Tall crown race for 1" threaded steerer
Trying to fit this rim brake caliper to a 700C Rossin track steel fork. The top of the caliper arm overlaps about 2 or 3mm with the crown race bottom so the caliper won't fit.
Before fitting a spacer in the brake bolt to increase horizontal clearance, is there a tall crown race I could install that would act as a vertical spacer instead?
Chris King used to make one for MTB that was 5mm tall but was not able to find one for a 1"/26mm steerer.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Finding a taller crown race that will work with your lower cup could be a chore. Just use a spacer.
Likes For JohnDThompson:
Likes For ClydeClydeson:
Likes For Moe Zhoost:
Quoted: 837 Post(s)
Liked 1,061 Times
Another vote for caliper spacers. I've had similar issues with bikes I've owned and a good solid spacer has worked without any issues. Your local bike shop should have some in stock with the correct tolerances as opposed to getting a sloppy fitting one at the hardware store or stacking washers.
Likes For Crankycrank:
The reason I'm being stubborn against the spacers is that the caliper is mounted in the fork rear. It's a TRP 925 time trial caliper bolted into a vintage fork. So clearance is limited, unlike with a front fork mounted front brake, if that makes sense. Example: //theurbanbike.com/wp-content/uploads/2016/07/trp-RED-FRONT-800x533.jpeg
Quoted: 2026 Post(s)
Liked 1,096 Times
Excuse me if this sounds dismissive but it appears you are trying to mount the wrong brake on the wrong fork.
I like these calipers because being rear mounted on the fork and black, they disappear completely into the 40mm deep black rim
Quoted: 4806 Post(s)
Liked 3,928 Times
Just thinking here - won't a tall crown lessen the steerer above the headtube, lessening stack? Do you have enough steerer showing?
If you find that tall crown race and have stack issues, consider the Tange $8 OEM race and locknut for the top. Super short stack. (Top races don't do very much beyond keep things in line. The best bottom race will probably die before that $8 top.
Which brings me to comment on the classic BF response. Question - "I want to do this. Does anybody know where to get/how to do ....?" Answer - "You're wrong. You should be doing this ..." One of my favorite rides I kept out of BF discussions until it was done because it would have generated pages of those responses.
