Are There Any Store Brand Bikes in Canada or US With Rohloff Speedhub IGH?
Quoted: 81 Post(s)
Liked 38 Times
After only a couple of weeks on my Alfine/Gates combo, I am sold on IGH's and belts. Very smooth and seamless shifting and I love being able to shift at traffic lights or any of the numerous stops on a city commute.
My wife wants a new bike now and I have proposed she take my Alfine 8/Gates while I look at upgrading to the Rohloff. A few more gears would be nice for my daily commute. She rides only occasionally for recreation so it's mutually agreed that I get the better bike and she gets the nicer car.
Quoted: 2339 Post(s)
Liked 2,831 Times
you should consider a bike with Pinion gearbox/drive
here is an example https://www.prioritybicycles.com/pro...gaAm7XEALw_wcB
https://pinion.eu/en/
Quoted: 81 Post(s)
Liked 38 Times
I am tempted to order this bike but servicing the pinion may be an issue. There are no supporting Priority dealers in Canada. The dealer I bought the Alfine 8 from threw in the 1k km drain service and it's 3 k km after that which I may attempt. There are a few dealers near me that sell bikes with Alfines. Obviously, Rohloff would suffer the same servicing issues as Pinion unless I am missing a Rohloff or Pinion brand avail in Canada
Clark W. Griswold
Quoted: 4363 Post(s)
Liked 4,006 Times
Co-Motion makes stuff with Rohloff and any custom builder can do it. Tout Terrain also comes to mind and Peter White can get you set up with them. There are also a lot of other custom builders who can get a Rohloff bike for you. I am unsure of Canada but I have to imagine there are options as well.
Likes For veganbikes:
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 191 Times
Likes For Viich:
Quoted: 81 Post(s)
Liked 38 Times
https://mariposabicycles.ca/bikes/city/
Clark W. Griswold
Liked 4,006 Times
Thank you sir. We do have custom builders nearby. The closest is this one. Does the frame and fork not seem excessive? Admittedly I have never purchased a custom bike so I will be unsure if I am being fleeced.
The sky is the limit.
However it should be noted that there are loads of builders out there both more expensive and cheaper and you can shop around. Some will be more barebones and might just offer a few models that they customize to a point and others will go for whatever they can build. I personally don't have much knowledge of Mariposa (I have looked at them recently) but looking at their website I would own one if I had the money. Though if I had the money probably all of my bikes would be custom frames. However choosing would be tough there are so many great ones that I would own happily. Decide what you want in the bike write out what you want in the bike, your dreams, your desires and start looking at custom builders and figure out one that you think matches most closely with what you want and send that screed to them and see what they say. Some like Independent Fabrications will have a build sheet you would fill out and that could be a good starting place if you are kind of unsure.
I will say think long and hard on it and don't limit yourself too much. When I got my Co-Motion I said these stupid stupid stupid words "I only plan on running a max of 35c tires and I don't want a dynamo too heavy", that bike has a dynamo (we drilled the fork at my old shop and got it wired) and 38c tires and that is maxed out with less room for mud clearance should I ever need it. Had I gone for wider tire clearance and the dynamo set up to begin with I could have saved money and time and could have gone with an SL fork meaning no wires connecting hub and fork. I was naive then and now I am stuck with it and it is still a great bike and I still love the bike but these days I would rebuild it differently as my tastes have matured and my love of comfort increased. However don't let that be a "don't do this" warning certainly get your dream bike just know there might be somethings you didn't want now that you do want in the future after you ride more and get a little older.
Quoted: 18427 Post(s)
Liked 15,582 Times
Likes For indyfabz:
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
I recently picked up another Rohloff hub for another project that is in work. I ordered mine from SJS Cycles. There is also Bike24, R2 Bike (I think) and others. All European.
Cycle Monkey used to be the US distributor. I have nothing positive to say about them & I am glad they are out of business.
Peter White is an option if you can figure out how to order from him and are comfortable with all of your relevant information sitting in an email inbox somewhere.
R&E Cycles is a "distributor" in the sense that they'll sell you one only in a wheel they built, but they'll only do it if they build the wheel. They do not use the Rohloff required Sapim double-butted spokes with the proper 2.3mm j-bend. They will build the wheel with bog-standard 14ga straight gauge spokes against Rohloffs requirement and will protest any deviation from their profit margin friendly choice to only use the cheapest spokes they could buy in bulk even if you offer to bring them the proper spokes personally. (I rebuilt my own wheels with the proper spokes & will never let them build me a Rohloff wheel again...Even if they are the best "Build anything you want" frame maker in the area.)
For a frame that is much cheaper than a full custom, it may be worth looking at Soma Fabrications. They have a variety of bikes with sliding dropouts that can accommodate a Rohloff. Also, Salsa has a few models with sliding dropouts (of a different design) that net the same effect.
One confounding factor in the commercially available mass market bikes available is the non-driveside shift cable routing. There are options of course to run full length housing and band clamps to secure and other variations along that theme. Full custom frames don't have that concern.
If you do go custom, Paragon Machine Works makes sliding dropouts galore to support disc brakes. Tange IRD (Interloc Racing Design ie Merry Sales) are an option for the same reason. A Bushnell eccentric bottom bracket is also another option, too. A Bushnell also means no messing with brake adjustments at all like would otherwise be necessary if you were to use sliding dropouts with rim brakes.
Here is a picture of my Rohloff bike from today:
by https://www.flickr.com/photos/145063776@N04/, on Flickr
Maybe you can study it for ideas?
Palmer
Quoted: 1671 Post(s)
Liked 1,827 Times
Get a frame, put a Rohloff on it. It's not rocket surgery.
Likes For tcs:
Quoted: 81 Post(s)
Liked 38 Times
My understanding is there are only certain frames that accept the speed hub with belt
im not an experienced bike guy. Not my field. I would want pro build.
will likely go with the Priority 600. I found a shop that will service Pinion.
Likes For MikeDeason:
I am potato.
Liked 1,631 Times
Something like this welded into the chain stay/seat stay: https://www.bikefabsupply.com/beltdrivesplitter
Car dependency is a tax.
Clark W. Griswold
Liked 4,006 Times
You are correct you do need a special frame that breaks for a belt drive the above poster had missed that. However with a chain tensioner you could put a Rohloff on a lot of different frames but if I am going Rohloff I want a belt and I want something nice.
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 133 Post(s)
Liked 304 Times
IDK of any off the shelf options; know that custom builders offer it.
And a moment of appreciation for the former Budnitz Bicycles, who offered a Rohloff option on their gorgeous bikes. Had a bunch of possible builds saved on their website but they went bust before I could press the "buy" option. Was ready for the upgrade from Alfine 11 on my commuter.
Quoted: 81 Post(s)
Liked 38 Times
I was about to order the Priority 600 when I realized it's 35lbs. I can't imagine a bike at that weight will be comfortable for my commute, which involves constant stop and go, often involving inclines. I have several spots where I can fly down a hill in a segregated bike lane, only to be brought to a dead stop at the bottom by a traffic light and then face a steep climb when the light changes.
My current Alfine/Gates equipped bike weighs in at 27lbs which is manageable.
Hack
Quoted: 347 Post(s)
Liked 191 Times
There are lots of framesets available out there that will accept belt drive at varying price points. I personally would be very tempted by the value of a build around something like a Soma Wolverine B-type (split seatstay & sliding dropouts so belt compatible) - but I would also love to get a frame built by a custom builder like Altruiste (on NB's Acadian coast) as a do-almost-everything bike.
Commuter
Bikes: Main Bikes: 2023 Trek Domane AL3, 2022 Aventon Level.2 eBike, 1972 Schwinn Varsity, 2024 Priority Apollo 11
Quoted: 238 Post(s)
Liked 323 Times
With Gates/Rohloff, you are looking at a multi-thousand dollar bike. Rohloff is the heaviest IGH there is, but also the most efficient across the board. The hub alone is $1200 or something, right?
With the Priority 600, one of the advantages to the pinion gearbox is that there are plenty of ratios, down to the very low. Climbing that next hill will not be a problem, unless you're wanting to do it quickly. It's a heavy and heavy-duty commuter. Priority is based in NYC I believe, and they value low maintenance over any kind of performance angle. Aside from being heavy, you also lose pedaling efficiency. A clean chain/derailleur runs at about 97% efficiency. Hub gears (even Rohloff) will cost you around 5% more, right off the top, and Pinion gearbox has even lower efficiency. It's noticeable on an unpowered bike, so you have to weigh that against the near-zero maintenance. Speaking of maintenance, there's no prescribed maintenance at 1 km or 3 km, as you say above, unless Rohloff is a LOT more maintenance-intensive than Shimano. (Shimano says every two years or 3,000 miles, IIRC) Did you mean 1000 km initial maintenance and 3000 km afterwards?
If you want a bit more performance from a belt drive in a lighter package, check out their Apollo 11 gravel bike. I'm fairly happy with mine.* It has the Alfine 11, which is a step up from the Alfine 8 in terms of # of gears and efficiency. Out of the box it is about 26 lbs.
More on hub vs. Pinion vs. chain drive here: https://www.cyclingabout.com/speed-d...arbox-systems/
Otherwise, for a commuter, it would be about impossible to beat their Current electric/IGH/belt drive bike. The electric takes the pain out of those bottom-of-the-hill stop signs, heavier bike weights and lost efficiency in the IGH.
* I feel the lost efficiency, compared to chain drive. Note from the table in the above link that the Alfine 11 is between 87-94% efficient, depending on gear. That 10% of your power, in some gears, just turned into heat. The Rohloff is 92-97%, but average is maybe 94%.
Also, I was not able to adjust the rear wheel to completely eliminate a small amount of rear brake rub. There is some adjustment designed into the rear axle positioning to tension the belt and align the rear wheel. I got that tuned out, but then when I tightened the bolts to lock it in position, it crept back in. It's minimal, but that, of course, will be another hit to efficiency. This is completely eliminated on a derailleur/chain drive with through-axles, where everything is perfectly aligned. If I could do it again, I would buy a gravel bike with drailleur gears and through axles and just grudgingly accept chain maintenance. Some of the cost saved by eliminating the Gates belt drive and hub would go toward through axles. For now though, I'll just accept the lost efficiency and realize that I'm not in danger of winning any races; that's fine for a commuter.
Quoted: 626 Post(s)
Liked 401 Times
Smaug1: Efficiency on a chain drivetrain that is clean and not at a far angle running through the derailleur is not realistic as to what is actually happening. Add some wear and dirt to that worn stretched chain and the Rohloff with the gates belt is not so much different in efficiency.
Palmer
Liked 1,827 Times
I am potato.
Liked 1,631 Times
But not really.
https://www.veercycle.com/products/split-belt-pro
Do you have any experience with their system? It seems about time Gates has some competition. I'm already thinking of which of my bikes I can upgrade just to see how the system performs.
Quoted: 133 Post(s)
Liked 304 Times
I had heard of Veer but hadn't realized that in the time since they have become a real company with an actual saleable product. Good for them.
I'd be leery of buying a bike with this in lieu of a Gates-compatible bike, not knowing the company/system's longevity.
I completely grasp the appeal of belts. But have you looked at the price of belts? Last I checked, Gates was about $80 a pop, and the Veer linkable one noted above is $150 each. If you ride a lot, that adds up.
Rohloff is a class act, never heard anything bad about one. Good seals, consumer changeable oil bath for everything including main axle bearings, that saves a lot in (LBS, if capable) annual cleaning and regreasing of lesser hubs if ridden in the rain. Some loss of efficiency, but better than most IGHs. And it's a total solution, not combining IGH and derailleur gearing like some.
I was excited about Pinion, but when I first looked, only found on bikes $5000+. I was not aware of the efficiency issues. I also need to carry my bike up stairs, already at weight limit, so heavy IGH or Pinion would make that marginal. That's also why I don't go electric, but also because I ride for both utility and exercise. Climbing the hills is the best exercise.
Quoted: 539 Post(s)
Liked 466 Times
But not really.
