Suspension corrected
Bikes: 2012 Fuji Traverse,
Quoted: 5 Post(s)
what is meant by "suspension corrected"? Does it just mean a rigid fork?
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
It is a rigid fork with added height to yield the same or similiar head angle as a sagged suspension fork.
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
Yup, it's a term to describe a bike (currently with a rigid fork) with the proper geometry to equip a suspension fork if desired. The frame and fork are taller.
You can usually tell because there will be a couple inches of dead space between the tire and fork crown on a "suspension-corrected" rigid fork.
A frame/fork that isn't "suspension-corrected" would get its geometry messed up if you put a taller suspension fork on it.
Quoted: 685 Post(s)
Liked 55 Times
I used correction to my advantage once. Bought an old 26er frame designed for 80mm travel. Put on a rigid fork corrected for 100mm travel. The resulting slightly slacker head angle has made the bike one of my all-time favorites.
Quoted: 454 Post(s)
Liked 104 Times
For modern bikes (post 2000) it's not really applicable, as frames were designed for suspension forks initially,
Quoted: 685 Post(s)
Liked 55 Times
Mine was merely a 20mm difference. 2004 Gary Fisher frame that was originally built with an 80 mm fork. I don't like to stray too far from the original design parameters.
Quoted: 167 Post(s)
Liked 5 Times
Most bike upto the mid/late 90's technically need suspension corrected forks, as they were designed for 40-60mm forks, but as #JonathanGennick experienced, it often made the bikes handle better by sticking a slightly longer fork on than originally spec'd.
Some modern "in-betweener" or "adventure" bikes are offered with sus-corrected forks, and some aren't. For example, I understand that the 1G Salsa Fargo was not sus-corrected, where the 2G Fargo was (due to customer request).
Imperton
Bicycle Mechanics
1
04-11-13 06:45 PM
griggsaks
Mountain Biking
9
11-20-11 11:11 AM
