I have a problem and I need help.
Quoted: 5 Post(s)
For the past several months, my friend and I have been training and preparing to go on a 3000 mile long tour of Europe. I am five days into the trip and I am in a very unfortunate event right now. After day 2, I started to notice a lot of pain in my knee. It started to become really painful. I took strong ibuprofen to lessen the pain and keep on cycling hoping that it would go away, but it hasn’t. But that’s not the worst of it. On day number four, I started to notice pain in my Achilles tendon area. It started to persist to the point of becoming unbearable. We had to cut day four in half and this is where I am now. We are taking an unexpected rest day in an unexpected location trying to figure out exactly what to do. I have checked my saddle height and pedal position multiple times. I have adjusted everything according to research and nothing has helped. I can barely even walk. I don’t know what to do. Any wisdom or help in this situation would be greatly appreciated. I have very little Wi-Fi and I am in a different time zone, so forgive me if I don’t respond right away. I’m scared that the answer might be that my tour is over, but I want to know if there’s any other options. By the way, this is all happening only in my right leg. Left has had no problems
First things first, on a long tour like that, you have to listen to your body. Popping pills is a temporary response and potentially dangerous if you do that daily on a long tour. You could be doing long term damage to yourself.
Secondly, you say that you have trained? Does that mean cycling similar distances to what you are doing now with similar weight on the bike?
If yes, then what has changed since your training? Weight? Distance? Speed? Footwear? Pedals? Roadsurface? Shoes? Had any work done on the bike? Hills?
If no, then you're finding out why it's a good idea to do some shakedown rides. You'll have to learn how to ride the bike comfortably. (Sorry, don't mean to be a smartass, but that's waht you really need to do).
Thirdly, check out the bike. The issue is only on one side, correct? Check your crank & pedal. Check the saddle, not height necessarily, but where it is pointing. that may be putting strain on one side of the body.
Next, get checked out by a medic. Are you European? If so, you should have free emergency health cover in another European country. If not, you'll have to make a choice of whether it's worth paying for or if your insurance will cover it.
Finally, listen to your body. Cycle and try to isolate when and where the pain is originating. Make adjustments accordingly to saddle (height, angle, direction) and possibly handlebars.
Explain your situation to your partner. Change your pace/distance to suit your needs. If you can stay put for a day or 2, or head for somewhere more interesting where your partner can amuse themselves while you rest.
Welcome to the world of touring! It's the adversity that you remember and gives the most satisfaction when you overcome it!
I remember one time heading off on a long tour. don't know what I was thinking, but at the last moment I had the idea that if I raised my saddle I'd generate more power and travel faster. So I did. Day 1 my ankles were tender. Day 2 my ankles were very sensitive. Day 3 my ankles were in agony & I could barely walk off the bike (on the bike was ok). Day 4 I could not walk.
At that point I realised the folly of my ways! Lowered the saddle, soaked a pair of socks & strapped them tightly around my very swollen ankles. It took about 2 weeks to recover fully. Lesson learned!
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Good advice above. We're not doctors here, and even if we were it would be folly to diagnose over the internet.
Taking pills to mask pain is like removing a smoke detector during a fire.
Rest and recover. Remember the acronym RICE: Rest, Ice, Compression, Elevation.
Be flexible and listen to your body. Battle plans never survive first contact with the enemy.
For future trips, a good tip I use is to train to 30% of the needs of the trip. For my last big trip, my goal was to cycle 600 miles per week, an ambitious pace for me. I "trained up" from my normal 100 miles per week to 200 miles per week (over the course of half a year), and it went exceedingly well.
Every day a winding road
If an activity is causing pain, the best thing to do is stop the activity. Plan B? Lots of trains in Europe.
Quoted: 761 Post(s)
Have you done this before?
Sometimes its not the bike just that your body is not used to day in day out riding. Remember also if your camping then your body may not be recovering each night sufficiently.
Quoted: 5 Post(s)
Thank you
Thank you all for your responses. Of course I know this isn’t the doctor diagnoses, however any advice from people who have been in my situation or know a lot more than I do is always good to hear. So, thank you for your responses! I will take it all into consideration.
Quoted: 3462 Post(s)
Liked 1,468 Times
If you try to keep riding, gear down and use very little torque. I say this because several years ago I was on a fully supported tour in Europe. One gal in the group was a nurse practitioner and she blew out her knee. (She described what she did in all the appropriate medical terminology, which I of course did not understand any of.) But she did not want to ride in the van each day, kept riding but at slower speed and with high cadence. That way she put very little stress on her damaged knee because of the lower gears. I am not saying you should continue to ride, but I am saying that if you try to continue try the lower gears. I gave her a roll of vetwrap but she never used it. (The elastic wrap that vets use is cheaper than the stuff humans use, but works the same.)
I do not know enough about your situation to know if you were doing something to try to lessen the pressure on your knee which cause the achillies tendon or if there is something else going on. But I would not be surprised if you were trying to use different muscle groups that caused your second problem.
Last spring on a short five day tour near home, at the end of the first day in the campsite I added a knee brace that I always take on tours in case I need it. My friend I was traveling with asked about it. I said, I managed to keep up with you today, but my knee does not feel very good, so starting tomarrow I am going to ride at a pace I am more comfortable with. So, won't be riding with you. Rest of trip my knee was just fine, I quit trying to over-exert myself by trying to keep up with a stronger rider.
I have not stood on the pedals to accelerate from a stop or to power up a hill for over a decade. Instead I gear down and spin up the hills, or get off and walk. Since then my knees have been a lot better.
Quoted: 18381 Post(s)
Liked 4,512 Times
Maybe a few details?
How far are you riding a day? Terrain? Gearing? Weight?
Is it possible to completely unweight your bike... transfer it all to your riding buddy? Box up what you don't need and ship it home?
You may get better with a couple of days rest, but you still need to do some serious changes to your trip.
- Lighten the load?
- Decrease weight?
- Decrease mileage?
- Decrease speed?
- Perhaps take the train from city to city, then ride the bike around the city and to surrounding small towns.
- More rest days?
- Call it a false start, go home, and try again later?
Nothing compares to the simple pleasure of a bike ride - JFK
Liked 4,512 Times
In the end, you'll have a lot of personal choices on how you wish to deal with this, pain tolerance, and whether you think you'll do any long-term damage.
Quoted: 136 Post(s)
I have had the achilles thing. About two weeks into a trip both achiles started hurting really bad after about 10 mins of riding. No rhyme or reason, I had ridden thousands of miles and was in good shape. After about an hour it would go away.
I was too far removed from anywhere to do anything, so since it wasn't life-threatening I just pushed through it. Really painful though, but it did eventually get better after about a week and a half. I kept them warm all the time and tried to stretch before getting on the bike.
As for the knee- I wouldn't keep riding for that, you might do permanent damage. I've had knee issues too that resulted from using pedals with too much lateral play. I switched to Dura Ace style locked in tight and never had another issue. That was road cycling though.
Did you switch pedals or something? Have you tried a shim for either leg (it sounds like one leg may be shorter than the other, which is pretty common)?
Quoted: 1182 Post(s)
Liked 833 Times
Where is the knee pain, i.e., front, back, or inside outside of knee?
If you have access to the internet, check this site out: https://www.bicycling.com/training/a...my-knees-hurt/
Taking something into consideration means you'll do it your way. We're trying to help. The first guy who responded said it best. If you really did train long enough and correctly, then this shouldn't be happening. Doesnt make sense. Ive been on many tours (my first was also Europe) and never had pain or discomfort from riding. And why is everyone mentioning standing while riding? Who does that on a tour??
if you go back to your other thread you'll see the problem(s).
https://www.bikeforums.net/classic-v...annondale.html
"...I will be embarking on a 3,000 mile cycling tour of Europe from Portugal to Slovenia. Let me tell you that I have no cycling history or experience at all ..."
"....It's is a 57cm frame and I am 5'7". I fit a 53cm. I have to lower the seat almost all the way ..."
"...I have to lower the post 95% of the way down for my legs to extend properly...."
when it came time to purchase my bike,... I found a “1999 Cannondale T700” For $250 and it was perfect for what I was looking for. I couldn’t believe it. Now, I don’t have any knowledge about bikes,....After having the bike shipped to me, I eventually got to the point where I was researching my bike because the frame size was just a little to big and I wanted to see if there was another one that could potentially fit me...."
you've embarked on a 3000-mile tour over some rough terrain with no real training. your body isn't ready.
your bike is too big for your body, so assume you're leaning to the side when you push down, favoring one side more than the other.
Bikes: Two. One daily rider. One with detachment issues.
Quoted: 53 Post(s)
saddlesores nailed it.
Your knee pain is clearly from overuse ... likely aggrevated by an improper fit. Regular riding strengthens the knee joints (thickens tendons and ligaments), then specific touring training builds from there. You appear to have skipped those very important steps. You should halt the tour or drastically reduce the distance, either by shortening the route or covering some of the miles by some other means of transportation. If you must continue, please do as others have suggested ... gear down and spin, reduce daily miles, more rest days, ice every night, listen to your body. You can do real damage to your knee if you try to tough it out.
^^^ Crucial information missing from this thread. OP, you should go to a good bike shop and have them look at the fit. Make adjustments if possible, or get a properly sized bike.
so the bike does not fit, and you are damaging your body.
you are 20 years old. wanna spend the next 60 years limping?
you are a few days into a long tour, and already in pain.
assume still somewhere in portugal. it's decision time!
continuing the current tour under these conditions is unwise.
first, can you switch bikes with your riding partner?
take a few days, a week, to rest, you and your partner can check
the maps.......find a less extreme route. no climbing, shorter days.
more time spent seeing the sights on foot, less time in the saddle.
google you some bike shops in amsterdam, see about renting
a bike from a shop there. one that can store your bike...or
sell it on commission.
how about a tour of holland and northern germany?
Liked 1,468 Times
Today while doing a long exercise ride, I thought of one more thing you might try. This is specific to your Achilles tendon, not the knee. I found that my foot was happier when I moved my cleats back about 10 mm from where the ball of my foot was. (I use shoes and pedals with SPD cleats, I do not know if you do or not.) This means that I am using the foot muscles less to push down on the ball of the foot than if my cleats were further forward. The downside is that I have more toe overlap with front wheel and fender.
Quoted: 53 Post(s)
Did you seek a doctor? in Europe you won't go bankrupt, for seeking medical care, even if not a citizen.
