Hydraulic disc brakes after period of no use
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
My son has a MTB (a little nicer than entry-level Jamis) that has hydraulic discs. We got the bike in 2020, and he only rode it occasionally up til about a year and 1/2 ago, and hasn't touched it since. "Light use" would be an understatement. He's interested in getting back out there, but I'm strictly a rim brake and mechanical disc guy on my bikes, and have no experience with hydraulic brake maintenance. I've examined everything I can--pads, etc, and as expected that stuff is fine--like new really. The pads are barely worn. The brakes appear function fine--the feel as they did when it was new. But do we need to bleed the brakes after this long a period of no use?
They’re probably fine. If they feel bad or have significantly uneven bite point then consider a bleed.
Quoted: 94 Post(s)
Liked 151 Times
Clark W. Griswold
Quoted: 4361 Post(s)
Liked 4,002 Times
Generally I just pump the brakes a few times and everything is good. The only time I would consider if you are using DOT fluid like most SRAM brakes but if mineral oil you should be fine. If the bike was stored upside down which I would hope not then air could be introduced to the system but usually a couple pumps and all is good.
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
This is simple...Ride downhill really fast. If the brakes don't slow you down, and you crash and die, you'll know the brakes need to be bled.
Likes For oldbobcat:
I have a bike with hydraulic disc brakes and they need several pumps in the spring, after a winter off, before the function as actual brakes again.
