Help me decide between these two bikes.
Bikes: 2015 Specialized Roubaix SL4
Specialized Roubaix SL4 Sport Specialized Bicycle Components
Endurance Bike
I saw a LBS with these in stock in the $2000+ price range
The bike is Carbon with 105. Has axis brakes and wheels. The good part is I can get fitted properly to the bike as well as test ride it on site.
Lynskey Titanium
https://lynskeyperformance.com/r150-complete-1/
Around the same price point, has complete 105, better wheels I believe
Looks better, Will probably last longer but... can't test ride, will have to buy and then get fitted to the bike I buy etc... (not buying from LBS as well)
Endurance Bike
Lynskey Titanium
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Those bikes are so fundamentally different (frame) that it would be criminal to decide without riding each of them a decent amount...
Today, I believe my jurisdiction ends here...
Quoted: 454 Post(s)
Liked 104 Times
with #rmdnla they are 2 totally different bikes, I have never ridden a Specialzed, but have had a Lynskey frame bike for the last 6 years or so, and it is a great ride.
Quoted: 458 Post(s)
Liked 490 Times
Appears that both have endurance/sport geometry. Having owned both Ti and carbon, I'd have to say modern carbon frame construction (more manipulation in tube shape and material properties than Ti) will probably offer a more responsive and comfortable ride. I still love my Ti bike, though.
I plan to just ride the bike on the weekends or in the evenings by myself for exercise and weight loss
Bikes: Moots Vamoots CR
Quoted: 17 Post(s)
I went from carbon to Ti and I love the way Ti feels "alive" in comparison. I bought used and saved a bunch over new (Moots). Try out some Ti locally if you can to see if it's for you.
What would make you believe that the Lynsky would have a longer lifespan than the Specialized? Lifespan on a quality carbon frame or a Ti framed bike will greatly outlive yours and mine cycling lifetime. Figure $100 to $200 if you need to pay for a quality fitting.
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Quoted: 741 Post(s)
Liked 412 Times
For the type of riding it sounds like your going to be doing, either one will work fine. If it were me, I would go with the bike shop bicycle. They will be there for you (hopefully) if you have any issues that come up.
Quoted: 741 Post(s)
Liked 412 Times
Carbon frames are not as crash survivable as titanium, generally. Also, a titanium bike can be repaired much easier by more people than a carbon frame, generally.
If I crash hard enough to destroy a carbon frame there is a good chance a Ti frame is damaged as well. I dare say that nowadays a carbon frame can be repaired just as easy if not easier than Ti. All of that is besides the point. I would not buy a bike using its "crashability" as a decision maker.
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Quoted: 741 Post(s)
Liked 412 Times
Quoted: 273 Post(s)
Liked 10 Times
You'd probably love a modern steel frame...
Endurance Bike
Endurance Bike
What I like about the Lynskey is that if you upgrade from 105 to Ultegra it adds $600 to the price. My 6800 groupset cost me less than $600.
Quoted: 4717 Post(s)
Liked 1,882 Times
Ti is probably a little more resistant to small dings, but most wrecks that "destroy" a CF frame will still ruin a Ti frame.
BTW, CF frames can be repaired fairly easily.
Quoted: 130 Post(s)
Liked 24 Times
Those are both fantastic bikes that would work great for the kind of riding you plan on doing. I would get the Specialized mainly because you can get it at your LBS, so it could get it fitted and you can test it out. Try to get the LBS to throw in a fitting with the bike a good fitting is very important.
Bikes: Lynskey R240, 2013 CAAD10
Quoted: 50 Post(s)
Both bikes are great for this. If it were me I'd buy an aluminum cross (or gravel) bike with disc brakes, and throw some 42mm tires on it. Roads, MUPs, unimproved trails and dirt roads... it's all your choice.
Super Modest
Quoted: 11025 Post(s)
Liked 4,736 Times
Administrator
Quoted: 12019 Post(s)
Liked 6,798 Times
How could you have forgotten?
