Big head helmet advice, please
Hoping someone can help me. I have a round head that is also xtra large (apparently). Been trying to find a helmet that will fit the melon. Closest I have come is the Giro Hex, size Large, but it is still too tight at the top (about 3 inches above each ear (the place where, if you bite down or move your jaw you can feel the muscle pulse at the side of your head)). Any help is greatly appreciated, Thank you in advance.
RB
RB
Bikes: 2017 Kona TI, 2016 Bike Friday Haul-A-Day, 2015 Bike Friday New World Tourist (for sale), 2011 Mezzo D9, 2004 Marin Mount Vision Pro - for now :)
Quoted: 103 Post(s)
Liked 5 Times
I cannot wear the Giro as it hits me hard in the front and back, but is too loose on the sides (I might not have much of a round head, but it is a size large). I have always found the basic Bell helmets to work well for me.
RB
RB
Live to ride ride to live
Bikes: Calfee Tetra Pro
I have heard from a few riders that Bell and Giro have a different fit so you might try Bell.
Yes Giro tends to be more rounded, Bell more oblong. Giro's "big head" helmet is or was the Atlas II, though I've found it not as comfortable on me as some others. Bell used to make a large helmet called the Triton, but I think it may be discontinued. Louis Garneau also makes a large helmet called the Arcterus. It seems to be a tad larger than my Triton, but overall feels about the same. You can buy the Arcterus here:
https://aerotechdesigns.com/cycling-helmets.htm#arcterus
My hat size is in the area of an 8, so I know what you're going through.
Bell also used to make a huge helmet called the King Head which is long discontinued, but you may still be able to find some old stock. I vaguely remember reading somewhere that the impact foam in helmets has a shelf life so I don't know if it's safe to wear a really old helmet though.
EDIT: I just checked, and Bell's latest big helmet is called the "XLV", which give about 2cm more circumference than their regular Large helmets. I'll have to look for one of these and give it a try. Oh BTW, I hope you're not picky about styling. All of these helmets are very basic low end designs.
Thank you, very helpful. Under the circumstances, I don't think I have the luxury of being picky relative to color or style, just want the protection that fits. I will look for Bell XLV. My motorcycle helmet is a Shoei, expensive, but that's partly because they make and test different shells rather than just changing the "guts" inside. Unfortunately, they don't make bicycle helmets and if I wear my full face motorcycle helmet on my bike, well, talk about non-stylish!!!!
RB
RB
Yeah, it sounds like your head is longer and thinner than mine, front to back, despite being large. I think most folks heads are shaped more like yours than mine, hence the difficulty in getting a fit for shorter, front to back, and wider in the middle and on top. Thanks.
RB
RB
Have you tried to see if you can get a smaller head?
Much as I'd like to think that would be a viable option, it isn't. I guess I'm jealous of those of you who can simply grab a helmet off the shelf. Sorry to be a bother, but I would guess I'm not alone in trying to find a helmet that will let me enjoy a ride. So if anyone can help, I really do appreciate any advice. Thanks a lot.
RB
RB
I have similar problem and been toying with the idea of getting out my flapper wheel and taking a bit of excess styrofoam off in the right places. Anyone done this?
Bikes: Fuji Cross Comp, BMC SR02, Surly Krampas
Quoted: 7 Post(s)
I found that the specialized helmet I got is plenty big. I have a pretty oval head, and this helmet is definitely for rounder heads. Can't remember the name of it, but is nicely ventilated, but the vents mean wind noise.
RB
By the way, Lazer also makes another model, the O2 in XXL size (64cm). It looks to be about $100 less than the Helium if anyone is looking at these.
I just noticed that the Bell XLV is supposed to go up to 65cm, so I may try one of those, as I could use a little extra room in the winter for layering a heavy skullcap underneath.
Another issue to watch out for with helmets isn't just the front-to-back or side-to-side fit, but the top fit as well. I believe the top of the helmet is supposed to come in contact with your head. Some larger helmets I've tried look like they're sitting at least a finger-width above my head. In the old days helmets used to come with interchangeable foam blocks that you could add or remove to customize the fit, but not anymore.
Don't steal bikes, bro!
Bikes: Scrambler V3 fixie build, Specialized Tricross Ultegra, Cevelo R3 Dura Ace
RB
RB
Bikes: 2009 BMC SLX01/2016 Santa Cruz Bronson
Quoted: 8 Post(s)
I have a Lazer 02 that still has tags. I don't like the fit, so I may sell it if your interested.
Bikes: S-Works Tarmac 2017 - TREK Madone - Cannondale CAPO
Quoted: 206 Post(s)
Looks like this thread is a little dated. Anyone know new/stylish helmets that work with big heads?
I think it was mentioned already upthread, but I'm loving the Specialized Max. Best fitting helmet for me that I've ever found in 10+ years of looking. I think I must have a very oblong head, maybe a bit flat on the top. I say this because most helmets press on my forehead (sometimes to the point of causing headaches) and there's usually an inch or so of daylight between the padding and the very top of my head. Not so with the Max. I still wouldn't mind another cm or so of circumference in the headband (mainly to allow room for layering in the winter) but for most purposes it fits perfectly. Which of course means it's bound to be discontinued any minute.
Quoted: 206 Post(s)
Quoted: 206 Post(s)
Quoted: 643 Post(s)
Liked 1,526 Times
As has been mentioned, it's not only size but shape. My head is pretty big and my Giro Savant MIPS fits pretty well.
When I was motorcycling, Shoei and Kali were the only brands I could live with and even with them, it was only certain models.
I think you just have to keep trying them till you find one that works for you. One reason I don't buy helmets (or shoes for that matter) on line is cause if everyone does that, pretty soon shops will have minimum inventory to try.
Sr Member on Sr bikes
It looks like this website is dedicated to helmets for large heads.
https://www.bhsi.org/bighead.htm
Dan
Dan
Quoted: 206 Post(s)
Bike Helmets for Large Heads
Dan
Dan
Quoted: 18420 Post(s)
Liked 15,564 Times
Dan
Dan
