Bar-end install trick?
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Having a heck of a time with a set of Dia-Compe bar-ends. The tapered nut just spins with the pod and won't tighten down and spread the sleeve shims. Didn't have this problem installing Suntour Bar-Cons.... Yeah, I know that don't have to be super tight and the cable housing will (help) keep them in place, but I'd like 'em to be at least somewhat secure. Anybody have a trick to try?
Quoted: 1608 Post(s)
Liked 2,216 Times
Did you adjust the sleeves to just barely insert into the bar? If there is enough friction between the sleeves and the bar, they might not rotate with the nut.
I am surprised there isn't a feature that prevents this situation.
Lubricate the threads.
Likes For SJX426:
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
First idea that comes to mind after making sure both surfaces were clean is a bit of valve lapping compound (or toothpaste in a pinch) where the nut just spins to give it a touch of friction to allow you to tighten it and a little oil on the screw.
Likes For Schweinhund:
Quoted: 761 Post(s)
Liked 1,563 Times
Maybe a bit of bees wax would work. Even better would be a product called Museum Wax, but it’s something most folks probably don’t have lying around.
Quoted: 3464 Post(s)
Liked 2,829 Times
Or the mod bike shop use of friction paste
Likes For repechage:
Liked 2,216 Times
I looked at the Suntour barcon. It has a spring around the wedges which induces friction against the mating surfaces and consequently doesn't rotate.
Quoted: 761 Post(s)
Liked 1,563 Times
Well doh...! as the bald, yellow cartoon character says.... Tried a bit of beeswax, which did nothing, and was taking things apart to see about adding a little ridge to keep the tapered part from spinning (it's actually not a nut, it's a screw- the 'pod' is the nut part) and, lo-and-behold, the tapered part is hollow and takes an allen wrench. Remove the shift levers, put the pod in position, tighten with the allen wrench, re-install the levers.
Quoted: 761 Post(s)
Liked 1,563 Times
I was just trying to get the shifters tightened in the bars- with the Suntours I tightened them enough to just slide into the bars then turned them to position and tighten securely- I didn't have to remove the shift levers from the pods to do it. Now if only the snow-storm hadn't delayed my cable-housing order I'd be taping up the bars!
Quoted: 1088 Post(s)
Liked 1,205 Times
Likes For noobinsf:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Was the allen key reverse thread?
Likes For clubman:
feros ferio
Quoted: 1393 Post(s)
Liked 1,326 Times
Likes For John E:
Quoted: 761 Post(s)
Liked 1,563 Times
I guess I must have just been lucky with the Barcons..
Liked 2,216 Times
I was in a parking lot a couple of years ago where a number of people were packing up an 18 wheeler. One person was installing the front wheel of a bike using the QR lever to screw it down tight.
I could not help myself. I instructed him how to properly use a QR and warned him of the potential damage to both him and the bike with the approach he was taking.
At least this approach did not do any harm!
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 310 Post(s)
Liked 679 Times
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
-Kurt
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
The irony is how QRs were invented to replace wingnuts - mainly because of the possible dangers in a fall - but the industry has still failed to design a QR that the general public can't mistake for or use as a wingnut, which might instigate a wheel shifting out of place...and thus a fall.
-Kurt
-Kurt
Liked 4,395 Times
And as above, you can frequently install bar-end shifters "mostly-tight", and simply turn the body of the shifter (which advances the threads through the compression assembly). Shimano's electric bar-end shifters for modern time trial bikes are actually built this way, meant to be installed with a large cone wrench to turn the body of the shifter around the [fixed] screw.
