Is it best to keep folding bikes folded.?
Old 08-04-15, 07:17 AM
tudorowen1
Bikes: Brompton S6L ,Bike Friday NWT, Phillips 8 speed folder, Trek 930, Thorn XTC
Quoted: 76 Post(s)
Liked 9 Times in 8 Posts
I have an old Dahon and an Enda..When these bikes are unfolded the hinge clasps are usually under tension..When the bike is not being used is it better to store them unfolded or at least with the folding clasps undone so they are not under tension..?
tudorowen1 is offline
Old 08-04-15, 07:43 AM
ShortLegCyclist
Bikes: Many bikes in three states and two countries, mainly riding Moots Vamoots, Lynskey R265 disc and a Spot Denver Zephyr nowadays
Quoted: 26 Post(s)
Interesting question, I'll be interested to see what the forum gurus think on this.
My two cents, some bikes are under no stress when folded and seem to "like" being in that state, like Bromptons. All my Bromptons stay folded unless actually being ridden.
Terns and Dahons, though, do not seem to "like" being folded, meaning if you move one or carry one it tends to want to open up. Along with the magnet, the folded bikes are held together by a rubber strap, and this seems to me to be under considerable tension when carrying or rolling a folded Dahon or Tern.
So I don't keep my Dahon and Terns folded because I want to avoid stress on that rubber strap more than I worry about the springs on the hinges, which seem to me just want to keep the hinge lever closed, whether the bike is folded or not.
Can speak at all to Endas, never heard of that before your post.
My only other folder is a Bike Friday and I never fold that unless transporting. Their whole schtick, interestingly often appropriated by Josh Hon when describing his Terns, is that Bike Fridays are "not folding bikes that perform, they are performance bikes that also happen to fold."
ShortLegCyclist is offline
Old 08-04-15, 07:46 AM
energyandair
Bikes: Birdy Red 8 speed, Birdy Blue 21 Speed, Birdy Monocoque 24 Speed, 2002 Devinci Desperado, 1996 Rocky Mountain Hammer Race
It's best to keep them folded if you want to save space.
If the hinge latches are properly designed, then leaving them fastened should not be a problem. If it is desirable on a particular bike, I would think about changing bikes.
If leaving fasteners undone to store them relatively stress free, was normally necessary then it would also be necessary to loosen all quick releases, all nuts, all screws, and all spokes.
energyandair is offline
Old 08-04-15, 07:57 AM
ThorUSA
Bikes: to many
Quoted: 213 Post(s)
makes no difference
as long as you don't ride them unfolded ( or way too loose )
thor
ThorUSA is offline
Old 08-04-15, 08:08 AM
bhkyte
bhkyte's Avatar
Bikes: 2X dualdrive Mezzo folder,plus others
Quoted: 107 Post(s)
Liked 3 Times in 3 Posts
One possible thing to consider is brake,and gear cables. I find that the torturous cable routing on my dual drive mezzo needs some elongating from time to time to avoid cable stick. Maybe it would happen anyway if not used for a long time. It needs a good run from time to time.
bhkyte is offline
Old 08-04-15, 10:49 AM
dadbar
Bikes: Firefly Ti, Trek Domane AL5, Montague MX, Dahon Formula S18
+1
The more I fold and unfold my folders, the more the derailleurs seem to shift alignment, so I only do it when I need to fold.
dadbar is offline
Old 08-04-15, 12:19 PM
ShortLegCyclist
Quoted: 26 Post(s)
Originally Posted by dadbar
+1
I don't like derailleurs on wheels that close to the ground so I almost exclusively have internal hub folders.
The glaring exception with ironically the smallest wheels would be my six speed Bromptons of course.
Old 08-04-15, 01:35 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
this , though I mostly only use the rear wheel flipped under 'Kick stand effect', of my Brompton.
it's not folded in my house's Entry room.
fietsbob is offline
Old 08-04-15, 01:55 PM
tudorowen1
Quoted: 76 Post(s)
Excellent point..Thanks..
Old 08-04-15, 02:07 PM
bhkyte
bhkyte's Avatar
Quoted: 107 Post(s)
+1
I run Teflon lined inner cables, kevler outers with Teflon linings to reduce this and to improve performance. Only do this upgrade if problem or if fitting new cables however.
bhkyte is offline
Old 08-05-15, 12:05 AM
foldingBiker
Bikes: mostly folding bikes
Yep, also had the problem with my Dahon bicycle. Basically, I am storing my bike with the folding clasps undone, because I fear that the tension, will break the clasps.
Btw Dahon`s warranty goes for up to 5 years.(even though I had no real problems with my bicycle yet)
foldingBiker is offline
Old 08-10-15, 10:29 PM
Violinfish
Violinfish's Avatar
Bikes: Dahon HSL,NB994 16",Battle FSD 14"
if you keep some metal parts tightened and untightened repeatedly, they may wear out or break sooner than staying tighened .
The extraordinary example about “metal fatigue” is that it takes only a few pounds of force applied repeatedly back and forth across the paper-clip’s thickness to break it.
IMHO, you'd better keep your bike unfolded. it's unnecessary to fold it unless you do neet to save space.
Violinfish is offline
Old 08-20-15, 06:52 PM
lucille
lucille's Avatar
My Bike Friday is pretty much always unfolded, Brompton lives in a small nook and it's folded until needed.
lucille is offline
niania
Folding Bikes
26
04-19-18 06:40 PM
lulubell
Folding Bikes
4
09-07-17 05:16 AM
rsanchezsaez
Folding Bikes
30
07-19-17 02:15 PM
Crankykentucky
Folding Bikes
12
06-28-14 03:13 PM
gracejoo86
Folding Bikes
3
06-22-14 06:53 AM
