Lightest steel freewheel?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
That sounds like a really wasteful way to go about it, but if you have the budget...
RUSA #7498
Originally Posted by noglider
Last edited by ThermionicScott; 09-03-13 at 01:43 PM. Reason: decided against the post-script
Likes For ThermionicScott:
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,195 Times
I have a 50 pound pail of 6 and 7 speed Dura-Ace freewheels and spare cogs. I also have an equivalent stash of Winner and Winner Pro hardware. So here is my unbiased advice.
The best freewheel right now for the combination of light weight and shifting quality is Shimano's TZ20 and TZ21 (6 and 7 speed respectively) Tourney freewheels. Why:
- They cost less than $15 each.
- They feature Shimano's superior Hyperglide cog profiles, which provide worlds better shifting than any of the old freewheels. Uniglide and Suntour freewheels were somewhat better than the old Italian cogs, which were hopeless.
- They have a unique design in which the 2 largest (heaviest) cogs are heavily cut away and supported (pinned to) the smaller cogs. This accounts for their low weight.
- They have a sensible 14-28 gear range. This elimates the useless 11 and 12 tooth cogs found in current cassettes, and includes lower gears for use with standard crankets. We're not getting younger.
Gearing is very individual to the rider and the terrain they ride in. For instance the smallest cog on any of my bikes is a 32T and they all are equipped with triple cranksets. If I lived in south Florida, I'm certain I'd never use a cog over 26T (maybe even a 24T), and all would have double cranksets.
Bob
Bob
Quoted: 7348 Post(s)
Liked 2,470 Times
I'm cool with my Chinese POS. In fact, I like it. Service the bearings? You're the last soul on earth who still does that. I quit doing that in 1981. Change the cogs? I bet less than .01% of the people want to do that.
Since freehubs are so superior, I'll save my complaints for them.
I don't think those bearings ever wear, since there's never a load on them.
Liked 2,470 Times
When freewheels have a problem with bearings, 99% or more of the time, flushing with lube does the trick. Repacking them with grease is way too involved for anyone but Pastor Bob. He enjoys it.
Liked 2,568 Times
And that's something Pastor Bob never likes to see, if he can prevent it.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
I always try to open up FWs to clean and re-pack them if I can (I think the only one I haven't manage to open is is Maillard Super Compact 7S FW that requires a special fine toothed lockring remover that I do not have). I guess I'm a bit anal and I don't want to miss the smallest bits of dirt hiding in the FWs. Anyway, it's fun to find out how each FW brand and model works as you'd be surprised that they are quite different from each other inside.....
Quoted: 834 Post(s)
Liked 2,126 Times
Quoted: 786 Post(s)
Liked 520 Times
To each their own. I personally run a SunRace 6 speed FW on my '86 Masi. Shifts great, is shiny silver, and was like $12.
Liked 2,470 Times
Well waddya know. Thanks for letting me know, Chombi and gaucho777. I didn't know others enjoy overhauling freewheels.
Then again, why not? I fix laptops among the various things I do for a living. I just received a contact from a new client, asking me to teach him how to take apart laptops and put them back together. And why not? It's a similar thing. It's not terribly hard. The patience is the key. Keep track of all the tiny little parts.
Quoted: 4722 Post(s)
Liked 3,036 Times
A riding partner once had a freewheel cover plate back off during a ride on an isolated road. We sat in a cold pouring rain, picking as many bearings as we could find, out of the cracks in the asphalt. After what seemed like an eternity, we eventually reassembled it and managed to complete the ride. After that, overhauling a freewheel in the luxury of my workshop, with all the proper tools at my disposal, is a piece of cake (but I still avoid cake whenever possible).
On the customer side, I stopped servicing freewheels years ago. The price of replacement is far cheaper than servicing and in the process you can provide the customer with a Hyperglide compatible unit that will shift better. The only drawback is the more limited ratio selection. Still, that's not an issue for the vast majority of customers and even if it is a concern, they invariably opt for the less expensive solution when they learn the relative costs. I can't remember the last time that I serviced a freewheel for a customer. (98)
I replaced an old high-end Shimano 600 6-speed freewheel (the twist-tooth type) with a new $15 Sunrace with HG ramps, and the 6-speed SIS shifting improved dramatically. Smoother, quieter, quicker shifts. An example of technology trickling down and making a low-end item superior to what was once considered a high-end item.
I'd say my beloved road bike is worth spending $250 every 4-5 years to keep a vintage bike vintage and functioning perfectly. Besides if you regularly service your parts and ride properly it can last way more than that.
Quoted: 786 Post(s)
Liked 520 Times
It is funny that in 2013 we are in a golden age of cheap, high-performing freewheels.
Liked 2,568 Times
I agree with most of that. My thrust was that those pricey freewheels and chainrings might last even longer if you replaced the chain (the cheapest part of the system) regularly or rotated through several, rather than allowing it to wear out the whole system and determine the replacement interval. Did I misread your protocol?
Liked 2,568 Times
^ Same. Sedisport was/is a better chain anyhow The Regina SLs do look cool though.
Though as iab pointed out in a recent post, in these days of $900 modern cranksets, etc., $130 doesn't sound so bad.
Quoted: 150 Post(s)
Liked 34 Times
Everything is going up in value.
Just a couple of years ago, you can still get an NOS Regina America Superleggera (Hybrid Al/FE construction) FW for less than a hundred bucks. Now that many have given up finding a Campagnolo Aluminum FW for any kind of sane price, I think the weenie FW buyers are now moving over to the Hybrids, so the Reginas and Zeus Hybrid FWs are now getting out of reach price-wise for most C&Vers too....
Bad part is, it is hard to find good used ones as they usually have significant wear on their Al cogs....
Actually good point with the hybrids. Found a hybrid Zeus. 13-20t at 260grams. All stell except for the 20 and 18 cogs. Asking over $200 for it too. You can get a full alloy Zeus for less.
Bikes: Frejus/Bertin/Cannondale
I actually just salvaged an old Sedis chain recently, but haven't tried it on the bike yet. It's a little heavy, compared to today's stuff, but very smooth-feeling, after a good bath in chain-lube. Plus I have a SRAM master link, to make things easier.
Freewheel Medic
Liked 2,195 Times
It's intersting how this thread has evolved!
One way to make your freewheel last longer is to remove the cogs once a year and remove the grit and grime. At the same time completely bathe and service the drive train. Your bike will love you for such devotion!
Bob
Bob
