KMC quick link question
Old 05-28-23, 03:12 PM
zandoval
zandoval's Avatar
Quoted: 970 Post(s)
Liked 1,632 Times in 1,048 Posts
Originally Posted by jadmt
...not sure what you mean dropped it on the ground and it came apart? If you were taking it off it should have been apart? If it were together on the chain how did you drop it on the ground? maybe I am not understanding what happened thanks
The Pin came out of the plate on 1/2 of the link. I was really surprised because up till that point I really saw no reason not to reuse them. On checking my other bicycles I found two loose pins as well. One of them was a KMC and the other a generic knockoff. I don't remove my chains very often so using a new link each time is not a big deal. If I were removing the chains more often, like when Waxing, then I would invest in Brand Name Shimano quick links...
zandoval is offline
Likes For zandoval:
Old 05-28-23, 03:30 PM
Jeff Neese
Quoted: 1084 Post(s)
Liked 687 Times in 441 Posts
Originally Posted by cyccommute
Pins require a tool as well. If you are using replacement pins from Shimano, you are probably okay. If you are pushing the pin out and re-installing the pin on just about any modern chain, you are risking the chain pulling apart. Even a single use quick link that has been use more than once won’t pull apart resulting in a broken chain. The link may be easy to pull apart and can be done without tools but it won’t pull apart under load like a pin that has had the peen removed can.
Exactly. If a quick link requires a tool also, I may as well just stick with pins. I already have a good chain tool for the bench, and my multitools all have a chain tool. I only use Shimano chains and brand new pins, and always carry a couple of spare pins in my bag. Like you pointed out, pushing the pin out and back in is a recipe for failure.
Jeff Neese is offline
Old 05-28-23, 03:54 PM
Garthr
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 117 Post(s)
Liked 209 Times in 127 Posts
Yes, not all quick links are single use. They make both types. All of the KMC X8, X9 and Z series links I've used are re-usable and it's stated on the packaging. Same with SRAM PC-830/50/70 and PC-950/51/71. Wippermans Connex link also.
https://www.kmcchain.com/en/teach/missinglink
https://www.sram.com/en/sram/models/cn-plnk-9spd-a1
SRAMS have remained consistent in their actuation since they've been around. KMC has varied. Yes, I concur that it's not a great feeling to connect the missing link and it goes together with little effort. Their links they included in a box of 25 X9's however were different, they were so tight I couldn't get any one the together by hand and I had no quick link plier as I never needed one. KMC ended up replacing them, but the new ones weren't much better so I bought a Bikehand quick link plier and that worked. I don't really bother taking chains off one installed anyways as I ride the factory lube as long as I can, with consistent chain wipe downs. Then it's WD-40 and consistent wipe downs for the life of the chain. Been there done that with the religious chain cleaning thing.
Garthr is online now
Old 05-28-23, 05:26 PM
sweeks
sweeks's Avatar
Quoted: 981 Post(s)
Liked 584 Times in 401 Posts
Even the ones that *theoretically* require a tool can be opened with a piece of brake cable (see
for the general idea). There are many variations on this theme using shoelaces, dental floss, paper clips, etc. There are many other ways to do it using ordinary pliers. Since the most likely scenario is taking the chain apart at home for routine maintenance, an inexpensive link pliers probably isn't a terribly radical idea. I like having the ability to do chain service anywhere, so I carry a small Wolf Tooth tool with a couple spare (used) quick links in it. I've only ever used it (away from home) to fix other riders' chains.
sweeks is offline
Old 05-28-23, 06:31 PM
smd4
Quoted: 3515 Post(s)
Liked 2,929 Times in 1,777 Posts
Thanks for that. That's the ease of use I'm looking for. I ordered one from Amazon and I'll try it on my next chain.
I love mine. I honestly wonder why people use anything other than Connex.
smd4 is offline
Likes For smd4:
Old 05-28-23, 07:32 PM
sweeks
sweeks's Avatar
Quoted: 981 Post(s)
Well, to be fair, unless you always buy Wippermann chains, you'll have another kind of quick link to use up.
I *do* agree with you about Connex though... the spares I carry are all Connex.
sweeks is offline
Old 05-28-23, 07:36 PM
smd4
I only use Dura Ace chains.
I’m really surprised at the cost difference for Connex links between different speeds. The 9 speed version that I use is $4 or $5 bucks. For 11 speed they’re at least $25!!
smd4 is offline
Likes For smd4:
Old 05-28-23, 07:47 PM
sweeks
sweeks's Avatar
Quoted: 981 Post(s)
I'm arrested at the 9-speed stage... this makes me feel somewhat good about that!
sweeks is offline
Likes For sweeks:
Old 05-28-23, 07:54 PM
smd4
Same.
smd4 is offline
Old 05-28-23, 08:44 PM
gkamieneski
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times in 62 Posts
One thing to consider is the proliferation of counterfeit KMC chains. I think this is especially true for the X10 10sp model. Possibly this could be a reason for a problem with the quick links.
Best to search on this topic and learn how to reveal a counterfeit KMC chain. Two of my X10 chains I was preparing to install both shook out as fakes.
gkamieneski is offline
Old 05-28-23, 10:16 PM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Liked 119 Times in 92 Posts
Good point. I was following a BF thread about the counterfeit KMCs. It's hard to imagine enough profit being made from a lowly chain, but I assume the bad guys rely on volume.
MudPie is offline
Old 05-28-23, 10:17 PM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
At that rate, I'd hate to see the cost for a 12-speed version (if they offer one).
MudPie is offline
Old 05-29-23, 01:26 AM
daniell
Quoted: 200 Post(s)
Liked 65 Times in 42 Posts
I think that in respect to SRAM chains, the quick link can be used multiple times on their chains 9 speed and below. Ten speed and above, they are one time use.
daniell is offline
