Huret splurge.
www.theheadbadge.com
Quoted: 2451 Post(s)
Liked 4,497 Times
Huret splurge.
...if you can call it a splurge when the derailer was virtually free from the LBS. At any rate, I finally found a use for that Huret Jubilee that the LBS threw my way as part of the most recent Raleigh Twenty purchase.
It took one of those pricey little eBay adapters (that's the splurge part!), but boy, does it shift nice. So glad the first-gen Campy Rally is no longer there - drop parallelogram or not, the Jubilee shifts much better on the corncob.
-Kurt
-Kurt
Likes For cudak888:
Bikes: 02 Litespeed Ultimate, 84 & 85 Raleigh Grand Prix, '84 Raleigh Prestige, 85 Raleigh 555 RSL, '20 Raleigh Tamland, 38 Raleigh, 85 Landshark "Raleigh", '84 Marinoni Levi's Raleigh, SB4484, SB7979, Raleigh SSCXWC, 87 Raleigh USA 531 Prototype
Quoted: 202 Post(s)
Liked 147 Times
Dead Sexy...
Liked 4,497 Times
Looking at the pics made me realize that the bar tape color isn't suitable enough for Monsieur Sexiness back there. Just discovered Newbaums' maroon cloth tape and picked up two rolls to see if they'll match the frame.
Back when I built this thing in 2011, bar tape colors were notably more limited.
-Kurt
-Kurt
Extraordinary Magnitude
Quoted: 2612 Post(s)
Liked 1,733 Times
-Kurt
-Kurt
It looks like that stuff has been and still is nonexistent...
https://www.bikeforums.net/classic-v...-bar-tape.html
Commence to jigglin’ huh?!?!
Liked 4,497 Times
I've been casually looking for some maroon/wine/oxblood/Burgundy cork tape...
-Kurt
Liked 1,733 Times
I tried cotton over different padding- and that was BEFORE my hand injury. There's only so far I'll go-
BTW- I've never used one of those Jubilees. They have such a beautiful, minimalistic look to them- yours with the drilling, looks spectacular.
Liked 4,497 Times
I've run one Jubilee before with the factory Huret levers. I don't remember it shifting sharply and crisply like this one - and I'm out of practice with my overshifting. I'm also pretty confident that the Simplex retrofrictions aren't major contributors either. It is the quality of the shift at the cog - not the pull of the lever - that feels above average for a straight paralleogram.
-Kurt
Freewheel Medic
Quoted: 1481 Post(s)
Liked 2,251 Times
Kurt, Is that your '81-2(?) "Superior" lurking behind the drop on your handlebars? For some reason I thought you had sold that off some years ago.
P.S. I like the Jubilee, however it needs the Regina corn cob I have up on the classified section: 12-13-14-15-16-17
It's the silver one on the left.
Bob
Bob
Quoted: 5937 Post(s)
Liked 3,643 Times
-Kurt
-Kurt
Le savonnier
Bikes: I can count 'em on one hand
Quoted: 729 Post(s)
Liked 604 Times
Coolest rear derailleurs ever, that one is in great condition. Great combo with the Simplex Retroshifters. My wife has a Duopar on her Trek 620, and that thing is one of the smoothest shifting derailleurs I've ever encountered.
Quoted: 796 Post(s)
Liked 523 Times
Liked 4,497 Times
I don't remember why I changed it to the current 5-speed, but I'd take a guess that chain skate might have been an issue. The Sedis chain on it now occasionally fails to engage quickly (even though the derailer performs the shift nicely), so I'd say it's a good possibility that it rode over the grooved tips of the Cyclo-Pans. Or maybe the Cyclo-Pans self-destructed? I seem to remember something to that extent; the two halves of the body scraping each other. Don't really remember. No reflection on your work, of course - if that was, indeed , the fate of this freewheel.
Here it is, hidden behind the Simplex I originally had on this build:
Is that Regina spaced for 120mm? The Superior is still nice and narrow, and I don't want to cold set it.
I wound up ditching the included bolt and nut for the factory Jubilee nut, as the repop came too close to the chain (and I didn't feel like cutting it down the day I installed it). The original Huret bolt holds it just fine, even without the original expander in the back. It's very snug.
-Kurt
Liked 3,643 Times
Here we go: https://www.ebay.com/itm/HURET-JUBIL...QAAOSw~oFXM3Yc
snip . . .
-Kurt
Liked 4,497 Times
Most of the cheaper ones are the models with Huret upper knuckles, which puts you back where you started. Try getting one designed for Campag.
-Kurt
Freewheel Medic
Liked 2,251 Times
Kurt, the "tasty" Regina 6 speed corncob is definitely spaced for 126mm. I can appreciate not wanting to spread the Superior's dropouts to accommodate such a trivial thing as 12 tooth sprocket. Who needs such a high gear?
The other thing about the Cyclo Pans, as I remember, was that at least half, if not more, of the sprockets were aluminum. I'm certain they did not have a very long life!
Bob
Bob
Liked 4,497 Times
Granted, with good old downtube shifters, nagging DI2 problems don't exist in the first place...
I don't remember the Cyclo Pans ending its life by spinning a cog though. Can't find any record on the forum of my complaining about it either
-Kurt
Quoted: 1658 Post(s)
Liked 861 Times
Always wanted to try the Huret Jubilee on my French bikes, since the 80's, but just never seems to happen. I guess it does not help that all my French bikes had been mostly Peugeots, a company that was dedicated to just using mostly Simplex components on pretty much all their bikes in the 70's and 80's (till 1984, where they started transitioning over to BSA threading, Shimano and a bit of Mavic and I think, Sachs components).....
Maybe one day, if I ever get myself a Mecacycle Turbo bike, with a proprietary brazed on Huret FD, then, I'd be forced to make an all out effort to finally get that Jubilee RD after all the years of waiting.
But on my Peugeots, it's just not happening......
