How to clean (road-)cleats
Hi,
I ride on Shimano road pedal system.
The other day I was riding and had a flat so had to walk on the side of the road to find a place to repair and my cleat is now covered with dirt/mud/...
I tapped it on the road to wipe the excess, so clipping-in and out was doable...
But how to clean it for good? knowing that the soles are carbon...
Thanks!
Thanks!
Bikes: Provex (centaur carbon) 2009 - cube litening super hpc race 2013
Just get some water, and maybe some soap.
Let the dirt soak up some water to get it to soften up a bit and than just use an old toothbrush or something.
That should do the trick but any other way would do so too.
You can also use a pressure washer, most of the pro cyclocrossers do it this way.
Location: Perth, Australia and sometimes Penang Malaysia
Bikes: Litespeed L1r, Litespeed Ghisallo 07, TCR Advanced Team SL 0 ISP, Giant TCR Advanced SL, Giant TCR Advanced Team - T-Mobile, Giant Propel Advanced SL
just hose it all off
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
As long as you can clip in and out, don't bother. The rest falls out when its dry.
Quoted: 18424 Post(s)
Liked 15,580 Times
Seriously?
Bikes: Specialized Roubaix SL3, Lynskey Cooper CX
Whatever you do, DO NOT simply spray off the dirt with a garden hose like you would any other shoe. It will be too much for the carbon to handle..
Administrator
Liked 2,180 Times
A garden hose is okay as long as you don't use a nozzle. Carbon can take water without the pressure.
Hey!
Would a water nozzle cause my carbon soles to asplode?
Momento mori, amor fati.
Administrator
Liked 2,180 Times
It might. I would let someone else try it first.
Middle-Aged Member
Bikes: Bianchi Infinito CV 2014, TREK HIFI 2011, Argon18 E-116 2013
Quoted: 24 Post(s)
I just scrub it with a nylon brush (dry) and wipe the rest off with a clean shop rag.
Liked 15,580 Times
Must Go Faster
Bikes: Trek Madone 5.9, BMC Road Racer SL01, Orbea Aletta TT
You can't, once they are dirty they must stay that way
