fixing a drilled frame
Old 12-07-23, 07:58 AM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1152 Post(s)
Liked 341 Times in 251 Posts
Originally Posted by CrowSeph
It's a Legnano, but honestly does not seems a high tier. Even the model is not recognizable.
But the owner want to fix it. As now I need to find the local prices and then let him do his choice.
You probably know this, but one thing to look for would be a decal or sticker that says "Columbus" and "Doppia Spessore". If no sticker, I would suspect a unexceptional carbon steel.
WizardOfBoz is offline
Old 12-07-23, 09:46 AM
CrowSeph
CrowSeph's Avatar
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times in 101 Posts
this one, but is not columbus.
speaking of the wich, i have another bike branded toMasini (yes one M). In the past someone told me that frame use columbus tubes but the logo is missing. is possible to recognize the tubing?
CrowSeph is offline
Old 12-07-23, 09:56 AM
RB1-luvr
I don't know.
RB1-luvr's Avatar
Quoted: 317 Post(s)
Liked 853 Times in 446 Posts
you are right, that's first spot on the cringe list alright. eesh.
RB1-luvr is offline
Old 12-07-23, 10:38 AM
WizardOfBoz
If you can recognize the model number and year (from the serial number), you sometimes can find the spec in old advertisements and catalogs.
There is a technical way to identify alloy composition but its not common outside of steel mills and scrap yards. It's called X-ray Fluorescence. The analyzer costs about $10,000. View is probably not worth the climb.
Regarding the OP, Falck made some good tubes and Legnano used them in some high-end bikes (e.g. Campagnolo Gran Sport) so perhaps another way to assess the frame quality is by inference. Is the crank alloy? What brand? If the crank is a machine-lightened version of the campy Nuovo Record, and the handlebars and stem are Cinellli alloy, and the seat post is campy alloy and the seat is a brooks professional.. This may indicate a high end bike with frame to match. If the crank, stem, and handlebars are all steel then one might infer a more plebian model.
Likes For WizardOfBoz:
Old 12-07-23, 12:14 PM
CrimsonEclipse
Quoted: 559 Post(s)
Liked 648 Times in 381 Posts
What's the purpose of the repair?
To prevent frame failure or future cracking?
To prevent corrosion?
Improve looks?
If you want to keep the water bottle cages, your idea on rivnuts is really the best option.
If the any of the holes is a little off, you can slightly larger hole to properly center it and install a slightly oversized rivnut
(last resort)
Welding just seems unnecessary
(especially if aluminum)
CrimsonEclipse is online now
Old 12-07-23, 01:01 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3591 Post(s)
Liked 3,401 Times in 1,935 Posts
Sometimes you can find manufacturer markings on the tubes. Columbus and Reynolds used to stamp their tubes, but these marks are sometimes lost when the tubes are trimmed for the frame. Places to look are chainstays near the bottom bracket, the base of the seat tube, the tops of the fork blades. Steer tubes are also often marked near the crown end. Ribs inside the steer tube may also indicate tube type: Five helical ribs are Columbus, five straight ribs Ishiwata, and six helical ribs Tange or Vitus. N.B. Columbus changed from stamping to graphite discharge marking in the mid 80s; pain will completely obscure this type of mark.
JohnDThompson is offline
Likes For JohnDThompson:
Old 12-07-23, 02:31 PM
CrowSeph
CrowSeph's Avatar
Quoted: 333 Post(s)
in the next day i'll cheeck the other frame. thanks for the tips
CrowSeph is offline
Old 12-07-23, 02:32 PM
CrowSeph
CrowSeph's Avatar
Quoted: 333 Post(s)
Improve looks?
(last resort)
the new owner requested a full restore.
still i'am undecided what to do
CrowSeph is offline
