Bianchi from the 70s 80s or 90s ? Help !
Quoted: 9 Post(s)
HI all those out there, I need help with identifying this frame and fork ? Do you know what frame it is ? Made of steel but which kind and from which year ? What would this frame be worth ? Its in really good condition.
@Bianchigirll
do you maybe have a clue ?
Pics here..
@Bianchigirll
Pics here..
Quoted: 4722 Post(s)
Liked 3,040 Times
I see nothing to indicate that this actually is a Bianchi. The dropout still has its derailleur hanger and chain stay cable stop, so I assume the absence of top tube cable tunnels and shift lever bosses is OEM condition and not a case of drewing. These features, in conjunction with OEM bottle bosses would suggest circa 1975-1977. The frame appears to be high grade but even during this period the upper end Bianchi had embossed stay caps and I can't recall seeing any Bianchi with that style of lug cutout. Do you own the bicycle or is it just under your consideration for purchase?
Likes For T-Mar:
Quoted: 795 Post(s)
Liked 1,797 Times
I would agree probably not a Bianchi also the fork is likely not original to the frame. As presented no id repainted mislabeled I would say $75 for the frame set. With the not so great kinda ugly SS/FG build only $175 for the whole bike. If considering buying this bike IMHO the OP should pass.
Quoted: 9 Post(s)
Yes im considering purchasing this only if its Bianchi. But then again im not sure the frame is one. Its going for 390 USD
Quoted: 9 Post(s)
Quoted: 795 Post(s)
Liked 1,797 Times
Hard to tell with the heavy powder coat but the dropouts look to be Campy 1010 which were used by nearly every Italian builder along with a lot of British makers and many US builders during the 70's. So about all you can tell from these is it's a nicer mid level frame.
Bianchi Goddess
Quoted: 2938 Post(s)
Liked 2,941 Times
I agree I don't think it is a Bianchi. I would expect to see at least a B on the head/downtube lug if it was oldeer than '88 and may be still Bianchi on the dropouts. Did Bianchi ever ues a window lug on mid grade frames? But it could be from a European market, just where are you and the bike?
The use of the front wheel retainers to adjust the rear wheel is interesting.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Quoted: 9 Post(s)
He says its a bianchi and but im not so sure. I mean He is Italian so maybe its true ?
Here is the link if anyone is interested in helping me decide if i should pull the gun on this or not ? If its authentic Bianchi i will get it. As its a flip flop so i can have a choice as a fixie or freewheel single speed for urban riding. zukahn1 T-Mar Bianchigirll
What do you say ? Is the price right ?
https://www.ebay.co.uk/itm/Bianchi-B...0603%7Ciid%3A1
Jeremiah
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 345 Times
Regardless of what it is...and I would listen to the above about it not being a Bianchi, it is not worth that asking price. The paint looks awful and it's a mystery frame frankenbike.
Likes For KonAaron Snake:
Liked 3,040 Times
As I stated earlier, it does appear to be a high grade frame but I see no evidence to suggest that it is a Bianchi. The Campagnolo 1010 dropouts were widely used on high end models from the early 1970s through to the introduction of the Portacatena dropout for the 1978 model year. I've seen embossed stay caps on high end Bianchi with confirmed serial numbers as early a 1973, so the lack these embossings on the subject frame makes the stated Bianchi lineage suspect. Also, none of the Bianchi that I've seen from the subject period have used the chainstay to dropout transition with the distinct lip. Speaking of this lip, the drive side seats stay end shows a distinct offset in the lip with a crack leading up to a void, as if there was a failure at this point that was repaired.
As to value, I have no appreciation of European market conditions, so I'll defer to other members.
Quoted: 9 Post(s)
Alternative
Thanks all for your great Input. You have made me see what i couldn't . I'LL pass on it then. BUT what do you say to the following ? Its going for like 400 Eur a shade under 500 USD. Nothing comes cheap in Copenhagen !!
This seems to be legit B Rekord 642 from the 80s I presume ? Do you guys agree this is the real deal then ? And if so is it worth for a single speed conversion of a vintage frame ?
Quoted: 795 Post(s)
Liked 1,797 Times
Yes this one is a real Bianchi being a lesser mid level model with a yuck cheap coaster brake build the price is way high in the US this would only be a $150-200 bike in most markets. In the $400-500 price range you should be able to do a lot better if your looking for SS/FG Bianchi you can likely find a Echo Pista that is a real SS/FG and not a cheap conversion.
Edumacator
Quoted: 2463 Post(s)
Liked 3,174 Times
From England...
This is the one I would invest in...
https://www.ebay.co.uk/itm/CIOCC-CLA...AAAOSw64Ncmlkn
Bianchis
https://www.ebay.co.uk/itm/Bianchi-V...MAAOSwXC1c2niQ
https://www.ebay.co.uk/itm/Bianchi-b...sAAOSwC5Rcxc8J
https://www.ebay.co.uk/itm/VINTAGE-B...kAAOSwYsxc6rnr
Bianchis
Liked 3,040 Times
The 2nd offering is a legitimate Bianchi, specifically a 1982 model. It is Italian, as opposed to being one of the early Japanese manufactured frames. As noted, this is a mass produced mid-range model with tretubi Columbus Sl,at best. It may be even lower grade tubing, as tretubi SL models,would typically have down tube shift lever bosses during this era., though European Bianchi models do not always directly correlate with American models. Also, it is another repaint. Again, I have no appreciation for European market conditions but in America there is no way that I would pay even close to the asking price.
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
But I wouldn't butcher it into a fixie either. If you want to do that, get something that's really disposable; alternatively as has already been recommended, get a bike that was designed as a fixie.
Quoted: 9 Post(s)
Quoted: 795 Post(s)
Liked 1,797 Times
Well this one is 3x better than the other 2 for a Eureo style cruiser but still overpriced. Nice bike but worth only 250 plus shipping/
Quoted: 605 Post(s)
Liked 480 Times
@JerryBerry you gotta remember - when considering "what's good value" - the EU market is incredibly different to the mostly US advice you may get here... and then again, the EU market is also different from one geography to another. Generally, I see the US market is much more competitive and there are much better deals to be had on bikes in the US... or maybe I'm just used to paying Dublin prices, and everything else is inexpensive by comparison (similar to Copenhagen, perhaps?)
I will say, the technical advice from this forum is second to none.
Back to the money thing: I recommend patience, and to track (for some amount of time) what's available and what's selling in your region, to get a feel for the market. As you said, "nothing comes cheap in Copenhagen!". If you know what you're looking at, and know your market, then maybe what's ridiculously overpriced for Florida (or Iowa, or New Jersey, or Boulder...) is quite fair for you.
I'm not sure about exactly what you're after - must it be a Bianchi? Don't get me wrong, I'm a huge Bianchi fan, I've got three of them... but you've got loads of bikes at your disposal, really nice ones.
Quoted: 9 Post(s)
Modern Alternative
I appreciate all the input i get here which really helps me decide. What is clear is that prices in Europe are certainly a little higher but as you all mentioned its about being patient and scouring the market.
This has led me to this , the 2013,14 Bianchi Pista Sei Giorn here in a FLIP FLOP variation and the TREK Urban District single speed with belt drive. I know these new ones are made in Taiwan and that is making me a little reluctant.
but the price i was being quoted here in Denmark for the Pista was 600 Eurs /680USD and Trek for 400Eur/450USD.
I will try them both and see how i feel on them.
The pista comes with some good parts i think
Wheels: Miche Pistard Hubs Miche Primato Pista/Strada FlipFlop Hub Crank arm: Miche Primato Handlebar: Cinelli Pedals: Shimano spd pd-M530
shihitemuslim
10
07-09-17 08:16 AM
Ashiquor
6
01-13-15 06:18 PM
