72 Paramount test build
Quoted: 938 Post(s)
Liked 2,946 Times
The P13 frame from Milepost105 arrived on Thursday. I brought it to my mountain lair and decided to do a quick test build so I can get it on the road on Sunday and start to adapt as necessary. Almost all of it came straight from my Falcon and is age-appropriate.
I have slightly newer NR components in my bins to put back on the Falcon. Not sure I have an appropriate wheel set but I’ll sort that out.
Before y’all start zooming in, the Weinmann levers will be changed to Campy, and I’m not keeping the Falcon straps on…
The Falcon has miles of clearance and is designed for long reach center pulls. I’ve had a pair of Records in the bin for a while, and @Mad Honk kindly provided me a set of levers, shoes and Kool Stop blocks. The levers will go on eventually after I finish sanding and polishing them.
I’ve put a hanger extender on to support a 6-speed 14-28, with 48-42 up front. I’m thinking of putting modern pedals on it. I have these silver ones and a set of Superleggerias which would probably look best, but my feet are happier with clipless. I’m sure I’ll get better tires and I’ll probably order decals.
Just as I finished the build, rain moved in so I can’t even take it down the road right now! Thanks for looking, hope to have a ride report tomorrow.
Likes For ascherer:
Quoted: 1303 Post(s)
Liked 1,912 Times
Andy,
Looking good so far! About that wheel issue; I'm pretty sure that with some large monetary movements, the right parts can be procured. Smiles, MH
NIB high flange hubs Somewhere else in this tool box there are some NIB LF hubs.
Plenty of refurbished sets on hand, just pick your poison.
Likes For Mad Honk:
Quoted: 253 Post(s)
Liked 223 Times
Oooof :O What a bike - seems reaaaally tall I am 1.83 m tall and usually ride 58 cm frames but this gotta be an 60+ cm?
Also on that selection of NIB stuff. Holy cow..
Likes For Positron400:
Quoted: 878 Post(s)
Liked 2,296 Times
Looks nice . I have not had to use an extender for a 14-28 FW on my bikes with NR derailleurs but I am running 53/41 chainrings. Is that why you need the extender , for the smaller chain rings?
Likes For Kabuki12:
Quoted: 878 Post(s)
Liked 2,296 Times
if I remember right , it is a 64cm frame ….which is perfect for me and a few others on this forum that were eyeing this beauty!
Likes For Kabuki12:
Quoted: 878 Post(s)
Liked 2,296 Times
Positron400, I get mine to clear the 28 tooth cog by moving the axel stops back. I have a few with that FW set up and Campy NR RD with no clearance issue.
Likes For Kabuki12:
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 164 Post(s)
Liked 102 Times
Likewise, I have run 28 tooth FWs with NR RDs on Campagnolo dropouts on several bikes. It has always worked fine when I move the wheel as far back in the dropout slots as possible.
Likes For kroozer:
Quoted: 938 Post(s)
Liked 2,946 Times
Originally Posted by kroozer;[url=tel:22896480
22896480[/url]]Likewise, I have run 28 tooth FWs with NR RDs on Campagnolo dropouts on several bikes. It has always worked fine when I move the wheel as far back in the dropout slots as possible.
Likes For ascherer:
Quoted: 938 Post(s)
Liked 2,946 Times
Originally Posted by Mad Honk;[url=tel:22896415
22896415[/url]]Andy,
I’ve got plenty of hubs, at least two sets of Campy low flange, some nice first version Shimano 600 high flange, I think some Dura Ave high flange, and lord knows what else. I have to take some time to determine what kind of wheel set I want - I kind of want to build up tubulars for this but that may not be my best decision either.
Those brake bits arrived just in time, many thanks.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Looks wonderful and I feel you on the larger frames. So nice for getting the bars up. I like the 48-42 chainrings!
Likes For 52telecaster:
Wow, impressive, that was fast! Two things I forgot to mention: for shipping I ran the rear axle stop screws all way forward so they wouldn’t get bent (something I learned from Merziac), but you probably figured that out and adjusted accordingly; and the other is that this P13 has the brake cable stops on the top tube, which I think is unusual. It must have been specifically ordered, or just a fluke in the original build.
Glad to see you’re up and running!
Likes For Milepost105:
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 323 Post(s)
Liked 690 Times
Quoted: 938 Post(s)
Liked 2,946 Times
I find builds go fast, especially if everything is on hand. Most of the components went on straight off the Falcon. Today was chain, cabling and all the fiddling that takes twice as long. At some point everything will come off and get cleaned and polished, but for now I just want to ride!
Likes For ascherer:
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1227 Post(s)
Liked 3,561 Times
What is that derailleur hanger/red bolt combo there? I like that!
There were 135 Confentes, but only one...Huffente!
Likes For AdventureManCO:
Quoted: 938 Post(s)
Liked 2,946 Times
I had a few cheap extenders on hand, I got some black, silver, and red at some point. I've used them with some Dremel modding to "convert" Huret dropouts. I was using the silver one and the bolt seemed to be stripped so I grabbed the bolt from a red one. Kinda pops, but if it shifts into the 28 without it when I pull the axle all the way back in the dropouts, it'll end up back in the hanger drawer.
Likes For ascherer:
Quoted: 3464 Post(s)
Liked 2,831 Times
I would look into purchasing graphics from Waterford. The time is Now or never.
if you go the slide the axle back to obtain 28t clearance, use shorter adjuster screws so that the extended fasteners won’t get bent.
I think Nervex Pro lugged Paramounts should have high flange hubs, Red bar tape with Chrome.
Likes For repechage:
The Huffmeister
Liked 3,561 Times
Quoted: 878 Post(s)
Liked 2,296 Times
Likes For Kabuki12:
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
Looking at the red covers on the shift levers, made me think that red leather bar wrap and custom red leather brake lever hoods would look really nice.
Beautiful Paramount!
Bob
Bob
Liked 1,912 Times
"Custom red leather" makes me think there will be some sewing going on soon! Smiles, MH
Likes For Mad Honk:
Myrtle Beach Crab
Bikes: enough one would think, but thinking isn't my strong point
Quoted: 271 Post(s)
Liked 541 Times
rati dropouts.
Likes For cocoabeachcrab:
Quoted: 601 Post(s)
Liked 781 Times
Would be very cool if many of us paramount riders could have a meetup, showoff and classic ride.
I sure wish I would have used my 72 P13 at the TX churches ride, like pastorbobnlnh
Thought I may have needed the colnago master but the p13 would have served fine
Likes For joesch:
Quoted: 938 Post(s)
Liked 2,946 Times
This morning I slid the wheel back and it made it onto the 28 without the extender. Had to remove a few links from the chain. Put on the rest of the accessories.
Likes For ascherer:
ambulatory senior
Liked 3,661 Times
