How to add brake levers to alloy bars without scratching them?
Bikes: 1952 Rudge Pathfinder / 1950's Raleigh Lenton Sports
I have just finished polishing the GB alloy bars off my Raleigh Lenton. It took me bloody ages! But I'm very satisfied with the finish! But I was wondering if anyone has any tips on how to put the brakes levers on without scratching the bars? I always struggle to get the Steel Raleigh brake levers onto racing bars without them digging into the metal when you push them round the curves.
Heres a picture of the bars and levers as so you know what I'm dealing with. The levers are thick steel and even when you take the tightening nut and bolt out they still scratch the bars.
Thanks
Thanks
Quoted: 478 Post(s)
Liked 634 Times
The only sure fire way in my mind is to bend the mounting ring out enough to have a very loose fit, then bend it back when in position. But that seems barbaric.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
Sand the inside of the band to remove sharp edges.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Depending on the state of your lever clamps. Minimal/no scratching can be had with most NOS levers that never had their bar clamps tightened against a bar, but once they are used, some levers like old Shimanos, tend to shape their clamping bands into permanent, tight circular shapes that then make them hard to remove without scratching the bar. Other brands (I noticed, most of the French ones I had used) that tend to retain a more "U"-like shape clamping band are usually easier to remove and re-install on bars without scratching them.....
Bikes: 1970 Holdsworth Mistral, Vitus 979, Colnago Primavera, Corratec Hydracarbon, Massi MegaTeam, 1935 Claud Butler Super Velo, Carrera Virtuoso, Viner, 1953 Claud Butler Silver Jubilee, 1954 Holdsworth Typhoon, 1966 Claud Butler Olympic Road, 1982 Claud
Quoted: 10 Post(s)
Liked 11 Times
The good thing is, even if the bars do get scratched at the bottom, this is usually covered in tape or rubber grips.
Quoted: 1609 Post(s)
Liked 2,216 Times
I have spread the band after removal enough to improve and avoid scratching. Typically, I put the band on first, then the body. This allows me more control of the band placement. Also, rotating the band as you engage the bend will often help as the band is no longer round, like the bend. The bend will be "wider" and less deep through the bend so rotating the band with the mounting stud or feature toward the center of the bar will often help.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Yup. I never tried too hard to avoid scratches.
agmetal
Classic & Vintage
0
07-02-13 12:49 AM
Thumpic
Classic & Vintage
15
04-06-11 01:04 PM
