Is the Peugeot UO8 series frame really designed for 650B wheels?
Bottecchia fan
Bikes: 1959 Bottecchia Milano-Sanremo (frame), 1966 Bottecchia Professional (frame), 1971 Bottecchia Professional (frame), 1973 Bottecchia Gran Turismo, 1974 Bottecchia Special, 1977 Bottecchia Special (frame), 1974 Peugeot UO-8
Quoted: 33 Post(s)
Liked 12 Times
I've thought about this for a while and never really come to a satisfactory answer. All of the bikes in this series (AO8, AE8, UO8, UO18, UE8, UE18, etc.) come with 27-inch wheels. The corresponding French models have different model numbers but seem to vary from 700C to 650B depending on the model. Because of the different model numbers and the fact that I don't have an actual French market bike available to compare, I can't really tell. But if you look the picture below of my UO8 setup with 27-inch wheels and 27x1 3/8 tires. Look at where the wide point of the tire is relative to the indentations in the chain stays fr tire clearance. They don't line up at all. Even a 700C is only 4mm smaller in radius so I don't think that would line up either. But a 650B just might. I'm going to take some measurements and see how it works out. What do you guys think?
1959 Bottecchia Milano-Sanremo(frame), 1966 Bottecchia Professional (frame), 1971 Bottecchia Professional (frame),
1974 Peugeot UO-8, 1988 Panasonic PT-3500, 2002 Bianchi Veloce, 2004 Bianchi Pista
Mike J
Bikes: 1975 Peugeot PX-50L, 1971 Peugeot PX-10, 1974 Peugeot PX-8
Quoted: 392 Post(s)
Liked 6 Times
I have 2 French-market lower-end Pugs, PX-8 which came with 700c wheels, and a PX-50 which came with 650b wheels. The chain-stay spacing on the PX-8 is about the same as on the UO-8, but is wider on the PX-50 for the 650b clearance. Those 650b-equipped models you're looking at were PX-50's, PE-41's, etc, not the AE/AO/UO-8 series bikes.
feros ferio
Quoted: 1397 Post(s)
Liked 1,336 Times
You are correct that US export A/U-08s came with 27x1-1/4" tires, usually Michelin or Hutchinson.
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
I'm not buying that explanation. First, unless these frames were specifically made for the US/Common Wealth market, the French would never design a frame around a 27" wheel. Second, the rim itself is already more than halfway into the indentation in the chainstays so putting a 27x1 1/4 inch tire is still not going to make it line up. Now the 4mm shorter 700C would help in that regard. I'll try a 700C rim later when I have a chance.
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
I did put a set of 27 x 1-3/8" knobbies on one of my bikes for awhile. I thought it was the UO-8, but chainstay clearance is already a bit close with 27 x 1-1/4". I think I could barely clear a 27 x 1-3/8" tire with the rear axle pulled back in the dropout.
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
I'm going to try an experiment this weekend, time permitting. I have 27" and 700C wheels that will fit this frame and 27x1 1/4" and 27x1 3/8" tires and 28mm and 38mm tires (and maybe some 32mm if they arrive in time). I'll mount them up and take pictures to see how they align with the chainstay indentations and what the clearances look like.
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
My 72 UO8 came with 27x1 1/4 tires. Seems like a reasonable assumption that the frame was designed for these. On the other hand, it's also reasonable that the US market was supplied different sized wheels. Still, I would expect that the French would have used 700c instead of 650b.
Keep in mind too that the stay crimps may have been done the same distance from the end of the tube so that when the BB end of the tube was trimmed, the resulting position would vary. Also, the crimps could have been done by hand so more variability.
Likes For Hoopdriver:
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
That gives me an idea on a completely different topic. I wonder if a frame builder could add crimps like that to an existing bike for more tire clearance. My Panasonic PT-3500 comfortably fits 700x38C tires but it does not have any sort of crimp or indentation in the chainstays. If they could be added it could probably go 42mm.
OP has a good question. I've wondered myself.
Peugeots were not designed for 27x1-1/4. They were fitted with that size for the American market. America is not the center of the universe. Paris is. Or you should assume it is if you want to know anything about French bikes. St. Etienne and Valentigney are satellites of Paris. America is somewhere in the outer darkness. Too many qualifiers on my part here, for any Frenchman it is unequivocal that Paris is the center of the universe.
Bikes used to need far more wheel clearance than they do now. 'Need' is the correct word. Ordinary bikes never had wheels that were particularly true. Spokes broke, regularly and predictably. Frames needed enough clearance to get home when the spoke broke. Low strength flat rims in wheels that have erratic spoke tension go way out of whack when a spoke breaks. In France there may have always been some sort of bike shop nearby, cell phones did not exist. Uber did not exist. The 27x1-3/8 tire shown above may rotate without scraping paint off the chainstays. It does not have nearly enough clearance for anyone who ever would have designed a vintage Peugeot.
Did Peugeot build frames that could be painted and stickered and built up as either 700 or 650? I don't know. But it is a fair question. Remember that 650x32 was a common size.
Quoted: 1865 Post(s)
Liked 665 Times
Two points: the fattest part of the tire is a little farther out from the axle, but the big influence is where in the horizontal dropout your wheel is clamped. There’s up to an inch of fore-aft adjustment in the dropout.
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
True, I'll take a look when I get home but I generally pull the wheel back as far into the dropout as it will go. Forged dropouts typically have adjustment screws to set the wheel position but these low end bikes don't. I've also see some of the low end bikes with a derailleur adapter in the dropout slot that would prevent the wheel from going all the way back but I don't recall what my Peugeot has. I'll take a look tonight.
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
I do tend to push the limits on tire size and gearing. The 27x1 3/8 knobbies on that one gave it some additional utility that it would not have had with 27x 1 1/4 road tires. The factories are very conservative. The worst that happens if my bike breaks down is I call my wife to pick me up.
Quoted: 4843 Post(s)
Liked 3,968 Times
I had a '67 UO-8. Never paid any attention to the chainstay indentation. US market 27 X 1 1/4. 1973 I went to 700c sewups, adjusted the brake blocks down and never looked back. Bike rode so well as a small tired 700c that I never felt it was designed or built for 27" despite that being how it came new.
One drawback to riding Peugeots with skinny 700c's, the low BB gets even lower. I call the conversions "slinkies". Ride them with sturdy pedals or expect to coast with the pedals at 3 and 6 o'clock for speed bumps. Riding fixed with leotard platforms, I spun off the left dustcap regularly. Pedal strike was a regular event.
Ben
Ben
Mike J
Quoted: 392 Post(s)
Liked 6 Times
On the PX-8, I have 25c width tires, currently using 27-inch rims, and they line up similarly to your example with the 1-3/8 knobbies. The rim braking surface falls at/near the center of the chainstay dimple, with the tire being close to the end of the dimple towards the bridge. On my 650b bike, the rim falls towards the beginning of the dimple towards the axle, and the tire falls at the center of the chainstay dimple. I measured the location of the center of the dimple to the rear axle center on both bikes, and both are dead-on 12-1/2 inches, and both have the same width of chainstay bridge. In other words, the 650b equipped bike can handle the extra width, because the tire falls near the center of the dimple, where there's more clearance. I'd say that if you change out the rims on your UO-8 to 650b's, you'll gain extra clearance for the 1-3/8's. tires.
Quoted: 796 Post(s)
Liked 522 Times
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
I will take careful measurements when I get home but I strongly suspect that I can run it with 650x38b and possibly even 650x42b although I'd have to carefully check the clearances on that.
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
Since the French sent Millions of UO-8s to North America and then built a plant in Canada to make millions more I think its safe to say they did in fact design the UO-8 around 27" wheels. Check out bike boom Peugeot and look at the American flyers
On Holiday
Quoted: 394 Post(s)
Liked 14 Times
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
Absolutely! I crimped the chainstays on a 90's vintage Bianchi frame so that I could fit 650b wheels with fatter tires. I carved a male pattern out of dogwood (very hard) in the shape of the crimp + a concave piece for the outside of the stay, and then used them with a C-clamp to do the deed. I did practice on one of my wife's metal broom handle first. She wasn't too happy.
Well, I was going to seek out the services of a local frame builder and let my wife keep her broom.
So I did check out Bike Boom Peugeots. The big year was 1973 when they sold 168,909 bikes in America. That ain't millions. And they thought you were completely out of your mind wanting that obscure tire size. Even putting the different size tire on the bike was a huge accommodation. It was a French bike. It was not an American bike. It was not about you. It was not about Americans in 1973.
Kommissar --- It was not about factory being conservative. It was about a bike made for a different time. It was not possible for a Frenchman to call his wife. No cell phone, remember? Did wife have a car? Did wife know how to drive? Was there even a phone in the house? I remember many houses in Chicago that did not have phones then, not even in the 80s. Peugeot wanted a reliable bike you could sell in France.
www.theheadbadge.com
Quoted: 2425 Post(s)
Liked 4,410 Times
Mike J
Quoted: 392 Post(s)
Liked 6 Times
So if I'm reading that correctly, the PX-8 and the PX-50 actually have the same bridge, chainstays, crimping, and spacing. Is that correct? And it also sounds like the 27" wheel/tire combo fits the PX-8 frame about the same as my UO-8. If that is true then it would appear that they all use essentially the same frame design. It could be that the frame was designed to fit both wide 650Bs and narrow 700Cs or that it was originally designed for wide 650Bs and the 700Cs were added later and there was no need to modify the frame. And then the 27" was added for the US & Common Wealth markets.
But, placing my 650b wheel into the PX-8, with a 584x40 Kenda 650b tire, there's about 5-1/2cm spacing each side of the tire. So, you could easily fit 42mm tires into the stock UO-8 fork, however the Mafac Racer calipers won't reach if you do it with 650b wheels, since there's fully a 1-1/4" gap under the fork crown.
