Is 5 speed SIS different
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
I am a bit confused. I did an upright conversion to a 72 Schwinn Continental for a son. It worked nicely in friction mode. I thought I would treat him to aluminum wheels and indexed, as he seems to enjoy the bike. I got a Shimano 5 speed SIS thumb shifter and an Exage Motion rd. I was using a bent tooth 14-28 Shimano freewheel on it and of course all index cable housings. No luck, as it seems to pull a fair bit too much cable.
I am confused. I successfully went indexed 6 speed on my vintage Super Sport so thought this would be easy. Am I missing something?
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
https://www.bikeforums.net/classic-v...freewheel.html
Shimano 5-speed and 6-speed shifters are made to index with the 5.5 mm spacing between sprockets on older 5- speed and 6-speed freewheels (or even, some new freewheels made as replacements). Without indexing, and because chains with protruding rivets are no longer widely available, https://www.sheldonbrown.com/speeds.html
Quoted: 2338 Post(s)
Liked 2,827 Times
personally, at 5 speed, I would just leave it as friction. it will be smooth shifting with the toothed rear. I had this on a 1x8 town bike setup and it works super nicely
Quoted: 583 Post(s)
Liked 699 Times
That is what I thought
Quoted: 4209 Post(s)
Liked 3,875 Times
A common reason for almost but not quite proper cage travel per index click is improper cable routing at the der anchor bolt. Also Shimano twist tooth freewheels (Uniglide cogs) were made years before indexing came to the market. There's no reason why Shimano would make those cog set spacings to a future and yet to be designed spec. Not saying the cogs are a different C-C spec but one measurement is worth a lot of ink. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 583 Post(s)
Liked 699 Times
Yep, checked cog spacing vs several other freewheels I have. I also paid attention to the cable routing at the cable anchor bolt at the derailleur. I may try it in a different orientation too. Thanks.
Quoted: 1944 Post(s)
Liked 2,164 Times
If you are pulling too much cable consistently across the cogs, you might be able to use a hubbub alternate cable routing at the rear derailleur.
Alternate cable routing was born out of DA 74XX compatibility and Shimergo of mixing Shimano and Campagnolo components.
It works on the premise that where the cable is attached effects the amount it moves; like a fulcrum. In essence moving the attach point closer or further from the pivot impacts how much a derailleur moves “up to a point” for the amount of cable.
It might also work with a 7 speed shifter, but it does take some experimenting. I think it is about a 10% change. And depending where you position the tab you can fine tune it. With the spacing on a 5 speed freewheel you should be able get close enough.
John
John
Quoted: 583 Post(s)
Liked 699 Times
I will explore several of those options perhaps
