Fitting Narrow Tubeless Tires, I know Not Tubeless Again
Bikes: Custom Ti Gravel Self built Force AXS 1 X 12, Allied Cycle Works All Disc Force AXS DT Swiss 1400 Spine, Santa Cruz CC XTR
I'm thinking about see how my Gravel Bike will ride with some faster tires. So I've just completed the front wheel. Put a Conti 5000 TL on 28mm and tried to air it up sans Sealant.
Not a chance. I've been able to get other road tires seated with minimal sealant.
The rims are WTB i21's. They seem just a bit wide for a 28mm. Maybe go to a 30mm.
Anyhow, Just curious about others experience with narrower tires setup tubeless.
BTW: I've got 28mm Hutchinson's on my road bike mounted to DT 1400 Carbon rims. They went on with no effort. Gravel bike currently has Hed Belgium/DT Swisww 240's running tubeless 37fr/35 back. Building mistake, can only get a 35-37 on rear depending on tire.
First Titanium frame built at Unite Bicycle Institute.
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Sorry if this is obvious but did you try mounting the tire with a tube first, then breaking the bead on only one side to get the tube out, install the valve? Much easier to seat just one side.
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
Did you use a compressor or just a regular ole' pump to try and inflate?
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
I install my 5000 TL's dry using just a track pump (really old Joe Blow) but I do it the first time with the presta valve core removed and no sealant.
Once it gets past the snap crackle and pop of seating the bead, I can deflate and inject sealant before replacing the presta core.
To inject sealant, I have a syringe with the fine spray extension tube that comes with Canned Air attached to it.
I think some oils and lubes come with a similar tube.
I like this setup, because when it comes time to check the sealant level, I can suck it back out again without having to break the bead.
Barry
Barry
mosquito rancher
I've followed the same routine as Barry2. I think some of this comes down to luck: the fit between a specific tire and rim, and manufacturing variations between tires. At this point, I've fit a total of four 28-mm Conti 5000 TLs onto the same pair of wheels. Three of them went on without too much effort. One of them was an absolute bear to get on. But they all inflated with my track pump pretty easily--I had more trouble getting the valve seal tight.
Adam Rice
Adam Rice
Thanks, I'll give that a try.
