Salsa Down Under rack with Ortlieb panniers?
Erect member since 1953
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Quoted: 121 Post(s)
Liked 38 Times
I have a set of Ortlieb sport roller classic panniers and need to mount them on a Salsa Vaya.
The Salsa Down Under rack looks like a reasonable choice BUT I've seen online comments that those two products don't connect well; that the Down Under just doesn't have the bars in the right place for the Ortlieb Sport Roller Classic
Fact or fiction? Advice?
Quoted: 2604 Post(s)
Liked 1,933 Times
You do understand the Ortlieb hooks can be repositioned as necessary along the top, right?
Quoted: 121 Post(s)
Liked 38 Times
Show a photo of this area of your panniers. Some older models have only one rail for the mounting tab, and the older ones even had a straight rail, which can be more limiting to proper tab positioning.
The curved "smiley face" rails give more options.
Be aware that you can also face the tab towards the back of the bike if this works better with a given rack support.
One of my bikes is set up this way.
I would add that often people don't get how to set up the Ortlieb mounting system correctly, but in their defense Ortlieb doesn't provide the best info out there--BUT I partially understand this because rear racks have such a wide range of shapes and position of this and that.
**Most important aspect is to eliminate fore and aft movement of upper parts on the racks horizontal tubes, and to position tab in right place to make this happen.
Liked 1,933 Times
At least on all my Ortliebs (3 pairs), the bottom tab can be moved in an arc about 6" long, and the tab can be rotated 360 degrees. I'm not saying it's impossible that it won't fit some rack, but I have never seen a rack on which that tab can't be arranged to fit.
Quoted: 121 Post(s)
Liked 38 Times
Thanks for the details. I ordered the Down Under and the sport rollers came yesterday. I'm feeling more confident now that I'll be able to make it all work.
The lower tabs of Ortliebs can be moved around quite a fair bit, and some Ortliebs have two rails that the tab can be mounted on, increasing possibilities of where tab is positioned.
Quoted: 3462 Post(s)
Liked 1,468 Times
Quoted: 121 Post(s)
Liked 38 Times
The rack arrived, but I will likely get on a plane before I get a chance to mount them. I will report back after June 1. Thanks again for the help.
