Did I buy the wrong size tubular tires???!
Time Traveler
Bikes: 1983 Ross Paragon
Quoted: 204 Post(s)
Liked 98 Times
So Im out there about to put the new tubular tires on the 1986 Nashbar road bike and they seem to small. I cant get them on the rims to test fit them? Did I get the wrong ones? They say on the side 23 - 28". Vittoria Rally. I was told I have 700c rims. I cant find anywhere on the wheel where it says anything about its size. I hope I dont have to send these back and then wait some more for the right tires. Im really getting antsy to ride this bike!
Quoted: 939 Post(s)
Liked 2,950 Times
Have they spent any time inflated in order to stretch them out? I recently bought a set of Vittoria Corsas and they spent a week or two unmounted and inflated (I don't remember, maybe 60-70 psi) before I tried to put them on rims. When I did it was not overly difficult.
Likes For ascherer:
Quoted: 835 Post(s)
Liked 2,141 Times
Sounds like you have the right size tires. You do need to stretch them out a bit before glueing. The first mounting can be a challenge but stick with it. Once you get it on the rim, inflate it to max pressure and let it sit a few days prior to glueing to reduce struggling with a glued up tire.
Likes For gaucho777:
Bianchi Goddess
Quoted: 2937 Post(s)
Liked 2,934 Times
Yep. They just need a little stretchy stretch. Most tubular users keep their spares hanging out on old rims.
Sugar "Kane" Kowalczyk
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
the last thing you want to be is antsy when installing sewups, you have enough trouble so breathe!
Don't know why certain European makes call a 700C tire 28" but they do when it comes to tubulars. Maybe just to make newbies more antsy!
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
But in this day and age, the tires that fit on 700c/28" rims aren't fatties that would have inflated to 28", they are tires that evolved into the skinny 700c tubulars of recent decades, still mounted to the same, very-old-sized 700c rims.
Don't expect durability from cheap tubulars such as the Rally, Giro, or Yellow Jersey and such. They tend to suffer a variety of failures not even related to punctures.
I haven't used them in about two decades, so they might have better quality control now. They were inferior to the cheap racing clinchers I used at the time for training, in terms of their durability. I had blisters appear under the tread many times, which led to blow-outs even running very modest pressures for my 150lbs.
Stepping up to Sprinters or Tufos, durability was quite good.
All of this sizing discussion brings up the question: "Are there 27" tubulars, or are they all 700C?"
Quoted: 1609 Post(s)
Liked 2,216 Times
@MaoHOUS - predominantly 700c/28. There is a t least one exception for junior racing, but I don't remember the size, something like 24"
Freewheel Medic
Quoted: 1455 Post(s)
Liked 2,197 Times
I have no idea why there is the "27 inch" designation. If you measure the diameter of the tubular rim with an Imperial tape measure, you will come really close to 26 inches. I've seen eBay sellers who are not bike savvy list tubular wheelsets as "26 Inch Bike Wheels." I was able to purchase Dura Ace/Aero tubular wheelset at an amazing price last year because the seller listed them as "26 Inch" wheels.
Bob
Bob
Quoted: 242 Post(s)
Liked 456 Times
They are the right tire.
They are hard to get on a rim because they just 'sit' on the rim using glue to hold them in place so a very tight fit is necessary.
I always dry fitted my sewups to a spare rim/wheel to allow them to 'stretch' into shape before use. I'd let them sit for weeks or months before using them. Even then, depending on the tire brand, it is hard to get them on. Vittoria is one of the 'easier' to put on a rim and was my favorite sewup...Vittoria Corsa's 21mm ahhh those were the days.
They are difficult to put on a rim but the more you do it the easier it gets as you learn techniques to assist. I always sat on the floor and used my bare feet to hold the rim at one end while using my hands to bring the tire onto the rim.
I always started with a thin film of glue on both tire and rim...allow to dry for at least several hours then apply another thin film of glue to the rim and install the tire...once installed adjust the tire on the rim making sure it is centered...allow to dry for 24 hours before use...I never rolled a tire using this method.
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 338 Post(s)
Liked 314 Times
I bought a Sprinter 26" x 22mm tire a couple of years ago by accident. No idea what wheel it is made to fit. Make an offer LOL
Never try to teach a pig to sing...
Edumacator
Quoted: 2443 Post(s)
Liked 3,137 Times
Likes For jdawginsc:
Time Traveler
Quoted: 204 Post(s)
Liked 98 Times
.......I always dry fitted my sewups to a spare rim/wheel to allow them to 'stretch' into shape before use. I'd let them sit for weeks or months before using them....
Do you inflate them to full.pressure while they are drying for 24 hours before use?
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,844 Times
As to the question of, “Did I get the wrong ones?” The answer as always = Depends. Maybe you should have tan walls or the ‘green’ walls instead of black sidewalls. A pic of the 1986 Nashbar would help.
(the greenish color is obvious in better light)
Taping or gluing both work. Tubular tape is faster. As a longtime gluer, I now trust tape for tires 28mm or narrower.
Likes For Wildwood:
My Workshop = Happy Place
Bikes: Schwinns, and many others.
Quoted: 42 Post(s)
Liked 224 Times
I just did a pair. first time for me, and it was HARD to pull around, even stretched.
i DID expand them according to Calvin on
Put 100lbs of air in them overnight or longer as they came.
They WILL turn inside out, but apparently it won't matter. Mine fitted and are in place perfectly now (I used three coats of glue: Once on the rim and twice on the Tubular.)
Thanks to others for the insights on what 700c and 26/27" means.
Likes For SharpByCoop:
Quoted: 2490 Post(s)
Liked 2,960 Times
In Tubular lingo 27" = 700c and 28" = 700c.
"Tubulars existed in several different sizes, but only 700c and 26-inch tubulars are readily available these days. Beware: sizes of 26" and 24" tubulars are not well-standardized. Take the rim with you when buying a tire, and vice versa."
“Senior” Member
i DID expand them according to Calvin on the vid on Park Tool: Put 100lbs of air in them overnight or longer as they came.
if that’s the case, you will find it easier to mount with just a slight bit of air in the tire to hold shape.
Quoted: 42 Post(s)
Liked 224 Times
I wish I knew better, I took almost ALL the air out of them to mount. it was messy, yet I got it.
Next time I'll leave them inflated just a bit. Like mounting an inner tube: Give it some shape better than no air.
Thanks.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
I always stretch the tires before gluing them. Getting a new tire on the rim to stretch can be a challenge; I use zip-ties to hold the tire in place as I wrestle up the final section. Once it's on the rim, pump it up hard and let it sit a few days before removing it for final gluing/taping.
N.B. I don't recommend fully inflating a tubular tire off the rim; it will tend to turn base-tape out, and IME that can lead to the base tape separating from the casing later on.
Likes For JohnDThompson:
Time Traveler
Quoted: 204 Post(s)
Liked 98 Times
Quoted: 42 Post(s)
Liked 224 Times
So far so good.
Quoted: 42 Post(s)
Liked 224 Times
But,.. I understand your caution. So far so good.
“Senior” Member
That video guy is clueless. He says pre-stretch first (good advice). but he just airs up a loose tire— not mounted on a rim. He just airs it up. That is not pre-stretching!
And he doesn’t even air it up to 100 (which as you hear here not a good idea off a rim) —you can tell by how limp the tire was when he set it down.
You have to be careful who you listen to!
Addendum: As I think about it more, maybe he is saying one thing but doing another. I just looked at that part. Not the whole video.
I can see how it was confusing. So at best it was poorly presented.
