2013 Trek Madone aero brake pads help please
Hello cult of bikeforums,
I an currently working on a 2013 Trek Madone 5.2 and need to replace the Brake Pads that are shot and pad removal bolt is stripped. I cant find aero brake pads that do not have that Fin on the middle on ebay or amazon.
can someone chime in .
Recap :2013 Trek Madone with integrated brake calipers. Caliper is neatly molded into the frame. Looking for recommendations on brake pads that come with the housing.
Quoted: 858 Post(s)
Liked 1,093 Times
First off you may be able to remove the pad set screws with a torx wrench as it can grab a stripped Allen head. If no luck, KoolStop for one sells a version of the Shimano holders without the fin. Dura 2 Triplelite Threaded – KOOLSTOP in black or silver and I'm sure there are others available from various sellers.
Likes For Crankycrank:
Quoted: 522 Post(s)
Liked 455 Times
Or you can buy new rubber pad cartridges already inside the holders. SRAM, Shimano, Bontrager, or Jagwire will work.
