How to install a saddle on a seatpost with a top facing bolt
Bikes: Bianchi Infinito
I'm a bit embarrassed to ask this question because it seems like it should be a no-brainer, however I did a ton of research and I can't figure it out. I probably don't use the right vocabulary hence no good result come out.
So I recently purchased a new Bianchi Infinito XE and I am trying to swap the original saddle for my own. On my previous bike both bolts holding the seat clamp together are down facing, i.e. accessible from below the saddle. On the new Bianchi one of the two bolts is facing upward and only accessible through the saddle cutout. This is fine when removing the original saddle however my saddle does not have a cutout, so I have no way of tightening that bolt. There is not enough clearance to get an Allen wrench in there. There is a knob-like thing on the front bolt, but I couldn't dream to tighten it to 1 Nm, let alone the 8-10 Nm recommended.
I would go and ask the LBS but they are so busy right now they can't help anyone (some are downright dismissive when asking for help).
Any help, suggestion or reading material would be appreciated. Reading up I learned about offset seatposts, which this Bianchi Reparto Corse seems to be, but I can't seem to find examples that are bolted from the top and bottom...
PS: I have photos but new account can't post pictures.
Thanks
Thanks
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Thanks
Thanks
Likes For SoSmellyAir:
That's an interesting design choice. Thanks for the insight, I will try to figure out the size of the seat post and swap it out. Looks like it's slightly D shaped so hopefully that's standard and I can find something compatible.
Meanwhile I will try this, if I'm lucky the saddle won't slip when I ride.
The theory is that you tighten it past the desired angle by hand (although I used a pair of needle nose pliers), and then tighten the rear bolt to the specified torque and the forces acting on both bolts would more or less balance out
Liked 1,471 Times
I was shopping an Infinito CV and the seat post is definitely a feature in the "con" column, and that was before I even realized (from your post above) that it is not a round post.
I only use saddles with a cutout (because I need that) but I recently had to try what you're describing (tighten front/downward bolt first by hand ) and that worked fine - minor hassle. I'd rather find a new saddle than to replace a bespoke D-shaped seatpost. On the other hand, yeah, having a proprietary seat tube shape is a negative for me too in any frame design.
Liked 1,471 Times
Bianchi Infinito CV Disc in review | GRAN FONDO Cycling Magazine (granfondo-cycling.com)
Quoted: 18378 Post(s)
Liked 4,512 Times
Liked 4,512 Times
What a pain. The vintage Campagnolo seat posts also have a bolt on top (long before cutouts existed). But, one could usually squeeze a wrench up there if one persisted. Worse if the vintage seats have full sides on them.
Many of us have a few custom tools in our toolbox made for a one-time use like this.
What I'd probably do is take an Allen Wrench and cut off a 3/8" to 1/2" piece. Just long enough to fit into the hole and stick up a bit.
Now take a 12 point box-end (combination) wrench and tighten the stub.
This will depend a bit on the size, although I am finding a couple of mini wrench sets including "SPEEDWOX Small Metric Wrenches". The quality doesn't look great, but hopefully it is good enough.
In some cases there might be a reason to modify the handle on a wrench, by cutting, bending, or welding a cheater on.
Quoted: 1438 Post(s)
Liked 1,092 Times
Liked 4,512 Times
Another option along the same line of thought above...
get a 1/4" to whatever Allen head you have. Very common... HF has a zillion "security set" that would have it.
As above, cut either the 1/4" end, or the Allen end to meet your needs.
Then there should be a good selection of 1/4" wrenches that you could use.
For example, find a 1/4" ratcheting box end wrench. There are some that are offset, some with flex heads.
Liked 4,512 Times
I suppose the precision of the grind depends on whether the bolt just provides tension, or also controls lateral movement of the saddle.
You probably won't save a lot of space over using some kind of allen wrench stub + wrench.
Likes For CliffordK:
Thanks for linking my pictures CliffordK and thanks everyone for the advice. I think I'll start by trying the fiddly method of tightening the front bolt with my fingers and if it doesn't hold I'll find a cheap Allen 5mm that I can hack. I just really need to get that one off my bike because it's very uncomfortable. Also I don't necessarily want to change my saddle because I'm comfortable on the one I have and I don't know the first thing about finding a saddle that suits me.
Quoted: 1591 Post(s)
Liked 1,018 Times
Replaced the ancient unicantor with a cutout saddle so there was no problem.
I didn't realize it was proprietary when I read the reviews it was mentioned that it's a bit too big (so stiffer than it needs to be). These days though if you need a bike you can't be too picky given the bike and part shortage going on. I'll just hope that in the future if I need to replace it these parts still exist, would be a shame to have an unusable bike because of an odd shape seat post.
Quoted: 1529 Post(s)
Liked 718 Times
This is a big fat meh - you don't need special tools, just use the thumbwheel and a bit of trial and error to set your angle.
