The Newest and Most Improved Hot or Not
#1776
Quoted: 9653 Post(s)
Liked 6,365 Times
That looks pretty sharp for an older frame...mostly. Cranks aren't level, stems aren't accurately aligned in a vertical position, and you didn't quite get to biggie-smalls. Personally, I think a triple doesn't look right on a racy bike. I do like the color coordination of the seat post clamp to tie in with the non-original fork.
The background is one of the most important parts of a photo composition.
#1777
Habitual User
Quoted: 4947 Post(s)
Liked 8,089 Times
Nah. Bam's kid is a bike stud. She gets some slack.
#1778
Quoted: 10237 Post(s)
Liked 5,184 Times
I would love to put a new groupset on this. Preferably a 1x since it’s my crit bike. But it’s not in the cards right now. The next big purchase would be some Zondas for it. The triple is ugly but it works.
I know the staging is off, Didn’t take the picture for this thread, but oh well. Before I remove the wheels I will take a better one. Picked up a new cassette today so will be putting the mavics back on it.
#1779
Habitual User
Liked 8,089 Times
#1780
Liked 5,184 Times
#1781
Bikes: Shmikes
Quoted: 10171 Post(s)
Liked 5,866 Times
#1783
Habitual User
Liked 8,089 Times
Assuming you can block out the little ring...
2x - To remove the little ring, you will have to pull the crank arm off the bike, but it's pretty easy (8mm allen key, and fair amount of torque). The ring is attached to the crank arm with a different set of bolts than the other 2 rings, so no new parts are needed.
1x - Same as above, you will need to pull the crank to get the little ring off, and (as Mo said) a set of shorter chainring bolts will be required for a single chainring. They are easily found on the magical intarwebz. Install the big chainring in the spot where the middle ring is now. Remove the front derailleur, cable, and housing. Win!
#1784
Liked 5,184 Times
2023 Emonda Alr 6
Likes For bampilot06:
#1785
Quoted: 18416 Post(s)
Liked 15,555 Times
#1786
Liked 5,184 Times
#1787
So it is
Quoted: 11402 Post(s)
Liked 4,759 Times
Likes For LAJ:
#1788
So it is
Liked 4,759 Times
#1789
Quoted: 682 Post(s)
Liked 453 Times
I was going to post my Madone SLR8 but it’s identical to Noctlilux the millionaire’s on page 1 (except he even added the much more expensive XXX rims). Still love that Rage Red 3 years on with a few dinks. Ah what the hell, I guess without the DA crank it’s different;
Yes it has gained a bottle cage (colour matching the Trek logo) since that first test ride and the newer Garmin doesn’t need a lurid green case to stop the buttons rattling.
#1790
Liked 5,184 Times
Then you will just love my checkpoint, once I get that done.
#1791
So it is
Liked 4,759 Times
#1792
Quoted: 3241 Post(s)
Liked 2,512 Times
Likes For seypat:
#1794
TIME ALPE D'HUEZ (disc)... hot or not?
I built this up about a week ago to replace my all-around / long-distance / ultra-endurance bike that was hit by a car (with me on it ). It's marketed by Time as a climbing bike, but the geometry works very well for long-distance / ultra-distance. The bike was built up from a frameset (purchased new from Time), and I'm really happy with the results. I know some folks will be turned off by the aerobars, and that's fine (I've got a thick skin ). It took me a while to warm up to aerobars, but for long-distance and ultra-distance they are a necessity.
Here's the spec:
- Time Alpe D'Huez framset (size small)
- Bontrager Aeolus RSL 37v wheelset
- Shimano Dura-Ace Di2 12-speed groupset
- Pro PLT Ergon carbon handlebar
- Deda Elementi Superbox DCR stem (100mm)
- Deda Elementi Superleggero 0 degree carbon seatpost
- Speedplay Zero pedals
- Profile Design 43 ASC carbon extensions / Profile Design Nesonic bracket
- K-Edge Wahoo gravity top cap computer mount
Here's the spec:
Likes For Turnin_Wrenches:
#1795
Quoted: 4806 Post(s)
Liked 3,929 Times
#1796
Habitual User
Liked 8,089 Times
Nah. Low is "pro".
#1797
Habitual User
Liked 8,089 Times
Here's the spec:
Here's the spec:
Your cranks are also not level, and the bike is at a wonky angle
Likes For Eric F:
#1798
So it is
Liked 4,759 Times
Here's the spec:
Here's the spec:
That said, I'm actually surprised on the white tape and saddle on an ultra-endurance bike, as it most assuredly needs more work to stay white. I think it looks good if I squint my eyes and erase the aerobars.
It's hard to throw too many rocks at ultra-distance stuff, in my opinion. Janie Hayes could put up a Schwinn Debbie, and it would get a hot from me.
Likes For LAJ:
#1799
... you guys really do hate aerobars. All good, no offense taken . I was also not a big fan of how they looked before I started using them. Over time I've grown to like the look because I love the function and comfort they provide. Can't do ultra-distance (very well) without them... unless you are Joe Barr. I still don't understand how he does it without the aerobars .
#1800
So it is
Liked 4,759 Times
