Shimano crankset FC-RS200 chainring measurements
Understand that for Shimano cranksets, the usual Chainring spacing is 5mm and 8-speed chainrings are 2.38mm thick. But folowing figure shows that it can vary across cranksets.
Before I buy crankset FC-RS200, have to figure out the exact positions of and spacing between chainrings.
Need x1 and x2 as shown in following figure.
Above figure was posted by tomtomtom123 in
https://www.bikeforums.net/20218671-post16.html
Quoted: 6195 Post(s)
Liked 4,810 Times
- Is your bike a 8 speed bike?
- Is it a road bike?
- Will your bikes bb be compatible with the FC-RS200?
Or are you also wanting to put different rings on it?
Quoted: 4206 Post(s)
Liked 3,870 Times
anga- I think your claim of rings usually being on a 5mm center-center dimension is off. Both in my experience and the imaged chart's specs the typical c-c is more like 8mm. Additionally at one time in the 1990s Shimano had their MtB cranks using a slightly wider c-c then their road stuff. Andy
AndrewRStewart
AndrewRStewart
Thank you. Exactly what I needed. Chainring spacing works out.
Ordered the crankset, probably the last available online in India.
5mm spacing is from Sheldon Brown's article on chainline.
Both are possibilities and the chainline covers most options.
