How do you cut ergo cable housings?
Cat None
Bikes: LOOK KG 461, LeMond Zurich, Giant Talon 29er 0
Thread title speaks for itself.
Quoted: 2026 Post(s)
Liked 1,096 Times
For Shimano STI shift housing, I use a Park cable cutter and smooth the cut end with a flat file. A needle or thin nail is used tol round out the inner liner. I assume Ergo housing is constructed the same way and would be cut with the same technique.
A Dremel with a cut-off wheel works but tends to melt the plastic outer layer.
Liked 1,096 Times
Originally Posted by vrkelley
If you do that, won't water get into the frame?
Just biking along....
Bikes: Scott Scale Ltd custom build.
Originally Posted by HillRider
Huh?
+1
Hahahhaa.... I just find it hillarious when you have ABSOLUTELY no idea what someone's getting at!!
