Handlebar fitment concerns, diameter
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 639 Times
As I was musing in another topic, on my 1974 Zeus track bike project, “It has been 45 years but I am pretty sure the bar and stem came to me together; I knew someone with a Favorit bike and was upgrading one component at a time and I bought these from him. I like the combination of steel and aluminum on the stem, to me it “looks right” on a track bike. Oddly, there is no raised center section on the bars and the stem really does not want to tighten down snug.” Well, between them appearing a bit bent and the clamp-down issue, perhaps I should replace the bars and keep the stem; I suspect I’ll have to hacksaw the bars to get them off. The micrometer reads the bar diameter at 23.7mm, and I’ve only found a couple of websites selling classically-shaped bars (I could use advice on sources) and not much below a center diameter of 25.4mm. Are there other sizes out there? If this is some odd Czech-only size perhaps the bar and stem both have to go… sad.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 1088 Post(s)
Liked 1,205 Times
Maybe the bars are supposed to be 23.8 and it's just a tight fit (or corroded together?). Sheldon's crib sheet says in row 2 that obsolete British steel drop bars would have been sized at 23.8mm at the clamp: https://www.sheldonbrown.com/cribsheet-handlebars.html
Quoted: 987 Post(s)
Liked 639 Times
So I am inclined to locate some nicer bars; perhaps start with a WTB here at C&V/BF? Not tied to a particular brand, maybe GB, or TTT or, hmm, what other brands should I be considering? And I'm right that the only diameter to worry about is at the clamp, no? With all 1'" steerers, the insertion diameter is a constant? That does not sound right, there's no universal diameter for anything.
Quoted: 1324 Post(s)
Liked 927 Times
Is it possible that bar was supposed to be used with a shim?
Cheers
Cheers
Quoted: 987 Post(s)
Liked 639 Times
Hmm, I do have a package of assorted-size brass shim stock I had used for automotive purposes -- if I could being myself to trust such a connection to hold and not slip and the worst moment.
Quoted: 987 Post(s)
Liked 639 Times
Micrometer says about 22mm for insertion into the steerer... common size?
Quoted: 1858 Post(s)
Liked 664 Times
I would say, you NEED to have the ID of the stem handlbar mounting bore and the center of the handlebar OD match. If the bar is too big, the stam clamp should fraccture as you tighten the clap bolt. the bar is too smal for the stem, you will over tighten the clamp screw and possibly never achieve tension. And due to the over tightening, it could still fracture the stem.
When the stem fractures, if you are riding, you will most likely crash and hit the ground, possibly with your face.
There are many sizes for the parts in question, and if they are now distorted, they are already over stressed and hence dangerous. Aluminum does not like to be cold-set.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
I have dated 1951 Reynolds drop bars that are 23.8 and require a shim to fit old GB Hidminium bars. I suspect this was always a thing.
Brass shim stock will work in most any application as will aluminum. I make sure to have any gap or overlap centred in the opening in the stem to prevent stress risers
Liked 927 Times
Bent handlebar? Deep scoring at one of the bends? In retrospect I'd ditch that handlebar and get something else that I could be sure wouldn't fail in use.
Prying alloy stems very much isn't a good idea either as you can easily introduce stress risers.
You really don't want a handlebar or stem failing on a fast ride or in traffic.
Cheers
Cheers
Quoted: 4722 Post(s)
Liked 3,038 Times
Likes For T-Mar:
Phyllo-buster
Liked 2,055 Times
Yes, I meant Hidminium stems.
Quoted: 987 Post(s)
Liked 639 Times
Yes, that was a pretty common English handlebar standard, as 23.8mm is the metric equivalentt of 15/16". I've seen lots of English bars that used a shim to accommodate the stem. My only shim advice is to to not build up the shim with several pieces of stock. Use a single piece of the correct thickness. The more layers between the bar and stem, the greater the chance of slippage.
Liked 664 Times
You got that right! Maybe they bent the bars to shape from straight stock after passing through the stem?
Micrometer says about 24.7mm inside diameter. How do I know? Because...
Upon reflection, I decided that's correct. So, to possibly save the stem, I hacksawed the bars to release the stem. So, my WTB 1.0 is to find bars to fit, my WTB 2.0 would be bars and a stem. Unsure what bars fit a 24.7mm hole.
Presuming I found some 23.8's, to fit a 24.7mm stem means 0.45mm shim. AM i calculating that right at 17.72 1000th's of an inch thick? Less any desired clearance, if indeed any is desired (I'm going through a "clearance crisis" on a seat post now at the same time).
Anything I can try to help with, HMU.
Quoted: 987 Post(s)
Liked 639 Times
Perhaps it is not worth beating myself to death looking for bars to fit this oddball stem which is not original to the frame anyway.
Liked 664 Times
Well, yeah, you have the right io cut your losses.
Quoted: 790 Post(s)
Liked 1,769 Times
Being classic metric the Zeus stuff is true 25.00 but has a bit of wiggle so you may be able to get french stuff to work,
