Swapping Quick Release and Bolt-on wheels
Quoted: 5 Post(s)
I have a hybrid bike with bolt-on wheels but wanted to replace the front tyre. I have a spare wheel but it's a quick release.
Would it be better to fit the bolt in the new wheel, or do I have to use a quick release skewer? If quick release, is it just put the skewer though and tighten, or is there more to it than that?
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Bolt-on wheels and quick-release wheels use different axles. If you’re asking if you can use a quick-release wheel to replace a bolt-on wheel… yes you can, with limitations. It’s best to take the wheels to a bike shop and pose your questions to an experienced mechanic.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Quoted: 5793 Post(s)
Liked 2,593 Times
It depend mostly on the fork.
Some forks are slotted for a 5/16" (8mm) axle and will not accept a 9mm QR axle. Otherwise, if the wheel slots in, and you know how to adjust and use a QR, then you're good to go.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 514 Post(s)
Liked 451 Times
Or you can take a round file to the dropouts and widen them a little.
