For the love of English 3 speeds...
Palmer
Quoted: 1684 Post(s)
Liked 1,846 Times
Sturmey archer fm
I tried this as a separate thread and no one responded.
I have a SA FM that works fine, but is noisy in normal gear. I removed the internals from the wheel, just to see if I could at least see how it works.
I am thinking the primary gear set is likely worn. If so, does anyone stock parts? It doesn’t seem likely that it would share parts excepting planet pins, pawl pins and springs with other hubs.
It seems like noise in normal gear would show up in AW’s as well. Has anyone had trouble with that? Is there an easy remedy?
TigerTom
TigerTom
Likes For bluesteak:
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 276 Times
I’ll put it back together and see how it goes.
With an AW I tighten the drive side down tight and back off 1/2 to 3/4 turn. Then I set up the left side a little sloppy. Is that why the left side doesn’t have the lock washer with tabs?
TigerTom
TigerTom
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 376 Post(s)
Liked 896 Times
The FM and FC hubs are in a family apart from the AW or even the FW hub. They are mechanically different. The drive side cone is set first, finger tight and loosen 1/2 to 3/4 turn. It should not be loosened more than 3/4 turn. Non-drive bearing adjustment is for the slightest play at the rim. It is less tolerant of play than the AW or even the FW. Was there any visible wear on any of the parts when you dismantled the hub?
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Likes For SirMike1983:
On the road
Quoted: 376 Post(s)
Liked 896 Times
Hopefully we're finally turning the corner here into better weather - finally getting some warmth. It seemed like we were ready to start spring, but then got hit with two inches of new snow. It has melted and hopefully that is the end of winter here. I took out the 1959 Traveler yesterday evening while the weather was good.
I took the internals out as a unit, and didn’t make any attempt at further disassembly since I figured it still worked and I wasn’t likely to find replacement parts. It’s 70 years old and likely there is some wear. When I first got the hub before it was built into a wheel, I did resurface the cones with a wet stone.
I did learn a few things. I could see the the secondary planet holder turns the main sun gear when you select the lowest gear. I haven’t been able to figure out the gear reduction that that creates.
I had an ahah moment when I saw the large diameter spring between the secondary and primary gear trains. “ So, that’s what those springs are for that I sent Mike in the trade.”
TigerTom
TigerTom
Quoted: 1866 Post(s)
Liked 665 Times
I read Persig's book while at college in my late teens in the 70's and was mystified by the theme.
Some of it must have sunk in, though at the time I was still shedding the last vestiges of being a callow youth.
Still have the book, but each time I pick it up, I put it down.
I've never found two people who shared the same interpretive experience reading the book,
Between Pirsig, John Muir (How to keep your Volkswagen alive) and the Tom Cuthbertson’s books on bicycle mechanics and being rough and ready when your touring situation demands it, I gained a lot which I still use in mt own mechanistic life, and in my aerospace and automotive engineering career, since college days
Likes For Road Fan:
FreedomRider
Bikes: 1971 Raleigh Sports, 2008 Specialized Sequoia, 2016 Trek Verve 2, 2023 Cannondale Adventure Neo Allroad ebike
Quoted: 24 Post(s)
Liked 234 Times
I'm planning a coastal tour on my Raleigh Sports 3-Speed this coming weekend .... I'll update this forum with my travel log. Will be touching 3 States ...
Likes For bharrisonb:
On the road
Quoted: 376 Post(s)
Liked 896 Times
This morning before I read this post I reinstalled the internals and set the hub up without as much slop. I took the bike for a spin and it is definitely quieter. Although there is still extra noise in normal gear.
Bikes: Vintage Raleigh and more modern Roberts
Quoted: 55 Post(s)
Liked 158 Times
Here is a new one on me and the seller who gives plenty of background say possibly unique a Hobday Brothers 3 speed, too far away from me luckily, I am not sure I have room for another.
https://www.ebay.co.uk/itm/326085113828
Likes For Small cog:
Likes For adventurepdx:
On the road
Quoted: 376 Post(s)
Liked 896 Times
The week before we had two days that made it up over 60. Of course the weather calls for "cold and rainy", and the two inches of snow at the end of the storm strike as an unpleasant surprise. Two steps forward, one step back in April around here...
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1301 Post(s)
Liked 942 Times
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Likes For 1989Pre:
Standard Member
Liked 942 Times
First ride of the season. The boat launch is always my first. Brought some lunch and my new mini-binoculars, but all I saw was herring gulls. Nice spot. Sunny, breezy. 60F https://www.mapmyride.com/workout/7877989039/
Ready for a sandwich of salad greens and tahini.
Had to put a piece of bark under the kick-stand to stabilize the bike.
You can see where the high-tide line is. Tide was coming in.
A pier behind someone's house
Phyllo-buster
Quoted: 2299 Post(s)
Liked 2,059 Times
Likes For clubman:
Standard Member
Liked 942 Times
Likes For 1989Pre:
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1030 Post(s)
Liked 444 Times
1972 Superbe
I've not had this one out for several years but needed to cart some stuff downtown
I was having a hell of a time in third gear and
thought I must be getting old....
Most of my bikes have 19/20/21T cogs
and I thought the original cog on this one was an 18.
I was very surprised to find this one had a 17T cog.
This bike is very original with all of it's "R" nuts etc so
I've always assumed the back cog was original as well.
Likes For gster:
On the road
Quoted: 376 Post(s)
Liked 896 Times
Beautiful, warm evening here last night. I took this 1957 Schwinn Traveler three speed for a ride.
Not lost wanderer.
Quoted: 890 Post(s)
Liked 1,017 Times
Likes For bwilli88:
Need some wisdom. Where would l find a replacement fork? Yes, I need the steering tube length. Wheels good. Bike a good size as a commuter which my son is doing in Portsmouth NH. Wanting some tips or wisdom to find the parts to put her back on the road. AW hub reads 70 5 so a 1970 era bike. Used to be easy to find parts at the dump. Less so these days. I must assume straightening the fork is not an option?
Decided I needed to take it apart and measure the exact length of the fork steerer tube. 205mm. Now the hunt begins. It also let me see the rest of the frame naked and whether there were any bends I missed. Just the stem and the fork... I need to reacquaint myself with where or if there is a trade forum. It would be nice to put this 1970 Sports back into use. PB soaking into the cotters. Then a deep clean.
Thanks for any suggestions on where I might locate obsolete parts.
Likes For AD-SLE:
On the road
Quoted: 376 Post(s)
Liked 896 Times
You're lucky the frame is not damaged from whatever caused the damage to the fork. These forks are often fixable but I think yours is toast because the bend is so severe. I'd try to find a direct replacement in coffee paint, keeping a close eye on eBay. Your measurement sounds right - a 23 inch Sports frame usually has a fork steerer tube of around 8 inches. You should be able to eventually find a direct replacement - 1970s era coffee bikes with 23 inch frames still do turn up. I haven't seen anything like this at the dump or thrift shops in quite a long time. I'd keep an eye on eBay or Facebook Market. I'd also put out a Want ad here in the C&V market forum.
Bikes: Several
Quoted: 74 Post(s)
Liked 168 Times
Good luck with your project bike.
Noticed you gave the stem a metric measurement.....
These bikes were built to Imperial dimensions; you may find using feet and inches will always take you to an exact fraction of an inch.
Quoted: 3819 Post(s)
Liked 6,752 Times
Another issue on looking for a replacement fork: You might find a temporary substitute while you wait for a coffee brown one to show up, but keep in mind that the threading on these was 26tpi, so the existing headset cups won't work on a more easily found 24 tpi fork streerer.
Likes For nlerner:
