Why are cycling shoes so stiff?
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
I mean, compared to cycling shorts and jerseys.
Likes For Polaris OBark:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2587 Post(s)
Liked 5,649 Times
Here’s why: https://en.wikipedia.org/wiki/Cycling_shoe.
Wiki has a ton of info on the most obscure subjects
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 3241 Post(s)
Liked 2,512 Times
They have Viagra/Cialis mixed into the compound matrix so that your pedaling will be funtional.
Likes For seypat:
Quoted: 3242 Post(s)
Liked 2,089 Times
Added stiffness bettor supports the foot.
Liked 2,512 Times
Quoted: 5224 Post(s)
Liked 3,585 Times
I don't understand comparing shoes with clothing
Likes For rumrunn6:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
At a minimum, if you are using old metal racing pedals or modern clipless pedals, the shoe needs a stiff midsole to distribute pedal force over more of the foot other than just the part right over the small surface pushing back on the bottom of the shoe. After all, the pedal force can equal or exceed your body weight.
With big platform pedals, it’s not an issue. Really not much more taxing than, say, running, at least in my experience.
Otto
Otto
Likes For ofajen:
Grupetto Bob
Liked 5,649 Times
Likes For rsbob:
Quoted: 18424 Post(s)
Liked 15,582 Times
Seek immediate medical attention for stiff cycling shoes lasting longer that 4 hrs.
Liked 3,445 Times
I was just trying to riff/emulate/make fun of those other threads about bicycling threads ...
https://www.bikeforums.net/general-c...-so-short.html
https://www.bikeforums.net/general-c...s-so-long.html
FWIW, I had to buy the stiffest XC shoes I could fine to avoid pain (flat flexible feet). So the real question is why are so many bike shoes not stiff?
Bikes: Specialized
Quoted: 145 Post(s)
Liked 54 Times
My cycling shoes were pretty worn out so I had to break in new ones. 2 rides later, my ankle is so swollen I can barely walk. So I wasted a couple bills on New Balance walking shoes and tried riding with those. Nope. Prob out of commission for god knows how long. Depressing.
Liked 3,445 Times
What cycling shoes did you get? Maybe we can help you get sorted ...
Nothing should do that to your ankle.
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Stiff shoes are where it's at. My MTB and road shoes are identical (Bont Riot+) except for the tread on the sole and bolt pattern. Same heat-moldable carbon tub and upper. Riding in flexible shoes makes my feet hurt, too.
Likes For urbanknight:
Bikes: Specialized
Quoted: 145 Post(s)
Liked 54 Times
I’m using the Crank Brothers Stamp 7 flat pedals.
Liked 3,445 Times
My experience with Five Tens is the shoes are ok but the insoles are complete garbage. My wife had a similar experience, and had terrible cramps until she bought a pair of good insoles (probably another $50 is the last thing you want to spend, but if you already have some, it might be worth a try, or get them from somewhere with a generous return policy).
Quoted: 4420 Post(s)
Liked 4,873 Times
Liked 3,445 Times
My Shimano XC shoes came with high-quality insoles. They are even heat-moldable (as were the shoes). But they fit me fine without that. The insoles have 3 different arch support inserts a user can try (I have different ones r/l), and something customizable up front as well.
Most shoes (bike or otherwise) come with at least neutral stock insoles that would probably work for most people.
Five-Tens seem to have the worst, cheapest and most pain-inducing insoles of any bike shoes I have owned. The ones that came in my wife's shoes were somehow even worse.
Liked 4,873 Times
Liked 3,445 Times
I think this is what my wife has:
https://www.adidas.com/us/five-ten-f...es/GZ4656.html
When I removed the insoles, they essentially had no structure at all, just very thin pieces of floppy structureless foam material. The shoes were new, but I couldn't imagine them holding up for more than a few rides.
The ones in my two sets of shoes, Impact Pro from about 6 hears ago (one high ankle, one low), were a bit better in that regard, but still benefitted from replacement.
