Found a Garmin Edge 500 on my ride today, cracked screen/LCD. Any hope for it?
GO, Mordecai!
I came across a Gamin Edge 500 on the road today during my ride. No one else around. Looks like it was either dropped very badly or it was dropped then run over with something.....
Some cracks in the glass on the top, and the LCD is shot. All rainbow colored.
First of all, did anyone lose a Garmin Edge 500 today in NY outside the city?..... if I can return it to the original owner, that would be ideal, but like I said, no one was around. If not.....
I plugged it in and it still seems to power up. Has anyone dealt with Garmin to get a new screen, or found a 3rd party supplier of screens I could install on my own?... Not sure what Garmin will say since I'm not the original owner. Maybe they'll replace the screen for a price... calling them later today but didn't know if anyone had experience replacing Garmin screens.....
Thanks
Thanks
GO, Mordecai!
I don't know much about them, but this just dawned on me: is there a way to plug it into my computer and read any info off of the device? Maybe I can find the original owner that way? I plugged it in but it doesn't show up as an external device.
moth -----> flame
Bikes: 11 CAAD 10-4, 07 Specialized Roubaix Comp, 98 Peugeot Horizon
An Edge 500 should show up as a USB hard drive. If your computer doesn't show that, it may be toast.
You could try calling Garmin customer service and read off the serial number, they might be able to help contact the owner.
BF, in a nutshell
BF, in a nutshell
SkinnyStrong
good idea. You could probably get the GPS data off of it, then put up "Found" posters on the street where the ride originated. Or just go door to door.
GO, Mordecai!
Any thoughts on how I'd get the GPS data off of it?
Maximus
You need some software for the computer to recognize the device
https://www8.garmin.com/products/communicator/
GO, Mordecai!
Bikes: 2010 S1, 2011 F75X
Go to garmin connect website, upload the ride to it and it'll show exactly where he lives - assuming he pressed start in his driveway
GO, Mordecai!
no leads yet... I'll call Garmin.
Thanks! This was what i was looking for. However, looking at what comes up, there are only 2 recorded rides on it. One from 3 days ago and it's only 2 seconds long... with no distance traveled. And one from a little while ago when I must have pressed the start and stop buttons while tinkering with the device....
I'm not 100% sure about 500, but I took apart a 305 a few months ago. If 500 is built the same way, it should be straightforward to open it and to remove the cracked LCD. If you can find a dead 500 with a functioning LCD on Craigslist or eBay (or even here), you should be able to swap LCDs and glass screens. Then you'll just need to re-seal it carefully (use superglue, take care not to get any on the outer surfaces) and you have yourself a working unit.
If you can't find the owner and you can't get it fixed, I'll take it off your hands for $20.
GO, Mordecai!
Even if no distance was traveled, it should still contain GPS coordinates of where it was started.
This is all I see from that ride 3 days ago on Garmin Connect. I don't see any maps or any where to look at GPS coordinates... sorry, not familiar with the interface or if it is supposed to look different. Any hep here?
moth -----> flame
or it's just that they (or you) accidentally hit "start" without having achieved a satellite lock. It's less than 2sec so clearly not deliberate.
Honestly, I find the trying to dig into this persons' GPS files a little creepy; just call Garmin and if they can't help, I'd adopt it and get it fixed.
BF, in a nutshell
BF, in a nutshell
GO, Mordecai!
Perhaps.... If I I turn it on, press the start button, just have it in my pocket and go walk around the block with it, should it record my "ride?" Maybe that's a better way of seeing if it still works?...
SuperGimp
When you plug in the garmin, it shows you the serial # of the unit. I know I registered mine when I set it up as part of logging into garmin connect - surely Garmin can do a little legwork for you.
GO, Mordecai!
moth -----> flame
I've had to call Garmin support for a few different issues over the years, I just think that will be more definitive than trying to examine the other persons activity files.
BF, in a nutshell
BF, in a nutshell
Liked 5 Times
It should show up as a mounted USB drive or two. Under the directories "Garmin/History" on one of the drives you should see some TCX files along the lines of "YYYY-MM-DD-HH-MM-SS.tcx".
GO, Mordecai!
Tried out the garmin walking around town a bit. Tried to manipulate it to start tracking my "ride" without actually being able to see the screen.... was able to have it show up on the maps when I got back. Seems functional!
Just need to get a working LCD in there now....
Bikes: 2007 Trek Madone 5.9 (Shimano DA), 2008 Kuota Khan (SRAM Red), 2009 Giant OCR2 ( Shimano 105 ), Lynsky R340 ( SRAM Rival )
Actually you need to call Garmin customer support, give them the serial number, and let them contact the rightful owner. It is registered to the owner, and you really can't use a GPS once they realize it is missing and report it, Garmin will shut it down. I would of reported mine, had I lost it, to prevent exactly what you are doing... stealing.
Roadkill
Bikes: 2002 Lightspeed Classic; 2010 Pedalforce RS
Garmin will replace/fix the the unit for a cost, there is no spare parts.
I had a similar incident with my 500 (run over by car), they quoted me $89 for a replacement (as near as I can recall). They took pity on me and reduced the price since mine was nearly new. Good folks at Garmin.
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
