Hookless Tires?
Hookless Tires?
So I am getting a set of Zipp 303's soon. I am shopping for road tires. I wanted to try Michelin Power Road TLR's. They are listed for ENVE AR's as approved, bu they do not show as approved by Zipp. I emailed Michelin, no response yet. Seems logical they would be ok for the Zipps? Am I missing something? Anyother recommendations are welcome to.
Quoted: 20810 Post(s)
Liked 9,456 Times
I haven't been going strictly by Zipps approved list - it's still petty abbreviated. I've been looking to manufacturers and the Enve hookless compatibility list.
So far, the following manufacturers have given the hookless blessing on:
Michelin Power TLRs
Pirelli P Zero Race and Race SL
Schwalbe Pro Ones
Goodyear Eagle F1
Keep in mind that there are some pressure (72.5psi max) and size restrictions, typically with tires measuring smaller than 28mm (though I assume that you'll be sticking to the 28mm or larger, anyway, with the 303S).
Michelin Power TLRs
Schwalbe Pro Ones
Goodyear Eagle F1
Likes For WhyFi:
Michelin Power TLRs
Schwalbe Pro Ones
Goodyear Eagle F1
Michelin Power TLRs
Schwalbe Pro Ones
Goodyear Eagle F1
Yup going with 28 Michelins. Thanks. I figured if ENVE said they work it should be ok with Zipps as the rim bead is straight on both. Just wanted some positive reinforcement lol
Liked 9,456 Times
ENVE has a few hookless rims at 23mm and 25mm, which matches the Zipp 303S and 303FC. Beyond that, many of the tire manufacturers that are making hookless compatible tires are ahead of the curve with regard to WAM, RAM and compatibility at various internal widths. I'm pretty comfortable, as a Zipp hookless rim user, interpolating from all of that available info, even if Zipp hasn't gotten around to giving a specific tire in a specific size their blessing.
Michelin is Not mentioned on the Sram/Zipp support site, but Im sure, if you dig deep enough, you can find arguments to "interpolate" that any tyre is perfectly fine, - but at the end of the day you are still experimenting and on your own if it blows off. Imo, at present hookless is a public experiment with No tyres designed specifically with a straight wall rim in mind. Id play it safe and not encourage anyone to venture outside specific manufacturer recommendations.
Liked 9,456 Times
That's only because you don't know what you're talking about. I've already mentioned multiple specific manufacturers and models a couple times, but you can't be bothered to confirm, because you've got no skin in the game and you just want to trash talk from the sidelines. Typical 41ier stuff.
