up.
Cheers
Quoted: 966 Post(s)
Liked 1,629 Times
40 years ago little things like brake reach, seat and bar height, pedals, were not a big issue. I could jump from one bike or bike type to another without much difficulty. Now days its much different. A mere few millimeters in brake reach and other small things make a big difference...
Quoted: 200 Post(s)
Liked 65 Times
Not exactly. The worst flat bar shifter design was the integrated shifter-brake setup with a single mount. Not only did it give you no adjustability, you were stuck with the package.
I have done this.
John
I have done this.
John
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
It'd be helpful to also know the model # of the shifter/brake beyond just "XTR". Should be on it somewhere.
SE Wis
Liked 3,395 Times
