Tire pressure 23mm v 25mm?
Bikes: Rossetti Vertigo
Quoted: 229 Post(s)
Liked 119 Times
I've always ridden 23mm tires, but am giving 25mm a try. My 23s are always pumped up to 110psi. What is the preferred psi for 25s? I am about 195lbs.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4390 Post(s)
Liked 3,016 Times
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Quoted: 2333 Post(s)
Liked 2,097 Times
I run 89 psi F/R. 25 mm GP5000
My TT front wheel is 23 mm and I run it at 100 psi
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
If you want the same feel run 10psi less per jump up in tire size. 110 is too much in a 23, I'd start at 90ish for the 25mm tires, and depending on your bar to saddle height relationship adjust the front down some the higher the bars are.
Likes For cxwrench:
Quoted: 766 Post(s)
Liked 1,739 Times
When I run 25, my front is 90 and rear is 95 and I range between 190 and 200. Depending on what kind of ice cream I buy
Likes For jaxgtr:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I'm ~200lb and was running 90/100 on my 23's until last year when I switched to 25's and dropped to 80/90. They're doing great with a much smoother ride.
It's like riding a bicycle
Quoted: 338 Post(s)
Liked 408 Times
Roughly 72kg, the roads around here vary, but are mostly decent, running everything tubeless now with airliners (a chore to fit, but brilliant) on some 19mm internal rims.
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Here's another guide https://silca.cc/pages/sppc-form
Quoted: 229 Post(s)
Liked 119 Times
Quoted: 8280 Post(s)
Liked 9,041 Times
We have some really beat up streets here and I don't notice a huge difference in the ride except on chip seal where the 25s do feel smoother. I'm under 200 pounds now but had been 220 for years.
Quoted: 389 Post(s)
Liked 255 Times
When I raced criteriums on smooth surfaces, I weighed 220. I used 23's on Mavic O4CD's and ran 140 front and rear according to my Silca floor pump. Now I weigh 210 and with 25's it's 115 rear 110 front. (still on narrow rims).
Quoted: 229 Post(s)
Liked 119 Times
I used 23s on everything for 30+years and always 100/110. Last year I switched to 25s and lowered the pressure a bit, 95/100, but don't like a squirmy feel.
Likes For pgjackson:
Quoted: 4560 Post(s)
Liked 2,802 Times
I favor the lowest recommended pressure, but I weigh 150 so pinch flats aren't a risk unless I run over a brick... which I've actually done once to dodge being pinched by a couple of trucks that bottlenecked me.
Mostly I favor lower pressure because our default pavement is the coarsest chipseal I've ever seen, more like railroad ballast in epoxy. With an old neck injury that stuff is painful to ride for long with high pressure skinny tires.
Also depends on the tire and tube. With latex tubes and good tires I can run slightly higher pressure and still feel comfortable on our coarse chipseal.
Generally with 700x23 and x25 tires I use around 60-75 psi front, 75-90 rear. Depends on the tire, tube, and my mood. Sometimes I'll start with slightly higher pressure, then stop and bleed off some air during the ride if it feels too harsh. I try to avoid running pressure so low that it feels mushy or imprecise on fast curves.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Did you use the measured tire width at the pressure? I have GP5000 tires on 25mm inside width rims. Front is a 25mm and rear a 28mm. At pressure the front is 29 to 30 mm wide. The rear is about 31mm. So I run 80 rear and 75 front for me at 230 lbs me and bike.
Quoted: 338 Post(s)
Liked 408 Times
25mm internal width rims are unusually large for road rims, though, so that's really quite like having a tire size up - if not a slight bit more - over a 19mm internal rim which is probably around what most people have on their road bikes.
Quoted: 229 Post(s)
Liked 119 Times
I don't want to get that scientific about it. The front tire says its a 23 and the rear says its a 25. That is close enough for me.
Quoted: 270 Post(s)
Liked 447 Times
Just means you can work your way down to smooth it out. At least until you get a pinch coast. With 19.5 mm inside road wheels (which I have planned for my disc brake bike) anything less than 90psi for. 23mm GP5000 and I’d get a pinch flat. Then I’d run 110psi.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1252 Post(s)
Liked 1,284 Times
Yep, ^^^that's the rule of thumb I've been using for years.
fwiw when I first started serious [sic] road cycling >15 years ago I was pumping 23s up to 115 or sometimes even 120psi (!) I quickly learned that the ride was much nicer at 110psi...and then after a few years of that, found that 100psi seemed to offer me the best combination of comfort, performance, and road feel.
(Amazingly I have been ~175lbs for the entirety of all ^^^those experiments. And still am, knock on wood.)
So yeah, my 23s are at 100psi, my 25s are at 90psi. Been like that for about a decade now.
Likes For Bob Ross:
Quoted: 229 Post(s)
Liked 119 Times
First ride with the new set up yesterday. Front a 23 and the rear a 25. Both at 100psi. Ran really nice. Might try dropping the front down to 90-95.
Quoted: 5224 Post(s)
Liked 3,581 Times
I used to go by feel, but now I use a gauge. I run the front a little lower than the back. I'm 225 lbs & I run my 25mm road tires approx. 80-90 psi front 90-100 psi rear. I switched from 23mm tires a handful of years ago & don't remember stressing about exact pressures, going from one size to the other. from what I've read, personal pressure choices are not a precise requirement. meaning it's up to the individual rider, bike & tires. but I think a light guy compared to a heavier guy like me, would be happy w/ lower pressures than what I use, all other factors being equal, which of course, they would never be. good luck finding your equilibrium!
