Better quality rear axle for 6 speed
Howdy all.
I just picked up a gorgeous Raleigh Alyeska. The rear axle is slightly bent and while a piece of wood and a mallet will make it better short term I would like to find a better quality replacement. Amazon have quite a few in the $10 dollar range but I'm hoping to find something that is actually better, not just more expensive.
Quoted: 4212 Post(s)
Liked 3,883 Times
Don't waste too much of your time and money on a "stronger" axle. The issue is not axle strength or stiffness but the imbalanced loads that a freewheel hub places on the axle. Since the driveside bearing is closer to the frame's center it sees greater forces and the axle will bend at the cone's inner point. Where is your axle bent?
Sometimes the frame's drop outs can be non parallel to each other and places a preload bending on the axle before any road shock is even had. The industry solution to the freewheel bent axle problem is the cassette/freehub with it's better axle bearing placements. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
I built the wheels on my Trek 720 with Shimano mountain bike hubs. I would like to keep this particular bike original just for fun.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
Look for one on eBay by Wheels Manufacturing.
Likes For SurferRosa:
When I was looking around those popped in the more expensive category so the question is, are they actually better?
Another option I was looking at are Campagnolo branded axles. I would think campy would source better quality ones.
Quoted: 540 Post(s)
Liked 416 Times
Performance axles are often made with less metal for less weight.
The steel axle found on all big box store bikes as yours is perhaps stronger than all aftermarket axles. I mean, it's steel.
The axle bent because of an accident/trauma/brute force.
Your short-sightedness in thinking another axle will prevent it from happening again is wrong.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Wheels mfg
Likes For dedhed:
Likes For Crankycrank:
Liked 3,883 Times
Having installed on customer bikes many (dozens by now?) Wheels of Boulder (their original name) axles and used quite a few in my Campy hubbed bikes I can talk about real life results. Their axles bend and break too, just like the OEM Campy axles that those hubs had and just like the more common axles found in so many bikes. I can't count how many customers have sought out the same need, an axle that won't bend/break only to have them come to the same conclusions as I speak of. Good luck with your situation and if you do find that holy grail please do let the world know. Andy
AndrewRStewart
AndrewRStewart
señor miembro
Liked 6,491 Times
Well, when things break we replace them. That's not "short-sightedness." In all my years of riding freewheels, I've only broken one hollow axle. And that was on my 1975 grocery getter with a rear load. I replaced the vintage axle with a brand new one.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Liked 3,883 Times
soyabean and SurferRosa are talking about two different things.
soyabean is talking about how stuff works and how that stuff reacts to situations/forces.
SurferRosa is talking about doing a repair.
Both can be right at the same time but not understanding the cause and effect of how freewheel axles bend is a path to repeating the problem. In my world doing the same repair again and again is not the best way to service a bike. Andy
AndrewRStewart
AndrewRStewart
Liked 739 Times
search: "Wheel Master Rear Axle" on Ebay... they sell Chrome Moly solid axles that will fit your application... one issue tho.. there are a couple different Thread Rates involved.. you will need to know the length, thread pitch and diameter of your axle to exactly match the new axle to the nuts and cones ... yours is most likely a 10x1mm x185mm length... but there are no guarantees of this.
the size differences are very small...there are 3/8" axles, 9.5mm axles, and 10mm rear axles... all of them use very similar Thread pitches too... The wrong parts will often start to thread, then begin to bind up and ruin threads.
Also.. be aware that No thread is ever cut to full height or depth... The "10mm" axles will typically measure about 9.7 or 9.8mm, etc...
Likes For maddog34:
Folks, this is not some misguided attempt at searching for an indestructible axle that would be better than a cassette hub. I know the limitations of freewheels, there is still nothing wrong in hoping to source a better part if one is available.
Likes For abdon:
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Had a couple of the original wheels of boulder axles in my bikes. One was in a set of suntour sealed bearing hubs, the other was in a bendix 70 hub. They were better than oem by an exceptional amount
The biggest change you can make is to get your butt off the seat and have your knees bent to absorb the shock your axle gets if you don't.
Likes For Schweinhund:
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
or build a new wheel properly dished with a Phil hub, confirm your dropouts are indeed parallel, and life is good.
hey abdon , I bet I got a Campy axle I will sell you for about 15 buck plus ship, I cannot promise the cones you have will thread onto it however.
I would suggest the Wheels Mfg parts as well, they are chrome moly, And as Schweinhund suggests, unweight when you hit a bump
/markp
/markp
Liked 739 Times
for those that responded with not one clue.. me included.... https://www.sheldonbrown.com/retrora...h-alyeska.html
the bike is well worth an bit of investment... and it's certainly no Box Store Special.
The stock rear hub is a QR'd Sansin RE-50... if that is no longer on the bike, then we all needed even more info, but some chose to attack box store bikes instead.
personally, i assumed it was a solid, nutted axle...
my apologies to Abdon.. and thank you for saving a cool old touring bike!
Liked 3,883 Times
"I have to take customer reports with a grain of salt. It's uncontrolled and you were not there to observe." Schweinhund
Yes and no. When one helps out the same customer with the same bike with the same problem over some time and gets to see the follow ups on the hoped to fix(e but didn't "last") and you had told them the repairs were not all that was needed but they bought the parts and did the work themselves and they come back... I think I can claim some knowledge about their hopes and choices, and the situation. Andy
AndrewRStewart
AndrewRStewart
Really Old Senior Member
You haven't proven diddly to me.
BTW- Did you notice Andy builds bicycles?
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
I appreciate Andy's knowledge more than yours too.
I offer what I have experienced as anecdotal information, take it leave it whatever I really don't care.
Know what I do know? I personally purchased Wheels of Boulder axles years ago. I did it for the coaster brake motomags I had on my super stroker. I kept bending the oem axles., Wheels of Boulder cured that.
Andy may have had a hundred returns, but until he bends it himself, it's what the customer said happened.
Sorry, but this is the case.
BTW, I've built a few bikes myself.
I love touring bikes. The geometries are ridiculously comfy and incredibly stable thanks to the angles and much longer wheelbase. My Trek 720 feels better when it has a good amount of weight loaded onto it, this one feels great unloaded and I have every reason to believe that it would behave just great fully loaded.
Liked 739 Times
Quoted: 3515 Post(s)
Liked 2,929 Times
Likes For smd4:
Quoted: 981 Post(s)
Liked 584 Times
I still have the original rear axle in the 10-speed (2 x 5, with a freewheel) Motobecane I bought in 1975. I weigh 200 pounds. A replacement axle might last the OP indefinitely, barring an accident or pothole.
Likes For sweeks:
Liked 2,929 Times
