Calipers/Rim Wear
Calipers/Rim Wear
I see lots of posts of folks getting vintage or used bikes and wondering about rim wear. I have a set of calipers that are cheap and do a good job. I have yet to find a really worn rim in an old bike. Most bikes seem to die of weather, poor maintenance, or general disuse. That said, a pair of these are nice if you are not sure of a vintage rim.:
https://www.amazon.com/Stainless-Iwa.../dp/B0087HKWCO
Quoted: 4210 Post(s)
Liked 3,875 Times
Machinist's calipers are not needed for detecting brake track wear. A simple straight edge that can be placed across the brake track to show concave wear works well enough. Does the concavity increase with inflating the tires? If so then the rim wall thickness is too little to support the air pressure and the rim brake track's upper/outer "half" flexes outwards. Time to replace the rims. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
Bonus points for using the word “Concavity”.
Quoted: 4806 Post(s)
Liked 3,932 Times
And to those who and seen blown rims at the local bike shops (sometimes with the bike and resulting damage. I look at my winter bikes' rims and make a call in the fall as to whether I feel sure it is good till spring. If not, that rim gets replaced, A little early is far better than having a shard of aluminum ripping open my calf.
Here in the Pac NM we have lava dust that simply eats rims. (Most of Oregon is sheathed in lava. I'd love to see a study of what lava types have what abrasive properties and where those lavas are, but the pressing need for that info isn't reaching the right people. ) Fortunately for me, I get around this dilemma the easy way. I love building wheels! Those volcanoes put me in a good place.
Now there's an easy way to make wheels safer after extreme brake wear - replace the rims with tubular rims aka sewup rims. Now, it you wear clear through the sidewall, the rim gets quite weak and will dent in easily on small pothole edges but the sidewalls still will never blow out and your tire stays inflated and ridable. (I rode a pair of wheels 17,000 miles out of Seattle. Collapsed the rear rim on a pothole. Looked and saw so much brake wear you could have read a newspaper line through the brake track. But the tire didn't care so I just bumped the 10 miles home.)
Quoted: 980 Post(s)
Liked 582 Times
This rim is getting ready to fail... it won't be pretty! Brake is thumping.
Liked 3,875 Times
"Nothing was less than 1.8-1.9 mm wall thickness." etherhuffer
Could you describe exactly what/where you are measuring? As in do the rims have a hook/lip to the rim's inner sidewall top? Is the measurement across this lip? Is it under this lip but above the bead seat?
When we start stating actual numbers it's nice to know where they are coming from.
The next step if using measurements is to spec a new rim and periodically remeasure to gain some understanding of the amount of the change (from wear) as well as one's rate of change. Of course riding conditions will influence these measurements greatly.
Back in the 1990s when I had my shop in Cleveland and bike messengers were considered gods I serviced quite a few routinely. We had a number of rim sidewalls wear out and split off the rest of the rim. The Mavis MA2 rim became well known for doing this sooner then other brands (no surprise as Mavic tended to use fairly thin extrusions to gain their low weight). We likely saw a couple a winter season do this. These days I see a lot less but still feel for any sidewall concavity on transportation bikes' rims. Andy
AndrewRStewart
AndrewRStewart
Quoted: 8 Post(s)
Liked 17 Times
My wife’s Trek hybrid came with rims that have a small circular divot on the side of the rim near the valve stem. The idea, as I understand it, is that the rim is ready for replacement when the divot is no longer visible. I took the wheels out of service when the rims had worn down to that point … I didn’t do any measurements, but they felt pretty thin and did have some concave wear. It wasn’t a great set of wheels anyway, so she was pretty happy with the higher-quality replacements.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
A dental caliper is an inexpensive tool to measure sidewall thickness:
Likes For JohnDThompson:
