Front derailleur cage wear with half-step gearing
How do people normally tackle the front derailleur cage wear as a result of frequent use associated with half-step gearing? Nobody seems to mention it on the forums.
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
Well, all my bikes have half-step gearing, but the majority of my shifts are full step. The half-step normally only comes into play when I get into the upper cruising range (above ~90"). Other than that, if I have a long cruise in the mid-range, and I need a half step to optimize my cadence, I use it... but most of the time, the cruise distance (before direction, meaning wind change, or slope change) is not long enough to warrant a half-step shift. To be sure, my full steps are in the 12-15% range, half steps half of that obviously.
Likes For old's'cool:
What kind of wear are you seeing that it is a concern?
Finesse it. It is not a power shift.
Likes For Bad Lag:
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
I've been using half-step gearing for decades and never had a problem with front derailleur wear. Are you perhaps using indexed shifting where you can't properly trim the front derailleur to stop chain rub?
Old fart
Liked 3,400 Times
Almost certainly, the OP is shifting "hard", that is, fast. The faster you shift, the more force imparted. The more force, the more wear.
Even with an indexed shifter, finesse the shift, be gentle. Shifting is not a speed or strength contest, especially up front, especially an up-shift.
Ok, I'll shut up now.
Likes For Bad Lag:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 920 Times
I have never thought of a front derailleur cage as a consumable part. Unless yours is made from a soft alloy, I wouldn't worry about it.
Likes For Fredo76:
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I can't seem to find that picture of the completely worn through cage... like let the chain grind on the derailleur until it wore completely through....
Commence to jigglin’ huh?!?!
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Quoted: 1106 Post(s)
Liked 1,328 Times
I had a Valentino cage wear through completely on the outer plate, on a 2x7-speed rig. It was on a trip, borrowed a blowlamp and a bit of brass wire and brazed a dime on the outside to fix it, was good for several more tours.
