1986 Centurion Ironman Driveline Compatibility - RD
Old 09-27-23, 09:21 PM
Otter2
I received an 86 Ironman centurion from a neighbor and am tearing it down to clean up, modernize a bit and put back together. I already have all of these parts on hand but not sure if it will all fit together.
Shifters - 2x7 micronew (micro shift knockoff) brifters to replace the original down tube shifters. I am not a fan of DT shifters.
Front Derailleur - original Shimano 600 fd-6207.
Front Sprockets - 53 and 38 tooth, not original, in good condition.
Rear Sprockets - 7 speed 13-28 tooth freewheel, original was a 6 speed but the 7 speed has been on it for awhile. In decent condition but haven’t been able to budge it to get it off.
Chain - 8 speed chain
Rear Derailleur - Dura Ace Rd-7800 10 speed, looks like a short cage.
For the rear derailleur the pull ratio is the same as 7 speed, and I’ve seen from other posts the chain should fit fine. I’m concerned the limiting screws may not have enough range and I am just outside the Shimano provided specs by a tooth (smallest 11, largest 27, max capacity 29, max 14 tooth front sprocket diff).
I might be able to rebuild the rough original rough rd-6208 but the rd-7800 is just sitting in my parts bin except I have to find a replacement jockey wheel. I would also be willing to spend about $40 on a better fitting new/used rear derailleur.
10 speed rear derailleur on 7 speed freewheel
Otter2 is offline
Old 09-27-23, 10:26 PM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 1562 Post(s)
Liked 1,735 Times in 975 Posts
The FD62** won't work with the brifters though. You'll need FD6401 and newer
icemilkcoffee is offline
Old 09-28-23, 12:55 AM
jetboy
jetboy's Avatar
Bikes: centurion cinelli equipe, look hinault 753, Zunow z-1, 83 stumpy sport
Quoted: 814 Post(s)
Liked 331 Times in 186 Posts
you will be fine. just adjust the position in your drop outs further to the rear- this gives you a bit more distance from the RD to the freewheel and take care of the shimano numbers- which are conservative to the worst case scenario. you have room to negotiate.
jetboy is offline
Old 09-28-23, 11:15 AM
seypat
Quoted: 3241 Post(s)
Liked 2,512 Times in 1,510 Posts
The FD will work both with Microshift 2X or or 3X brifters. The FD-6207 is the go to FD when it comes to shimano FDs. Heck, most any FD will work as long as it's a bottom pull. Doesn't matter if it's indexed or not. The original RD will take a 28t also. If you go to the IM thread, somewhere in that thread during the pandimic year I go over in detail(with pics) the gear options/limits of an IM. If you need a cheap RD, pick up a Deore from that era off the Bay. I've got one bike with a 52/42/30(9/10 speed chainrings), Microshift R9 3X, Suntour X-1 FD(7 speed), Deore RD and a 9 speed cassette.
seypat is offline
Old 09-28-23, 03:03 PM
Classtime
Classtime's Avatar
Quoted: 1952 Post(s)
Liked 2,013 Times in 1,112 Posts
6200 RD get worn and loose and I don't think you can rebuild it for dependable indexed shifting. The 7800 is good.
The '86 IM is the best year.
Classtime is offline
Old 09-28-23, 06:55 PM
jetboy
jetboy's Avatar
Quoted: 814 Post(s)
https://www.bikeforums.net/classic-v...aint-jobs.html
post to this thread and you will get all you need to know. the beauty is that I have never met an IM fan who was not up for helping a brother or sister.
jetboy is offline
Old 09-28-23, 10:13 PM
Otter2
Thanks for the responses!
Great to hear about that the rear derailleur should work fine after replacing a jockey wheel, but I’ll take a look at at seypat’s post to get some more info.
For the front derailleur, I picked this project back up after several months and after seeing the comments I remember I was searching for a new FD because of some incompatibility issues so I’ll take a deeper look.
I thought the IM thread was more for finished bikes but if I have any other issues I’ll try posting there. I feel like I need to actually ride it first before joining the IM cult.
Otter2 is offline
Old 09-29-23, 11:04 AM
markwesti
markwesti's Avatar
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times in 175 Posts
Otter2 , did you check your PM's ?
markwesti is offline
