Pedal twist off Q
Bikes: Trek 5200 and Trek D.S. 8.6
Pedal twist off Q
How hard should it be to twist your cleats off? My looks cleats are so hard to twist off.
Quoted: 5793 Post(s)
Liked 2,585 Times
I keep mine as tight as possible yet still allowing twist out. It's also a question of technique, a quick twist pops them off much more easily than steady pressure.
It's a personal decision but if you're a spinner you can go with less tension. But if you stand and sprint or climb hard in a high gear you want a solid engagement because unexpected release can cause you to lose control.
FB
Chain-L site
FB
Chain-L site
There's a release tension screw on the back of the pedal.
Check that your pedals are not jammed up with gunk.
You may also have worn cleats.
