Downtube index shifter not returning all the way after shift
I've been trying to tune the rear shifting on my wife's bike for some time now, and can't get it dialed in. The problem is when I shift from lower to higher (larger to smaller) gears I can get it indexed properly, but if I shift from high to low gears across the cassette it will grind slightly and slightly touch the neighboring cog.
I've observed the following behavior in the shifter. When I push forward to upshift it fully seats against the index stop (not sure the exact word, but the "notch" that determines its index position). But if I shift in the other direction it does not return all the way to the stop. But if I push on it, only then will it fully seat. This means that the cable is pulled slightly too taught when shifting in that direction, and the pulley wheel is slightly misaligned with the cog. This shifter behavior is also present when there is no cable attached, and just shifting the lever on the frame.
I've now tried 3 different downtube shifters—2 older but in nice condition 7s Light Action shifters, and a brand new Shimano SL-R400 set I bought new—all with the same result. I have 10s dura ace downtube shifters on my own bike, and they do not exhibit this behavior. So I'm wondering, is this expected behavior for these shifters? Is it compensated for somehow in the rest of the drivetrain and that isn't working? Is there something else I need to do to make sure it indexes to the exact same place for a given cog, regardless of the direction I shifted from?
I's appreciate any help. Thanks!
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
SE Wis
Liked 3,398 Times
Quoted: 1944 Post(s)
Liked 2,164 Times
I have a similar issue but only on the 2nd position. But it happens more on the upshift (3rd to 2nd). It doesn’t grind but can be a bit noisy. It would go away if I put pressure in the opposite direction on the lever; which wasn’t acceptable. New set of Ultegra 6401’s.
Since you have the same issue with 3 different sets shifters, I would check the rear derailleur to make sure the pivots and cage are tight. I’m not betting there is a problem here, but at least rule it out.
When you set everything up can you turn the cable barrel adjuster and get it to quiet down on the downshifts? Shift from first position to fourth and turn the adjuster, probably left (out) to tighten the cable.
If it shifts fine downshifting, you might be able to fudge the limit setting and spacing on one of the cogs. It may mean finding a workable compromise. Since all indexing starts from the 1st position cog, (top normal), that is where I would begin.
I know my stock 8 speed Shimano cassette has a spacer that measured 3.09mm instead of the typical 3.0mm for 8 speeds between the 2nd and 3rd cog positions. I ended up using an even thicker 3.2mm spacer and that helped.
Over the years I have read accounts of Shimano’s cog spacing not being a consistent amount throughout the cassette, but never tried to verify it or if that is just for the older downtube/thumb shifters.
Good luck!
John
Edit Added: If you get it pretty good, a slightly narrower 9 speed might help to quiet it a bit more.
Good luck!
John
Thanks for the replies!
They are tight
Yes
It really does seem to be related to the shifter(s) or their setup. I mean, they definitely have the behavior I described, which doesn't seem desirable as far as I can tell. So either the shifters are supposed to be that way, all three I've tried are defective, or I'm setting something up wrong (though I've installed shifters a bunch of times, I haven't encountered this issue before).
Here is a video of what is happening with the lever, needing to be push into place after downshifting:
https://drive.google.com/file/d/1K41...ew?usp=sharing
Liked 2,164 Times
Couldn’t anything tell from the video. Obviously make sure the shifter selector is clicked into Index and the M5 shifter attach bolt is as tight as possible.
John
John
Liked 2,164 Times
Just curious, are you running the Shimano Centeron/guide pulley?
John
John
Yeah, right now it has a Shimano 105 derailleur with a Centeron/G pulley. But in my efforts have also tried an Ultegra derailleur, an old Exage derailleur, as well as swapping out for some cartridge bearing pulley wheels from Velo Orange I had lying around. The guide pulley on those doesn't have any float though like the Shimano ones, and whether that is the reason or not, they worsened the issues (though the wheels spin very smoothly).
I double checked, and the M5 bolt is tightened. I made sure the 7 speed levers I tried were fully clicked into index mode. And the shifter on there now has no friction mode, only index.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
I can't tell what is going on here. Op mentions 7 sp, but Shimano SL-R400 is 8 sp. The spacing is different. No mention of exactly which DR is being used.
For 8 sp I had to read the shimano DR setup instructions to the letter to get it to work right.
In most combos I can get it to index properly in one direction (upshifting), but in the other it does not, unless when I downshift I then push the shifter lever back into place, since it does not settle into the correct position on its own. I would probably live with it if I had no other choice, pushing the lever back after each shift, but I know my wife will not always do that, and will then have gears slip (this is what happened when she took it out for a test ride).
So I'm still curious about this shifter behavior, if it is normal, and usually just works anyway. I have a Schwinn Voyageur with 7s Light Action shifters, and it all seems to work fine. It's in storage, but I want to check when I get a chance if the shifters on that bike have this behavior as well. Perhaps some of you can tell me if this happens on your bikes, but still works fine anyway.
Liked 2,164 Times
As a direct answer, no that is not how the index shifter should work.
John
John
Likes For 70sSanO:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
ALL of those parts mentioned should work well with each other. And in many years of working with Shimano down tube shifting components, have never (with the exception of 6208’s) had any go bad or do what you describe.
There’s something very basically wrong here, and it may well be in the cable and housing setup. Shifting up (small to large) means you are putting positive pressure on the cable. Shifting down (large to small) means you are releasing pressure on the cable and the RD spring is providing the cog change. Different RD’s tried means it’s not a bum RD spring so it has to be somewhere else kn the system.
Good Shimano stainless drawn cables of good Jagwire housing would be one suggestion.
An update:
I seem to have gotten it working pretty well on the stand. She'll have to give it a test ride to really tell, but it's pretty smooth and reasonably quiet in the stand.
I tried the suggestion from 70sSanO to try a 9 speed chain. I put the 7 speed cassette and 7 speed Light Action shifters back on, with the Ultegra 6500 derailleur. The shifter still has the issue of not seating in place when going from harder gear to easier (without being manually pushed back into place), but the combination of the wider 7 speed cassette spacing and the narrower 9 speed chain seems to compensate for the variation in shift position caused by the shifter, and keep the chain from touching the neighboring cogs. Fingers crossed it works on the road!
The bike in question, in its current state, if you are curious:
Quoted: 405 Post(s)
Liked 430 Times
If a narrower chain helps, by adding additional play into the system, that's a useful thing to know. Clearly, there's an underlying issue, and I think it's in the frame. The symptoms are classic for a bent hanger, but yours is straight, so... misalignment in the rear triangle? The hanger being square to the dropout won't help if the dropout itself is crooked.
Just a thought,
--Shannon
Just a thought,
--Shannon
Just a thought,
--Shannon
Just a thought,
--Shannon
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Liked 6 Times
this finnicky behavior can also be a result of chain and/or cassette wear in just the most used gears, changing a chain but not cassette or both of them just being worn too far together.
