Bent steel pedal arm
K2ProFlex baby!
Location: My response would have been something along the lines of: "Does your bike have computer controlled suspension? Then shut your piehole, this baby is from the future!"
Bikes: to many to list
Quoted: 16 Post(s)
Liked 56 Times
My "James" cycle has a bent pedal arm and am asking what the best (safest) way of bending it back into place would be. Its slightly bent but enough to just make contact with the chaingaurd while pedaling. I checked the chaingaurd and its fine. I've seen the LBS use a long steel pipe to bend them back in place, is this "the norm?" or do you guys have a better way? Please let me know.
You see, their morals, their code...it's a bad joke, dropped at the first sign of trouble. They're only as good as the world allows them to be. I'll show you. When the chips are down, these...These "civilized" people...they'll eat each other. See, I'm not a monster. I'm just ahead of the curve
Decrepit Member
I'm not sure what a pedal arm is. Are you talking about the crank arm?
K2ProFlex baby!
Quoted: 16 Post(s)
Liked 56 Times
Yup, the crank arm.
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
PS. I still want that bike... Not jealous, just envious.
K2ProFlex baby!
Quoted: 16 Post(s)
Liked 56 Times
Quoted: 1372 Post(s)
Liked 1,755 Times
If you do intend to straighten the arm, might I suggest that you remove the crank from the bicycle, first. You would not want the excessive pressure finding a way into the frame set.
For what it is worth, I am working on a Peugeot with a seriously bent steel crank arm. I intend to try to replace it but, being a Peugeot five speed, I might have a tough time finding the perfect crank. If that is the case, I will straighten the arm out using the cold set method. If it looks good when done, I will be set...
You will notice that the crank arm was bent far enough in to actually damage the lovely original alloy Peugeot fender. How did it get bent so badly? Incredibly poor shipping technique...
So far, I have collected everything I need to restore the bike, except the correct crank arm. And that might not even be a problem. There just might be one hiding in The Old Shed.
K2ProFlex baby!
Quoted: 16 Post(s)
Liked 56 Times
@ Randyjawa, Sweet find! Hope things go well with that crank arm! OK, I remove the crank arm to cold set it, how/what do I anchor the arm to to keep it still and secure enough to bend it with the pipe?
Knotty Guy
Remove the crank arm and take it to someone with a hydraulic press. You can then have them bend it back right where it needs it. They can control the amount of force needed with the press. Of course, the arm needs to be steel.
Tom
Tom
Old fart
Quoted: 3598 Post(s)
Liked 3,423 Times
spookeaymarine.info
Location: Me, I'm in Central Alabama C.S.A. But my husband is under the bed. He's sure there is a black helicopter orbiting our house.
Bikes: Schwin,Ross,Cannondale.
The press is the best way. The pipe can work. But before you do. Wrap the heck out of it with electrical tape first to keep the pipe from marring the chrome. If you have a bench vise, that would work also. put it in the jaws with the arc of the bend compressed in the jaws and tighten it down till it mates flat with the jaws and leave it over night. just my 2 cents.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,057 Times
I've had success propping the arm a half inch off the concrete floor and using a maul and a hardwood block. Those arms can be very soft and you can control the bend easily. Or a bench vise and a couple of shims...
K2ProFlex baby!
Quoted: 16 Post(s)
Liked 56 Times
Hydrolic press, yeah, I don't know anyone with a hydrolic press.
Schwinnasaur
Vise and pipe works. I did one not too long ago. First measure how far it needs to be bent and do it a littie at a time. You don't want to go past the amount you need because metal fatigues quickly in its "plastic" zone.
K2ProFlex baby!
Quoted: 16 Post(s)
Liked 56 Times
Hmmmm, this sounds like a plan! I'm pretty good at whackin' stuff with a hammer! LOL! Think a hard rubber mallet might do the job? I've got one of those.
Liked 1,755 Times
Liked 1,755 Times
Do not use heat. Do not use impact. Use a vise, three hardwood or alloy blocks, and press the arm straight. That is what I intend to do and I have done it before, but only with steel. Do not use a bent alloy arm!
Research and Development
Bikes: Gary Fischer Level Betty, Marin B-17, Giant Attraction, Scwhinn Beach cruiser, Trek 700, Currie 450w,
I agree with this method. Used it more than once. Wood block and a BFH. If aluminum, you only have very few shots to get it right. Bang on it too much and it will work harden and break, or at least develop cracks which will eventually lead to catastrophic failure at the worst possible moment. Steel, you can beat on all day long.
Old fart
Liked 3,423 Times
Clamp it in a bench-mounted vise, preferably with the bench bolted securely to the floor. Slip a long steel pipe over the arm and apply Great Force to move it where it needs to be.
K2ProFlex baby!
Quoted: 16 Post(s)
Liked 56 Times
This thread is two years old, that bike id loooong gone.
