Pump says 90 psi
#51
Quoted: 768 Post(s)
Liked 1,744 Times
hit it with a couple of drops of WD-40, that should loosen it up
#52
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
#53
Quoted: 768 Post(s)
Liked 1,744 Times
Yea I know it not a lube, but it will help loosen if there is something that is making it stick as it is more of a light cleaner, water displacer, and anti corrosion product. (not for chains, but lets not go down that rabbit hole), which is why I said a couple of drops to help loosen it
#54
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
#55
Quoted: 2700 Post(s)
Liked 486 Times
What would you set it to if you could adjust it? I think 65 is a good pressure for bikes, the ones with skinny tires will suffer but probably won't break for most people. I run mine much higher, but thats besides the point.
#56
just pump until the tire explodes and then pump less next time.
#57
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
42 is said to be the answer to the Ultimate Question of life, the universe and everything, so that’s a good number. Nearby you have 41, 43 and 47 which form a triplet prime. Or maybe 28, which is a perfect number?
BTW, my experience is that tire pump gauge readings are reasonably consistent, but not at all accurate. If you really want to know the actual pressure, you should get a good pressure gauge. OTOH, you can just note what the pump says and adjust until you know a number that seems to work. It probably won’t be accurate, but what does it matter?
Otto
#58
Quoted: 7652 Post(s)
Liked 3,479 Times
Likes For Maelochs:
#59
Liked 3,479 Times
By the way, the above post is not meant to be insulting. Post #55 is a really well-considered under-bridge question---feigned ignorance, fake faulty reasoning, ridiculous advice .... perfectly tailored to get responses.
@jetboy and @ofajen responded in way I would call correct. Entertainment appreciated.
Likes For Maelochs:
#60
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
A year or so ago, a Larry thread like this would be at 6 pages by now.
#61
Klaatu..Verata..Necktie?
Quoted: 10436 Post(s)
Liked 11,912 Times
65 is a good pressure for me to pinch flat on the slightest of bumps.
#62
Liked 11,912 Times
Now we're all too cynical, demanding he entertain us, and we spend half the thread talking about talking about Larry, rather than responding, as we used to, with a mix of helpfulness and disbelief.
Likes For genejockey:
#63
Quoted: 2484 Post(s)
Liked 2,956 Times
Likes For Trakhak:
#64
Quoted: 3513 Post(s)
Liked 2,927 Times
#65
Quoted: 3953 Post(s)
Liked 7,299 Times
#66
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,644 Times
If Larry was shirtless, smoking a joint at the bottom of an hill to race people up, we might have something.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For Calsun:
#69
Liked 7,299 Times
Likes For tomato coupe:
#71
Liked 11,912 Times
"Wish I didn't know now what I didn't know then."
#72
Liked 7,299 Times
#73
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Likes For datlas:
#74
Grupetto Bob
Liked 5,644 Times
Likes For rsbob:
