Mohawk Industrial Tricycle????
Gravel Junkie
Bikes: GT type CX, FUJI Sandblaster Drop Bar conversion, Kink Williams BMX, Framed Defendant Pro 22" BMX, Custom Klunker
Liked 7 Times
Anyone know anything about Mohawk Industrial Tricycles? I picked one up and am trying to figure out what components it should have. Rear axle, brakes, rear wheels? This thing must be a rare bird because internet searches have turned up next to nothing.
I worked for Mohawk Cycles in the early 80's. The trikes we built had a 7/8" cold roll solid rear axle. Threaded on each end. The 200 and 300 models had 3 pillow block bearings supporting the axle, the 100 had only 2. The rear wheel hubs were welded together in house. There was a drive wheel that was threaded onto the axle and a coaster with ball bearings on the other side. The hubs were made with a short piece of tubing, maybe 2 1/2" OD, welded to 2 spoke washers. the coaster wheels then had flanged ball bearings pressed in. The drive hubs had a washer welded in one side and a round nut in the other. The drive side of the axle was threaded about twice as far as the coaster side to allow the drive hub nut to screw on and still have room for the lock nut on the end. The 100's and the 300's had 20" wheels on the rear and the 200's had, I believe, 24". The Brakes on all the trikes we built were coaster. I think the was an option for a caliper on the front wheel. A stamped steel sprocket was welded to the body of a standard rear coaster hub. We built a few with 2 speed coaster brake hubs. This welded sprocket drove the sprocket welded to the rear axle. All the wheels we used were hand lased and trued by mostly housewives working from home. I believe the company was bought by a wheel manufacturer out of Mississippi. I don't know about rare, seemed like we made a awful lot of them. The biggest customer at that time was Lockheed aircraft, out of Georgia. I remember a few being shipped to an oilfield in the middle east. I'm not a regular here, in fact I only joined to answer your question. Ran across your question looking for something else. Since I already opened my big mouth, I'll check back for a short while in case you need more details or something else.
Likes For cuzzincarl:
Mohawk industrial bikes
I recently came upon a pamphlet of Mohawk industrial bikes... my grandfather owned the business for a period of time. There is a model 100 with basket, mode 100 basic, model 200 with cabinet, model 200 basic,model 300 basic, model 300 with cabinet. It comes with pictures and descriptions. Let me know if you are still interested.
Peggy
Mohawk industrial bikes... franchise?
Hi,
I read you use to work for this company, was it a franchise? Trying to find more info. My grandfather owned it at one time in Arlington, TN. Same company? Do you recall the owners name?
Thank you,
Peggy
Thank you,
Peggy
Orange Mohawk Industrial Tricycle
Hello! We have a Mohawk industrial tricycle.
It has a label:
MOHAWK
Mohawk Cycle
Memphis, TN
Our bike is orange, has the metal cabinet (with “Maintenance” painted on it), and is in decent condition. We are so curious about the history of this bike. It was in my fiancé’s garage! I have not been successful in finding one like it in any online searches.
It has a label:
MOHAWK
Mohawk Cycle
Memphis, TN
Mohawk rebuild
Hi. I am rebuilding a Mohawk tricycle. I bought the trike for $50. The drive wheel was trashed. I have been looking for one since. I work restore worksman trikes all the time. I've done 12 or so. I know I can convert the rear to a worksman setup but I'd like to keep it original if possible. Anyone have or have a lead on the mags rims that came with the Mohawk? Thanks in advance for any help.
