How much does your loaded bike weight?
Bikes: 2009 SE Draft (I know, I know)
Im wondering how much weight you put on your bike and if its safe? I have 19lbs of cargo on my 28lb 09 fuji crosstown 4.0s rear rack and am wondering if thats ok?
If it makes any difference, Im running a 700 35 tire which should put out a little flex.
Quoted: 1185 Post(s)
Liked 842 Times
I'm not trying to hijack your thread, but I had the same thoughts the other night when I weighed my bike. I put a new wheel set on it with bigger tires, and was wondering about the weight. I almost posted a threaad at that time wondering what some of the other folks' bikes where weighing in at. Mine is a 58 cm Volpe and with racks, fenders, seat bag and pump weighs in at 31 lbs. My gear on the last trip weighed 40 lbs without water. So, approximately 70-75 lbs loaded.
Flying Under the Radar
Bikes: 10' SuperiorLite SL Club | 06' Giant FCR3 | 2010 GT Avalanche 3.0 Disc
I road on 700x32's Double walled rims with about 80-90lb total weight not including a rider. I had no problems. 3k miles later it's about time to replace cassette though.
No worries... All my weight is pretty much my 14lb Kryptonite New York chain. lol. I have though long and hard about carrying it on the rack in my trunk bag. I hate the weight of it but love the security as it can go though the frame and both wheels and still go around a tree at 5'5" long.
another question: would it be better to put my heavy chain in a backpack as it might spread the load to the center of the bike? mind you I dont have double walled rims i dont think
Thanks ahead of time.
Liked 842 Times
Hi again,
I just did what I should have done before: looked on Bikepedia at the Fuji's specs.
It has Weinmann CN-520, 36-spoke rims with 2mm stainless spokes. I suspect that you can get away with the weight you are talking about easily. I used to tour on a Trek 1000 with 25mm tires, carrying about 30-35 lbs of gear. I had the stock wheels on it which had 32 spoke rims. I still ride the bike alomost every day (with 23mm's), and never had a wheel problem. The Bianchi in the picture above has several thousand fully loaded touring miles on stock 32 spoke wheels and 28mm tires. I just put really big tires on it--32mm's!
Hi again,
Thanks.
www.Click-Stand.com
Bikes: Owner built touring & tandem
My bike w/racks weighs in at about 32 pounds. On our last Sept. tour I added 55 lbs. of panniers & gear. I know that I am probably lying, and it was 60, but then I mailed home a bunch of stuff along the way. My wheelset seems almost bullet proof. Rear = Phil Wood 145 zero-dish tandem hub; 40 hole Sun Rhynolite soon to be Aeroheat; triple butted spokes. Front: 36 hole Hugi tandem hub.
Bikes: Cervelo Soloist, Giant TCR Advanced, Co-Motion Americano Co-Pilot
There's another tread going on this subject and following it, I began to make some sense of the weight issue. The weight ranges that folks gave varied widely...say 60 pounds on the low end to 100+ pounds on the high end, which perplexed me until someone provided a blinding glimpse of the obvious.
Weight is a function of many things....
what you can afford (Kindle book vs. "real" books, down bag vs. synthetic bag),
what repairs you are comfortable making (patch kit, CO2 and tube vs. spare tire vs. spare wheel, multitool vs. "real" tools),
how you personally define comfort (Pillow anyone?, separate sleeping clothes?),
what it takes to make you happy (how about a chair?,
are you cooking?, "real" food vs. freeze dried),
what type touring you are doing (fully supported vs. credit card vs. completely unsupported) and
what conditions you expect to encounter (mild temps and clear skies vs. cool and rainy vs. bitter cold and snowing).
Someone doing a couple day tour in a temperate climate will probably need less equipment than another who's on a multi-month tour in "four seasons" conditions.
Bicycling touring means different things to different people, so comparing weights between touring cyclists is a bit of an apples and oranges exercise. I think in order for this exercise to be meaningful, you have to narrow and better define the comparisons.
Bikes: Tour Easy, Linear USS, Lightening Thunderbolt, custom DF, Raleigh hybrid, Felt time trial
28 lb bike, 45 lbs gear/water, 170 rider = 243.
27lb bike, 28lb gear, 5lb water, ~5lb food, 170lb rider = 235lbs. This is for extended 3 season self-sufficient touring on roads in the US.
All my gear and food is on the rear rack. My wheels have 32 1.9/1.7 DB spokes laced to Mavic Open Pros. My rear tire is a 32mm Panaracer Ribmo.
Is is almost always better to carry weight on the bike rather than the person when touring. Schlepping a 14lb chain on your back will wear you out! If do want to center the weight you could try using a top tube pad and wrapping the chain around that.
Bikes: I own N+1 bikes, where N=0.
Quoted: 35 Post(s)
139 pounds, plus rider, at the one opportunity I had to weigh it. I don't recall what my food and water supplies were at that time. The bike, without panniers weighed about 35 pounds.
Quoted: 3483 Post(s)
Liked 1,483 Times
Another six plus year old thread being resurrected.
Like I said on the redundant thread started on this same topic..
How much time off are you getting for your Vacation?
