Compressor vs Floor Pump with integrated air chamber for tubeless
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
Are those floor pumps with the built in air chamber for tubeless worth it? I'm finally running tubeless, but I don't own a compressor yet. I also could use a new floor pump. Will one of those suffice, or am I still gonna end up wanting a compressor?
Quoted: 630 Post(s)
Liked 369 Times
How often are you going to be changing tubeless tires?
Some tubeless tires (on certain rims) like Schwalbe Tubeless Easy or Maxxis Tubeless ready can mount with just a floor pump and some will even mount with no sealant. Or you can use a CO2 cartridge (as low as $1 for threaded) or use the gas station's compressor.
Quoted: 284 Post(s)
Liked 313 Times
Señor Member
Bikes: All of them
Quoted: 31 Post(s)
I got a cheap little pancake air compressor on sale from Harbor Freight a couple years ago for around $35. It's very worthwhile when setting up anything other than an ideal combo of tubeless-ready rims and tubeless-easy tires (which can be extremely easy to setup with a normal floor pump). I was even able to convert some super old wire bead Big Apples to tubeless on my commuter -- took quite a bit of finagling but once the bead popped fully into place they've been holding steady for months without problems!
Non omnino gravis
Quoted: 284 Post(s)
Liked 313 Times
Yeah, the more I ponder it, a compressor would be pretty handy to have around! Guess I'll get a new cheap-ish floor pump (I use a separate digital tire gauge anyway, so the built-in gauge's accuracy isn't important), and then look for an affordable compressor.
Quoted: 6974 Post(s)
Liked 10,975 Times
Quoted: 112 Post(s)
Liked 25 Times
I had a real hard time sealing my tubeless road tires using a floor pump. I have being using tubeless since 2011, and buying an air compressor made it much easier.
Make friends with the mechanics at your LBS and you'll get this done cheap/free!
Bikes: 2017 Specialized Roubaix Expert, Surley Karate Monkey 29er hard tail
Quoted: 79 Post(s)
livedarklions doesnt need a compressor or a pump, just a plastic, no, ahh check that, a certified high pressure hose good to 3000 psi, to blow through. : )
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
My opinion is a compressor needs to be rated 100 psi or more . they both do the same thing basically . a hardware compressor needs an adaptor or presta hook up . it really comes down to price you can find booster pumps a lil cheaper i think and use any pump including the compressor.
Air chamber pumps work really well for tubeless. And they're much lighter and more portable than a compressor.
As others have said, Compressor user here. I have a 21 gallon one for the house, and I had an old bike pump that was broken. I pulled the hose, attached it to a 5 dollar blow gun adaptor I got at Lowes, and it works great. My air compressor doesn't loose much air, so If I turn it off with 130 psi in the tank, it lasts me a month of air adjustments on me and my wifes bikes. Also, I have a Co2 tank in my Jeep, so if I go away from home, I throw my adaptor in my Jeep, and I can do quick fills where ever I am. Mind, I have a small bike pump on my bike too, just in case.
Quoted: 38 Post(s)
Liked 9 Times
Small compressor. I have a big one that runs tools really well but it’s really loud. A few years back I had a project that could benefit from an air nailer and Home Depot had a three-nailer combo with compressor for the same price as a single Porter Cable nailer.
I love that little compressor. I don’t hear it cycling in the garage so it’s no problem at all. It’s of course awesome for bikes, but even better for the cars. If I see my wife’s car looking a little low, it can just be taken care of, rather than hoping it gets remembered at the next fill up.
