700c skewer recomendations?
i took a wheel set of my old 853 bike. and the cam on the skewer is shot... worn out,, im looking for some decent, inexpensive skewers.. they dont need to be Ti but i would prefer alloy handle to steel old style Shim stiyle.. i dont want the hex key style... those sent me to the hospital once... just lever type.. no carbon..
and suggestions... are ones off of the EBAY any good or steer clear?
These are pretty good, moderate cost.
Amazon.com : SRAM Quick Release Pair SS X.9 Black : Bike Wheel Skewers : Sports & Outdoors
Liked 58 Times
I agree with you, but OP seemed to be asking for external cam type, or so I read his post.
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Liked 294 Times
These are very light generic skewers sold under several brand names. I've had them on my bike for 4 years w/o problems. I've given two sets away as little b'day gifts and they are still going strong too. Just don't treat treat them like steel, but with vertical dropouts you don't need to.
Titanium Alloy Skewer Bicycle Wheel Quick Release Hub for Road Mountain Bike | eBay
Old fart
Liked 3,460 Times
Sure, but perhaps what the OP is describing as "worn out" is simply inadequate clamping on a horizontal dropout. I have yet to "wear out" a skewer, and some of mine have had over 30 years of service.
Liked 58 Times
Your guess is as good as mine, maybe better. But you know me, I just aim to please.
these are easton ea something wheels.. and the front skewer will not clamp ;with any force or snug up and close... i consider them warn out if they just close but will not stay closed of clamp.. its done i got enough good suggestions.... close thread.
Thread Killer
Liked 1,815 Times
Or, if it's the nylon cam bed that's often used which is of concern, there are those which use metal. But anyway, that's not a "clamping force" issue but rather a wear issue, no?
Can anyone explain this to me?
You can get them for about half that price if you watch the auctions.
Our local bike co-op has a pile of skewers of different lengths. Maybe some picking around for matching nuts, but they are good solid old-school type skewers. Keep in mind that there are different lengths of rear skewers. Oh, I need to skim about 1cm off the end of that titanium skewer.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Liked 10 Times
Shimano makes alloy handled QRs as well; I use them and they work great.
This is just an example:
https://www.ebay.com/itm/Shimano-Dura...WuF2efMPd9IG2g
Today, I believe my jurisdiction ends here...
This is the conventional wisdom, but I don't understand why that would be universally true. I mean, they both work by displacing the axle skewer with an eccentric, so whereas one may be easier to operate, isn't the clamping force determined by the amount of offset by the eccentric?
In addition, the exposed cam has a larger diameter, (typically 16 mm vs. 7 mm for an enclosed cam) so the friction is acting on a longer moment arm (the radius of the cam.)The result is that the exposed-cam type provides very much less clamping force for a given amount of hand force on the lever.
Thread Killer
Liked 1,815 Times
Advocatus Diaboli
Liked 1,558 Times
Get a couple of trainer skewers and call it a day?
Liked 58 Times
Isn't it true that the clamping force that results from the greatest force you can physically exert on the handle will be lower with the external cam? That is ultimate clamping force, not ease of use. Right?
Thread Killer
Liked 1,815 Times
But the issue is not ultimate clamping force, but rather what is insufficient clamping force. I, personally, have never exerted, nor needed to exert, all the force I can muster in order to close a quick release and secure a wheel.
Thread Killer
Liked 1,815 Times
Liked 58 Times
Me neither. And I use external type. Just saying that if a person won't exert more than a given force, they will get lower clamping force from that with external. Hey, I can see this is just a semantic argument I'm waging. Over and out.
Thread Killer
Liked 1,815 Times
In fact, given the practical dominance of external cam skewers and the utter absence of official admonishment to avoid all but vertical dropouts, it seems very unlikely that the common refrain that they provide insufficient clamping force would be true.
you may be right, i will tell every one NOT TO BUY THOSE SKEWERS THAT TIGHTEN WITH A HEX KEY... they may be light weight.... but i had some on my cannondale.. thought the back wheel was in there good, friend says "lets wind up a sprint for the limit sign...... see where this is going... kicked for the limit sign.. back wheel jammed in to the rear stays of the bike.. halting all forward progress.. not sure the speed.. but it was enough to knock me out.. i woke up in the hospital, asking about my cycling shoes... Glad i have a bucket on.... but those skewers sure were lite.... i kinda hope they took them off the market... but i doubt it.
Thread Killer
Liked 1,815 Times
Hers were not old and worn out, but I believe they had a design flaw.
