Where to find mounting brackets/hardware for baskets and racks?
Hi all, does anyone know where to get the mounting hardware/stays for racks and baskets? Most bike stores I go to don't seem to carry them independent of their racks/baskets, so I figure hardware stores like Home Depot carry a rough analogue that I could DIY into something that works - but I don't know what they're called exactly; are they called brackets or something else?
I'm looking to attach a basket to the fork eyelets via stays (like here: https://www.youtube.com/watch?v=V1q7...garys.projects - but the IKEA ones he suggested are too short for my bike/basket) for reference.
(hope this is the right subforum)
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
A regular front rack would be much stronger than the contraption constructed in that video. You can zip-tie the basket of your choice to the rack.
If you want to go the DIY route, I think a search for "bicycle rack mount hardware" would be a good place to start - although you might end up paying more for that stuff than a cheap rack would cost.
Quoted: 5793 Post(s)
Liked 2,585 Times
Search "bicycle rack P clips" and you'll find all kinds along with related hardware. The rest is up to you, but will probably involve a rack with a basket or box attached.
FB
Chain-L site
FB
Chain-L site
Quoted: 1438 Post(s)
Liked 1,092 Times
"P" clamps, also known as Adel clamps, are often used for such purposes. I buy the metal type with rubber(ish) cushioning. https://www.amazon.com/adel-clamps/s?k=adel+clamps; I consider plastic clamps insufficiently strong.
The perforated metal strap used by plumbers is also useful for improvised hangers and brackets. Hardware stores also have various metal brackets and odd pieces which can be pressed into service; creativity is the key word here.
Don't forget the possibilities offered by stainless steel lock wire; I use 0.041" https://www.amazon.com/Wire-Cable-Sp...005BS3V3O?th=1
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
The people telling you to use a regular rack for support, then fasten a basket to that are concerned about the issue of load.
I would not use that basket in your video for anything heavier than a newspaper.
The metal P clamp (with vinyl coating) is a standard hardware item, that you can find at Home Depot or most hardware stores.
They are usually over in plumbing and electrical, where they get sold to hang pipe or conduit (sometimes wiring, enclosed behind sheetrock).
Used Blackburn (and similar) rear racks are a common bike co-op item. The one here has an endless supply of them.
You use the P clamps to fasten them to the seat stays, if there is no threaded fitting on the frame there. Then the legs get bolted to the dropout fender eyelets (assuming your bicycle has those).
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Likes For dedhed:
Quoted: 540 Post(s)
Liked 416 Times
I'll be honest, this takes a bit of engineering innovation from a DIY perfectionist.
Some folks can half-arse everything with zip ties.
My installs look like they are done from the factory.
There is no one stop shop.
Fastener shops, metal stock suppliers, local hardware stores, mail order, I source whatever I need to have on hand.
Likes For soyabean:
Liked 1,092 Times
You can do surprisingly good work on some aluminum stock with a hacksaw, hand drill, a file and some patience. The rear rack mount on one of my bikes with a mono-stay rear is a cut-down handlebar mount for a water bottle, with some added brackets made from aluminum angle.
Quoted: 540 Post(s)
Liked 416 Times
I believe the MIK system (Mounting is Key) turns any front or back panier rack into a tooless quick disconnect for any other bag, basket, whatever.
mik-click.com
mik-click.com
Likes For soyabean:
Quoted: 514 Post(s)
Liked 450 Times
Most shops can order what you need and get it in about a week.
Will definitely keep that in mind for more polished projects, thanks
I ended up going to Home Depot to look for anything I could use as arms, but all I could find were these bars(?) they use for cabinets
It's a little ugly, but it works for whatever my friend will need to carry (probably a bag of groceries or a backpack), and I'm considering a repainting in the future anyways
Likes For BrenZan:
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
So you can find aluminum bar stock, and aluminum angle stock at home depot too. Aluminum Metal Stock As you can see, they also sell aluminum rod and square tubing as well.
Not sure if it will work better for you or not, but they sell it at the Home Depot near me.
I was actually considering using aluminum bars when I was at Home Depot, but I realized that I don't have the means to work it reliably at my disposal (all I could effectively do was maybe drill a hole or two, with no vice or torch I feel like I'd snap it easily)
My kingdom for shop equipment and the knowledge to use it....
Likes For BrenZan:
Brenzan, you're asking about how to work metal, which you will certainly need to do, without tools. That ain't gonna happen. You will get the knowledge with use of those tools and like the rest of us by making mistakes.
For taking on projects in lighter metals such as making up supports to adapt a wire basket to a bike you'll need your drill and a few other things. Find a spot where you live or where you work or go to school where there is a table or bench that folks will not mind if you mark it up a bit. Adding to your hand drill I'd suggest the following to start out;
- Two F clamps that are 30cm / 12 inches long for clamping stuff.
- A clamp on vise that is around 5 lbs in weight. So something bigger than a toy. But not overly heavy to carry.
- A hacksaw and a few 32TPI and 24TPI blades. Then learn to use it. For aluminium you can use it more or less like a wood saw. But when cutting steel use a slower stroke and firm but not excessive pressure. Done right you'll feel the teeth dig in and a nice spray of swarf runs out the far side of a cut. Done poorly you'll feel the blade lightly skating over the metal or binding all the time. For steel a good speed is a touch faster than 1 stroke per second for a 12 inch blade. And enough pressure to feel it bite in and need a good push on the forward stroke. And ease off the pressure on the return to reduce dulling of the blade.
- You'll need a few files. For the round files go to a place that deals strongly in chainsaws and buy a few sizes of their round files. Cheap as chips compared to other options and they are almost always superb cutting files that really last. For a medium flat file something from Home Depot is as good as any. Files are used in the same way as the hacksaw. Slow and firm over steel and ease the pressure to a glide on the return. Files are really wide saws. They are not a fancy metal sandpaper. So treat them like saws. And don't let them rub against each other. They'll last for a long time if you do this. And not long at all if you don't. For aluminium use much lighter pressure and you can bump up the stroke speed a bit. If you use too firm a pressure it clogs the teeth of the file rapidly. There's things like chalking the file and other ideas. But in aluminium if you are clogging the file you're pressing too hard and the metal chips are too much and they stick due to the pressure.
- Some electrical tape makes for a great temporary clamp for holding round tube and rods together where clamps just fail. Get a roll or two. Same with duct tape.
- On top of that there's the usual metric tools for working on bicycles. If you don't have that already then figure on adding it.
- You'll also need a variety of pliers, cutters, vice grips and screwdrivers. I'd say get a driver set that uses good replaceable tips. One handle is OK but buy a second handle that is handle only. Or handle with only a few tips.
- You'll need a combination square and a nice ruler as well. You can get by with a tape measure but it's nice to have a metal ruler with finer lines and small increments to work with more accuracy.
- EDIT- Almost forgot a tool box. Or if you commute to where you would be working by bike a sturdy back pack to put all your tools into.
Quoted: 5224 Post(s)
Liked 3,585 Times
I've experimented with making some of my own accessories, including rack hardware & even a front rack. nothing easy about it. but it can be fun!
I suggest you use a rear rack basket system like this instead. Front baskets make steering weird when you have a heavy load.
https://www.racktime.com/en/racktime-products
