A mechanical question
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3194 Post(s)
Liked 1,844 Times
My coupled bike is a 1984 Schwinn Letour Luxe, because that was the bike that was still in the states when I ran out of places to leave a bike. I'm trying to work it into the rotation, so it's ready to go when I am, and also because it's a nice ride.
On the rear is a Día Compe long reach centerpull caliper, NOS. The levers are Shimano 600 EX? The rim is Alex ACE19 700C. I initially put Shimano pads on it and had zero braking power. Changed them out with KoolStop Salmon MTB pads, with similar results. Is it possible that the levers and the caliper are incompatible? Brake pads? Other?
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
About your initial question- yes, Shimano SLR calipers don't play well with non-SLR levers- but it's more that the lever doesn't pull the cable back to start, so you have to flick the lever forward after you brake.
About this- My guess is that's a REALLY long reach on a center pull caliper-
Commence to jigglin’ huh?!?!
Quoted: 3813 Post(s)
Liked 3,344 Times
in photo of rear caliper pads appear to be out of adjustment with rear of pad touching rim first rather than front of pad touching rim first
Likes For juvela:
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
I have to admit that contemplating mechanical advantage and straddle cable length always make my brain hurt so here is some advice from Sheldon. I will add that I've always found a cable adjuster somewhere along the track is essential to get the best out of a set of anti brakes.
https://www.sheldonbrown.com/canti-trad.html
https://www.sheldonbrown.com/cantilever-geometry.html
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,926 Times
I don't see any SLR (Shimano Leaner Response) calipers or levers so I don't think that is a concern
I think the bike problem is the adjustment of the pads themselves. They need to be adjusted so the front of the pad contacts the rim first by a few micromillimeters and motion of the rim pulls the pad flush to the rim
I'd also consider swapping the hardware around and try and get that fat washer on the inside of the arm, you might be trying to close the brake past it's optimal leverage point
Sugar "Kane" Kowalczyk
Edumacator
Quoted: 2440 Post(s)
Liked 3,129 Times
Agree. Would a shorter straddle in addition to the suggestions above give a quicker response?
Bianchi Goddess
Liked 2,926 Times
It might but I haven’t dealt with center pulls in years so I couldn’t tell if that is the correct one for caliper or not
Quoted: 3811 Post(s)
Liked 6,707 Times
The straddle length is fixed on those Weinmann/DiaCompe 610/750 brakes. I’d try different levers, preferable aero.
Likes For nlerner:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
I also think that slim design is a poor choice of K-S pad for those calipers. I would go with K-S Continentals.
Likes For SurferRosa:
Liked 1,844 Times
Thanks all, especially for pointing out online resources. That aspect doesn't quickly occur to me, I don't know why.
This bike normally gets used 2-3 weeks per year and spends the rest of the time languishing in its case. So whatever adjustments I made for its previous trip are long forgotten when the next trip presents itself. The obvious solution is just to keep in the rotation.
Liked 1,844 Times
Checking in. I went to the Park Tool video and followed it. And tried every set of pads I could put my hands on. The only ones that showed any improvement are those same KoolStop. I agree they are not the best choice, but also I realize that I simply don't have access to vintage bike parts. The other model suggested is certainly the better option, but I can't lay hands on them. As I was getting ready to move on to something else, I remembered another stash of brake pads, including another set of KoolStops and a couple brand new KS inserts, and will fiddle with them this afternoon or, more likely, tomorrow morning.
I also have the option of drilling the brake bridge, in order to install the Tektro long reach sidepulls I have. But I have not yet made the decision to do that. This bike functioned perfectly in August of 2021, so it's just a matter of figuring out how it was set up then. Memory is a terrible thing to lose.
Edit: I have long been under the impression that the toe in was to be corrected in response to noise, and the Park Tool video , in part, confirmed that. Nonetheless, the adjustment has been made and it's working better. I have hope for the next round of pads.
Quoted: 1608 Post(s)
Liked 2,216 Times
Did you sand down the pad surfaces? that is a rear brake shown so I wouldn't judge performance too harshly.
I have found that adjusting the pads on center-pulls as close to the rim as possible provides the best performance. Keep in mind that CPs are dual pivot brakes.
As mentioned, cable housing and maybe ferrule choice can impact performance by allowing too much elasticity in the system. Not to mention routing.
Liked 1,844 Times
^^^^Good points. I did sand the pads. I'm using Sunrace housing. I have a couple extra pairs of ergo levers too, and may give them a try.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
just for sharts and fartles, try changing out the levers. I'm wondering if it's not a mechanical advantage thing with the length of those arms and the limited pull of the 600 lever.
Likes For Schweinhund:
Paramount Fan
Bikes: Paramounts, Raleigh Pros, Colnago, DeRosa, Gios, Masis, Pinarello, R. Sachs, Look, D. Moulton, Witcomb, Motobecane, Bianchis, Fat City, Frejus, Follis, Waterford, Litespeed, d'Autremont, others, mostly '70s-'80s
Quoted: 123 Post(s)
Liked 240 Times
Pull repeatedly on the levers and look for movement in cable housing, hanger, etc. It all adds up and is the bane of centerpulls, which already have plenty of flex in the caliper itself. Sharp bends in the housing introduce friction that also saps applied force. Better cable inner wires are pulled through a die to flatten the outside surface and reduce friction. The biggest improvement, though, will be in switching to aero brake levers. Providing you don't have so much flex that you run out of cable pull, their increased mechanical advantage will make all the difference. If you still require more stopping power, a suitable length dual-pivot caliper is probably your best bet. I've seen some rims on which almost nothing seems to work well. I always figured that there was something about the type of aluminum, just as there are some rims that are much more likely to give up aluminum that embeds into the pads, the Weinmann concave being the first that comes to mind. There can also be a huge difference in the friction provided by new pads and that of old, dried up pads that otherwise look fine.
Liked 2,216 Times
There is another good point. Really clean your brake surface. I found that to be a huge difference on some rims.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Just as a side note, I found that those levers did not work well with my Mafac centerpulls, regardless of brake pad.
Likes For rccardr:
Liked 1,844 Times
I cleaned the brake surface, and have used the same wheel on other bikes. My first guess was that the arms are sooo long. Ergos it is then. I have had no knowledge, over the years, about length of pull of different levers. That kind of info makes my head spin. There are folks here, who specialize in such, so I just asked.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
https://www.chapmancycles.com/cantilevers/
The accompanying essay makes my brain hurt a bit, but I find the interactive tool to be very illuminating. For center pull brakes, if I understand what it's telling me, the only thing you really have any control over is the length of the straddle cable/height of the yoke, and once you get beyond a certain point, which I think most centerpull straddle cables exceed, even that isn't a factor.
My Bikes
My Bikes
Liked 1,844 Times
Have you seen this?
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 532 Post(s)
Liked 1,007 Times
Have you seen this?
Quoted: 3513 Post(s)
Liked 2,926 Times
I'd also consider using compressionless cable housing, which should also offer a dramatic improvement.
Likes For smd4:
Not so New
Definitely swapping the Kool Stop pad spacers using the thicker pad spacer on the inside of the caliper will improve braking as Bianchigirl suggested. As the the slotted part of the caliper goes beyond parallel with the rim you are losing leverage.
Liked 1,844 Times
Brake levers and pads changed. Test ride tomorrow morning.
