I have a weird-stupid (and possibly heretical) build idea....
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 27 Times
I have a chance to get a DL-1 frame for cheap, and I'm playing with the idea of a Pashley Guv'nor/Speed 5-inspired build....but, instead of using north road or Lauterwasser style bars, I'm thinking about a more typical drop bar. Has anyone ever done this, and if so, can you post pictures?
EDIT: I wouldn't be using the rod brakes...I'd use drum brake hubs with regular drop bar brake levers, much like I have on my Panasonic "Stupid Franken-3-Speed"
Quoted: 1627 Post(s)
Liked 630 Times
Doesn't sound weird to me. This one has 3 more gears in the hub but it's a shot in the same direction (racier frame geometry, though).
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
The main problem I'd see is how to rig brake levers for rod brakes to the handlebar. If you mean to use standard calipers, then no problem.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 248 Post(s)
Liked 27 Times
I'd be using drum brakes, no rods. I've set up a 3-speed hub with an STI lever before, and I'm thinking of combining that idea with roadster geometry and wheel size
feros ferio
Quoted: 1393 Post(s)
Liked 1,331 Times
It sounds like a great project to me, and eliminating rod brakes would strike a great blow for safety.
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
agmetal-
The dropped bar to rod brake interface sounds like a problem. For cheap, grab an old Raleigh Grand Prix and drop in a 5 spd rear hub. Gives you dropped bars and functioning brakes with the fewest problems.
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
This 85 Gazelle has a similar geo to the DL-1 and felt that drop bars would not work for me. 2 reasons; 1 it is too tall, 2 my belly is too big to fit into the cramped position with my feet so far forward because of the sloping seat tube. It now has a Brooks pro and some flat bars with a nice curve to the rear ( the bars look like a nice parenthesis). A smaller size would be ok with the seat really far front on the seat post.
Also realize that the head tube angle makes the bars turn in a funky manner.
This is running a SA drum front brake and SRAM 2 speed auto rear Coaster brake with 28" rims 635 ERT and Schwalbe cruiser tires. Fun bike to ride and really moves because of the gear ratio.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Quoted: 248 Post(s)
Liked 27 Times
Cable-actuated drums, not rods. This is all about the geometry and 28" wheels.
multimodal commuter
Liked 574 Times
That said I can't go so far as to call it a good idea. Most bicycle designers since 1950 or so would tell you the incredibly slack frame geometry is obsolete for good reason, but if it's what you like, go for it.
I have done my time playing with drum brakes, and have reluctantly come to the conclusion that they're a pain in the neck; but again, if that's what you like, go for it.
The same goes for 28" wheels. I know the guys riding "29ers" will disagree, but I think the larger diameter gives no advantage, while the heavy rims and tires are a distinct disadvantage; but like I said... if that's what you want....
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 248 Post(s)
Liked 27 Times
What can I say? I enjoy cognitive dissonance and anachronisms. I already own a bike with a front drum brake and an STI lever controlling a vintage AW hub, and a 1930s roadster....now I want to combine those ideas with some Pashley Guvnor influence mixed in
Quoted: 1361 Post(s)
Liked 424 Times
Surely could be done and less challenging than a DL1 with rod actuated. Cable operated, yes. Anyways, RHM summed it up well.
As for myself, been sidetracked on far too many things lately but did start on a DL1 project w/ Nasbar steel Lauterwasser style bars. The goal of retaining rod brake linkage. Shop made braze-ons for the bar, lots of custom bending of rods, etc.. Mostly experimental, weird angles. Conclusion was a loss of leverage, more time than its worth and have parked it all. There's a few pics on the net of very early racers (1930's?) with a similar arrangement. But for something different and one has the time, go for it.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
You'll probably want to source a horizontal 'L' seat post to get forward enough for drop bars. That, and a small frame and a short stem may get you into a rideable position.
Phyllo-buster
Liked 2,055 Times
off-topic, kinda. Check out the stem/fork combo on this 'Bradbury'. Doesn't look comfortable to me.
Quoted: 248 Post(s)
Liked 27 Times
Yeah, I'll be using a 22" frame, and probably a zero-setback seatpost
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
You can flip the seat bracket over to get an inch or two further forward. I was wanting to try this for a long time. It's tough to get all the hardware to make things compatible but I was always on a tight budget. Look to the old racers for inspiration. Have fun and keep us posted!
I got about this far before I found some other project to distract me. I had collected alloy rims and a fixed gear hub but never got around to lacing them.
Quoted: 248 Post(s)
Liked 27 Times
Well, it turns out that the guy doesn't actually have the frame he thought he did. I do have a 24" one here at home that I could use, but I don't think I quite have the legs to stand over it.
Quoted: 248 Post(s)
Liked 27 Times
This is just kind of quickly thrown together with bits that I have lying around, but this is the basic look of the idea I have in mind. The saddle is set to roughly the height I'd need it to be to ride, and the stem is in as far as the light bracket will allow (plus the stem and handlebar give slightly too much reach). A 22" frame would be the same length, but would give me more standover clearance.
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
Once the novelty wears off, you'll be left with a heavy, slug. Search for a light frame with the proper geometry, you can find it among British Frames from the 30's & 50's. Sellers like Hilary Stone are a good source to watch, some even end up in his "Bargain" section.
It will cost you a few coin but you'll end up with a bike you'll enjoy to ride.
multimodal commuter
Liked 574 Times
The seat tube angle is not the problem; as has been mentioned, you can put the seat clamp on the front of the post, or use a gallows style post, to move the seat to the correct position in relation to the crank. That's easy. But with the DL-1 style roadster frame, you'll still be left with the impossibly slack head tube.
So, for example, my Fothergill (built either just before, or just after WW 2):
The seat tube is as slack as a roadster, but I have the seat mounted in a normal position by reversing the clamp; but the head tube is a relatively modern 73 degrees or so. The frame looks archaic, but in fact rides fine.
Maybe you can find a DL-1 that's been in a head-on collision, giving it a steeper head angle. That would ride much better.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 248 Post(s)
Liked 27 Times
I think a lot of you are missing the point of what I'm trying to do
multimodal commuter
Liked 574 Times
Quoted: 248 Post(s)
Liked 27 Times
Perhaps, but how many of the commenters have ridden a roadster? My '37 is faster than most people expect, climbs surprisingly well, and does really well on gravel and bumpy roads. A lot of that is due to the steering geometry, the large wheels, and long crank arms....and the weight helps keep it rolling once it's up to speed.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
But this is not to talk @agmetal out of the project, I want him to see it through and get his impressions afterward.
